    4. Fehler bei SQL-Adapter
    SOLVED Fehler bei SQL-Adapter
    • Andre 0
      Andre 0 last edited by Andre 0
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry Pi 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspian Buster Lite
      Node-Version: 10.17.0
      Nodejs-Version: 10.17.0
      NPM-Version: 6.11.3
      Installationsart: Manuell
      ich bin mit meiner Installation auf den Raspberry Pi 4 umgezogen.
      Minimal Backup durchgeführt.
      Sobald ich den SQL-Adapter installiere kommen ohne Ende Fehlermeldungen.
      Auch wenn ich DANACH andere Adapter installieren möchte kommen diese Meldungen. Vor Installation des SQL-Adapters nicht!
      $ ./iobroker add sql  --host raspberrypi
      NPM version: 6.11.3npm install iobroker.sql@1.9.4 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../src/binding.cc:3:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      ../src/binding.cc: In static member function ‘static void Magic::DetectFile(const Nan::FunctionCallbackInfo<v8::Value>&)’:../src/binding.cc:184:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]                                  (uv_after_work_cb)Magic::DetectAfter);                                                           ^~~~~~~~~~~
      ../src/binding.cc: In static member function ‘static void Magic::Detect(const Nan::FunctionCallbackInfo<v8::Value>&)’:../src/binding.cc:217:59: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]                                  (uv_after_work_cb)Magic::DetectAfter);                                                           ^~~~~~~~~~~
      In file included from ../src/binding.cc:1:../src/binding.cc: At global scope:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/binding.cc:415:3: note: in expansion of macro ‘NODE_MODULE’   NODE_MODULE(magic, init);   ^~~~~~~~~~~
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63,                 from ../src/binding.cc:1:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../../nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
      Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘strftimeFunc’:
      Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:14137:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC   ((sqlite3_destructor_type)sqlite3MallocSize)                           ^Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:22052:52: note: in expansion of macro ‘SQLITE_DYNAMIC’                       z==zBuf ? SQLITE_TRANSIENT : SQLITE_DYNAMIC);                                                    ^~~~~~~~~~~~~~
      Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c: In function ‘sqlite3ErrorWithMsg’:
      Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:14137:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC   ((sqlite3_destructor_type)sqlite3MallocSize)                           ^Release/obj/gen/sqlite-autoconf-3280000/sqlite3.c:30393:54: note: in expansion of macro ‘SQLITE_DYNAMIC’     sqlite3ValueSetStr(db->pErr, -1, z, SQLITE_UTF8, SQLITE_DYNAMIC);                                                      ^~~~~~~~~~~~~~
      und so weiter.
      Später dann im Log folgendes:
      sql.0	2019-11-24 23:15:45.253	error	(17679) TypeError: Cannot read property 'borrow' of undefined
      sql.0	2019-11-24 23:15:45.252	error	(17679) Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
        arteck Developer Most Active @Andre 0 last edited by
        @Andre-0
        node -v
        nodejs -v
        asugabe posten bitte
        • Andre 0
          pi@raspberrypi:~ $ node -v
          v10.17.0
          pi@raspberrypi:~ $ nodejs -v
          v10.17.0
          • apollon77
            apollon77 last edited by
            Bitte vollständiges log Posten. „Und so weiter“ ist hier leider genau nicht hilfreich.
            Scheinbar wird SQLite nicht sauber installiert. Und ja, wenn das so ist dann versucht npm das danach bei jeder weiteren Installation von etwas anderem immer zu korrigieren weil npm immer den „gesamten Abhängigkeitsbaum“ anschaut und fixen will.
              heli last edited by
              ich hänge mich hier mal dran da mich das gleich Problem plagt. Frische Buster Installation auf einem neuen Raspi 4, aber jede Adapter-Installation oder Update dauert ewig lange und führt, am Beispiel der Telegram-Aktualisierung zu folgenden Log-Einträgen, hier nur ein kurzer Auszug da der Post sonst zu lang und daher nicht veröffentlicht wird.
