    4. Hinzufuegen von Roomba Adapter wirft Fehler
    UNSOLVED Hinzufuegen von Roomba Adapter wirft Fehler
    • scr2k
      scr2k last edited by Negalein
      ich bin iobroker Neueinsteiger, wollte nun meinen Roomba versuchen als Adapter hinzuzufügen und bekomme einen Fehler. Andere Adapter konnte ich bisher problemfrei hinzufügen. Den Fehler verstehe ich in der Tiefe nicht wirklich.
      Hoffe mir kann jemand einen Tipp geben!
      Zu meinem IO Broker: Neuste Version auf einem Raspberry 4
      $ ./iobroker add roomba  --host raspberrypi
      NPM version: 6.11.3
      npm install iobroker.roomba@1.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.75-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1npm ERR! canvas@2.6.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-11-19T20_18_03_891Z-debug.log
      ERROR: host.SmartHome Cannot install iobroker.roomba@1.0.7: 1
      ERROR: process exited with code 25
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      foxriver76 1 Reply Last reply Reply Quote 0
      • foxriver76
        foxriver76 Developer @scr2k last edited by
        @scr2k Laut Doku:
        sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
        sudo npm install canvas --unsafe-perm=true
        Debian Pakete muessen aktuell leider manuell installiert werden. Steht allerdings auf der Agenda für den js-c.
        Canvas vermutlich manuell wegen unsafe-perm.
          Coffeelover last edited by Coffeelover
          habe die Installation für meinen Xiaomi versucht, bekomme aber bei den Libraries folgende Meldung:
          Abhängigkeitsbaum wird aufgebaut.
          Statusinformationen werden eingelesen.... Fertig
          E: Paket libcairo2-dev kann nicht gefunden werden.
          E: Paket libpango1.0-dev kann nicht gefunden werden.
          E: Mittels des Musters »libpango1.0-dev« konnte kein Paket gefunden werden.
          E: Mittels regulärem Ausdruck »libpango1.0-dev« konnte kein Paket gefunden werden.
          E: Paket libjpeg-dev kann nicht gefunden werden.
          E: Paket libgif-dev kann nicht gefunden werden.
          E: Paket librsvg2-dev kann nicht gefunden werden.
          Installation in einem QNAP Container / Docker.
          VG
          Edit: Gelöst durch ausführen von sudo apt update und dann sudo apt-get install [...]
          adapter error roomba adapter
