    4. Sonoff error in log
    SOLVED Sonoff error in log
      roland1000 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry pi4 .
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: RasbianBuster
      Node-Version: 10.17.0
      Nodejs-Version: 10.17.0
      NPM-Version: 6.11.3
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Hallo ioBroker-Gemeinde
      Ich habe folgendes Problem und zwar seit ich den Host-Js-Controller geupdatet auf 2.1.1 gibt der Sonoff-Adapter folgende fehler Meldungen raus:
      host.ioBroker
      2019-11-22 17:53:00.926
      error
      Caught by controller[0]: at DestroyableTransform.onreadable (/opt/iobroker/node_modules/duplexify/index.js:134:10)
      host.ioBroker
      error
      Caught by controller[0]: at Connection.Duplexify._forward (/opt/iobroker/node_modules/duplexify/index.js:170:26)
      host.ioBroker
      error
      Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_readable.js:245:10)
      host.ioBroker
      2019-11-22 17:53:00.925
      error
      Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_readable.js:278:11)
      host.ioBroker
      error
      Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_readable.js:291:12)
      host.ioBroker
      error
      Caught by controller[0]: at Connection.emit (events.js:198:13)
      host.ioBroker
      error
      Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
      host.ioBroker
      error
      host.ioBroker
      error
      Caught by controller[0]: at Connection.client.on.packet (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1558:21)
      host.ioBroker
      2019-11-22 17:53:00.924
      error
      Caught by controller[0]: at receivedTopic (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1067:30)
      host.ioBroker
      error
      Caught by controller[0]: TypeError: Cannot read property 'topic' of undefined
      sonoff.0
      2019-11-22 17:52:59.890
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      sonoff.0
      error
      (8323) TypeError: Cannot read property 'topic' of undefined
      sonoff.0
      2019-11-22 17:52:59.888
      error
      (8323) uncaught exception: Cannot read property 'topic' of undefined```
      Die Topic habe ich auch schon mal geändert Ein Neustart bringt keine Besserung .Es läuft zwar noch der MQTT-Adapter mit weil, ich vier ESP32 BT als Anwesendheitserkennung installiert habe. Die beiden Adapter laufen schon auf zwei unterschiedliche Port. Was kann das noch sein?
      Erstmal danke für eure Hilfe.
      LG
      Roland1000
        Moin
        Bitte Thema schliesen. Fehler gefunden .🙂
        LG Roland1000
        • Negalein
          Negalein Global Moderator @roland1000 last edited by
          @roland1000 sagte in Sonoff error in log:
          Und was war das Problem?
          ist für andere User eventuell auch interessant.
            Hallo Negalein
            War schwierig weil die Sonoff bzw Esp12f keinen Error gemacht haben .Zuletzt waren es die ersten S20 die haben das Firmware update nicht verstanden. Nach den flashen mit der Blank 1MB firmware .War es ein Kinderspiel. Ich habe die Hälfte der Esp12f nach und nach wieder online gestellt und gewartet ob fehler kamen . Bei den letzten viertel ⚡ kam die ersten Fehler. Danach war es ein Kinderspiel neue Firmware drauf und es lief wieder normal.
            Lg Roland
            sonoff-adapter error
