    4. ioBroker stürzt Ständig ab!
    UNSOLVED ioBroker stürzt Ständig ab!
    • Matten Matten
      Matten Matten last edited by
      ioBroker stürzt Ständig ab- Tinkerboard komplett aus.
      das ist jetzt schon das 4. mal das das system nach kurzer zeit wieder abstürzt. Was kann ich tun?
      Cannot parse /opt/iobroker/iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
      Cannot parse /opt/iobroker/iobroker-data/objects.json.bak: SyntaxError: Unexpected token  in JSON at position 13289268
      Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: SyntaxError: Unexpected token  in JSON at position 1150726
      Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json.bak: SyntaxError: Unexpected token  in JSON at position 1150653
      2019-11-15 19:19:27.385 - info: host.tinkerboard iobroker.js-controller version 1.5.14 js-controller starting
      2019-11-15 19:19:27.389 - info: host.tinkerboard Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-11-15 19:19:27.389 - info: host.tinkerboard hostname: tinkerboard, node: v10.16.3
      2019-11-15 19:19:27.391 - info: host.tinkerboard ip addresses: 192.168.27.38 fe80::613b:a0ba:b245:9d7b
      2019-11-15 19:19:27.497 - error: host.tinkerboard Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: SyntaxError: Unexpected token in JSON at position 1232765
      2019-11-15 19:19:27.600 - error: host.tinkerboard Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json.bak: SyntaxError: Unexpected token in JSON at position 1232780
      2019-11-15 19:19:27.617 - info: host.tinkerboard inMem-states listening on port 9000
      2019-11-15 19:19:28.772 - error: host.tinkerboard Cannot parse /opt/iobroker/iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
      2019-11-15 19:19:29.860 - error: host.tinkerboard Cannot parse /opt/iobroker/iobroker-data/objects.json.bak: SyntaxError: Unexpected end of JSON input
      2019-11-15 19:19:29.862 - info: host.tinkerboard inMem-objects listening on port 9001
      2019-11-15 19:19:29.877 - info: host.tinkerboard InMemoryDB connected
      2019-11-15 19:19:29.884 - error: uncaught exception: Cannot read property 'rows' of undefined
      2019-11-15 19:19:29.886 - error: TypeError: Cannot read property 'rows' of undefined
      at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:1239:28
      at _getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2817:13)
      at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2844:28)
      at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1869:20)
      at ObjectsInMemServer.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2840:13)
      at setMeta (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1237:13)
      at checkHost (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:347:29)
      at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:705:17
      2019-11-15 19:19:29.889 - info: host.tinkerboard terminated
      2019-11-15 19:19:29.892 - info: iobroker _restart
      • dbweb
        dbweb last edited by
        konnte einen ähnlichen Fehler bei mir mit "npm update" beheben, vermute bei mir waren einige Dateien nach einem Stromausfall zerschossen.
        Matten Matten 1 Reply Last reply Reply Quote 0
        • Matten Matten
          Matten Matten @dbweb last edited by
          @dbweb
          hab ich alles neu installiert. das schlimme es kommt jedes mal aus dem heiteren Himmerl, das ich eine USV vor meinen systemen hab .
          bin gerade schon wieder am neu aufsetzen😰
          • dbweb
            Als das Board ist nach dem Absturz komplett aus? Klingt eher nach einem Hardwareproblem. Schon mal die Stromversorgung geprüft, anderen Trafo verwendet?
            • dbweb
              oder deine SD Karte hat nen Schaden, hatte ich bei raspis schon ein paar mal.
              • Matten Matten
                das ist ein großes netzteil wo meine Raspberrymatic und noch ein pi3 drauf hängt. die anderen systeme laufen.
                • Matten Matten
                  Matten Matten @dbweb last edited by Matten Matten
                  @dbweb sagte in ioBroker stürzt Ständig ab!:
                  aber zweimal innerhalb einer woche... mit 2 unterschiedlichen SDs... nee denke das eher auch nicht. ich will demnächst mit iobroker direkt auf die raspberrymatic mit nem p4 4gb ram umziehen. Ich hoffe das es dann einfach besser läuft als auf armbian und dem Tinkerboard.
                  • Matten Matten
                    und schon wieder die selbe scheiße. vielleicht hat das Tinkerboard einen schuss
                    error log