              ⁃	2019-12-13 18:17:48.244 - info: host.raspi4 iobroker NPM version: 6.13.2npm install iobroker.telegram@1.4.6 --loglevel error --prefix "/opt/iobroker" (System call)
              	⁃	2019-12-13 18:18:22.703 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘strftimeFunc’:Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:22212:52: note: in expansion of macro ‘SQLITE_DYNAMIC’ z==zBuf ? SQLITE_TRANSIENT : SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:22.864 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘sqlite3ErrorWithMsg’:
              	⁃	2019-12-13 18:18:22.870 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:30555:54: note: in expansion of macro ‘SQLITE_DYNAMIC’ sqlite3ValueSetStr(db->pErr, -1, z, SQLITE_UTF8, SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:25.255 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘sqlite3VdbeMemSetStr’:
              	⁃	2019-12-13 18:18:25.266 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:75784:15: note: in expansion of macro ‘SQLITE_DYNAMIC’ if( xDel==SQLITE_DYNAMIC ){ ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:25.309 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘valueFromExpr’:
              	⁃	2019-12-13 18:18:25.320 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:76190:55: note: in expansion of macro ‘SQLITE_DYNAMIC’ sqlite3ValueSetStr(pVal, -1, zVal, SQLITE_UTF8, SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:25.361 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:76238:29: note: in expansion of macro ‘SQLITE_DYNAMIC’ 0, SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:27.819 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘sqlite3VdbeExec’:
              	⁃	2019-12-13 18:18:27.826 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:91559:38: warning: cast between incompatible function types from ‘int (*)(u32, void *, void *, void *)’ {aka ‘int (*)(unsigned int, void *, void *, void *)’} to ‘void (*)(void *, const char *)’ [-Wcast-function-type] void (*x)(void*,const char*) = (void(*)(void*,const char*))db->xTrace; ^
              	⁃	2019-12-13 18:18:33.279 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘printfFunc’:
              	⁃	2019-12-13 18:18:33.297 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:114219:25: note: in expansion of macro ‘SQLITE_DYNAMIC’ SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:36.362 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘generateColumnNames’:
              	⁃	2019-12-13 18:18:36.383 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:127513:58: note: in expansion of macro ‘SQLITE_DYNAMIC’ sqlite3VdbeSetColName(v, i, COLNAME_NAME, zName, SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:36.403 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:14234:27: warning: cast between incompatible function types from ‘int (*)(void *)’ to ‘void (*)(void *)’ [-Wcast-function-type] #define SQLITE_DYNAMIC ((sqlite3_destructor_type)sqlite3MallocSize) ^Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:127520:52: note: in expansion of macro ‘SQLITE_DYNAMIC’ sqlite3VdbeSetColName(v, i, COLNAME_NAME, z, SQLITE_DYNAMIC); ^~~~~~~~~~~~~~
              	⁃	2019-12-13 18:18:45.955 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘sqlite3InvokeBusyHandler’:
              	⁃	2019-12-13 18:18:45.967 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:157821:12: warning: cast between incompatible function types from ‘int (*)(void *, int)’ to ‘int (*)(void *, int, sqlite3_file *)’ {aka ‘int (*)(void *, int, struct sqlite3_file *)’} [-Wcast-function-type] xTra = (int(*)(void*,int,sqlite3_file*))p->xBusyHandler; ^
              	⁃	2019-12-13 18:18:45.969 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c: In function ‘sqlite3_busy_timeout’:
              	⁃	2019-12-13 18:18:45.980 - info: host.raspi4 iobroker Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c:157899:30: warning: cast between incompatible function types from ‘int (*)(void *, int, sqlite3_file *)’ {aka ‘int (*)(void *, int, struct sqlite3_file *)’} to ‘int (*)(void *, int)’ [-Wcast-function-type] sqlite3_busy_handler(db, (int(*)(void*,int))sqliteDefaultBusyCallback, ^
              Ausgabe von node -v und nodejs -v ergibt in beiden Fällen:
              pi@raspi4:~ $ node -v
              v10.15.2
              pi@raspi4:~ $ nodejs -v
              v10.15.2
              Hat zufällig jemand einen Tip oder eine Idee was ich unternehmen muss um den neuen Raspi von einer sauberen Arbeitsweise zu überzeugen? 😉
              Viele Grüße
              Norbert
              Homoran apollon77 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @heli last edited by
                @heli sagte in Fehler bei SQL-Adapter:
                pi@raspi4:~ $ node -v v10.15.2
                Wie kommst du an diese Version?
                https://github.com/nodejs/help/issues/1877
                Nach aktueller Installation müsstest du 10.17.0 haben.
                Die 10.15.2 deutet auf einen Fehler bei der node.js Installation
                aguilared created this issue in nodejs/help
                closed npm does not support Node.js v10.15.2 #1877
                  heli @Homoran last edited by
                  @Homoran said in Fehler bei SQL-Adapter:
                  10.17.0
                  Hm, keine Ahnung wie ich an die gekommen bin. Aber ich habe jetzt mal auf 10.17.0 geschubst und bin gespannt wie sich das System jetzt bei den nächsten Aktualisierungen verhält und melde mich dann wieder.
                  Danke schön!
                  Norbert
                    Bist du sicher?
                    nicht dass du jetzt zwei node.js Versionen parallel drauf hast
                      @Homoran
                      pi@raspi4:/opt/iobroker $ node -v
                      v10.17.0
                      pi@raspi4:/opt/iobroker $ nodejs -v
                      v10.17.0
                      Klingt doch gut, oder?
                        @heli ja, und npm -v?
                          heli last edited by Negalein
                          pi@raspi4:~ $ npm -v
                          6.13.4
                          pi@raspi4:~ $
                          • apollon77
                            apollon77 @heli last edited by
                            @heli ist das log vollständig??
                              heli @apollon77 last edited by
                              @apollon77 Nein, das vollständige Log passte hier nicht rein. Dann wurde die zulässige Postlänge überschritten.
                                heli last edited by
                                Ich habe noch einmal versucht nur den relevanten Teil des Logs hier reinzuschreiben, aber ich überschreite damit immer die maximal zulässige Zeichenzahl eines Posts.....max. 10000 Zeichen möglich. Das reicht bei weitem nicht um das Log hier darzustellen.
                                Ich traue mich derzeit nicht den Admin-Adaptaper upzudaten. 😉
                                • apollon77
                                  apollon77 @heli last edited by apollon77
                                  @heli attache es doch als file 😉
                                    @apollon77 Log.txt
                                    Ich war gerade dabei es zu erstellen. 😉
                                      heli @heli last edited by
                                      @heli said in Fehler bei SQL-Adapter:
                                      @apollon77 Log.txt
                                      Hier ist jetzt nur der relevante Teil (Update des Telegram-Adapters) dargestellt. Das war allerdings noch vor dem node-Versionswechsel!
                                        heli last edited by heli
                                        Guten Morgen,
                                        da heute wieder Updates anstanden (Backitup-Adapter) kann ich mitteilen dass das Problem leider noch nicht behoben ist. Auch nach dem node-Versionswechsel kommen immer noch die im oben angehängten Log zu sehenden Fehlermeldungen.
                                        Gibt es noch Ideen oder Lösungsansätze?
                                        Danke schön!
                                        • apollon77
                                          Naja irgendwie scheint SQLite bei dir nicht ordentlich gebaut zu werden und deswegen macht er es immer wieder.
                                          Schau mal in /opt/iobroker/node_modules/sqlite3 oder /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3 ( es sollte nur eins der beiden da sein)
                                          Und führe mal in dem Verzeichnis dann das Kommando „npm rebuild“ aus. Das volle log davon bitte posten.
                                            heli last edited by
                                            @apollon77 said in Fehler bei SQL-Adapter:
                                            Ich glaube wir kommen der Sache näher: ich habe keines der beiden Verzeichnisse in meiner Installation.....
                                            sql
                                            1955
