    4. Adapter Yahka macht Probleme nach Update
    UNSOLVED Adapter Yahka macht Probleme nach Update
      Realzippo last edited by Negalein
      Hallo.
      Ich habe "node" auf Version 10.17.0 aktualisiert.
      Alle Adapter bis auf den Yahka laufen wieder.
      Der Yahka Adapter wird grün angezeigt, schreibt jedoch folgende Fehler:
      host.raspberrypi	2019-11-30 09:22:45.729	error	instance system.adapter.yahka.0 terminated with code 1 ()
      host.raspberrypi	2019-11-30 09:22:45.729	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.raspberrypi	2019-11-30 09:22:45.729	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      host.raspberrypi	2019-11-30 09:22:45.728	error	Caught by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
      host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node'
      host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: ^
      host.raspberrypi	2019-11-30 09:22:45.727	error	Caught by controller[0]: throw ex;
      host.raspberrypi	2019-11-30 09:22:45.724	error	Caught by controller[0]: /opt/iobroker/node_modules/mdns/lib/dns_sd.js:35
      Was kann ich tun?
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      • Asgothian
        Asgothian Developer @Realzippo last edited by
        @Realzippo sagte in Adapter Yahka macht Probleme nach Update:
        (for instance, using npm rebuild or npm install).
        Steht da doch.
        Einmal Google wie man das nutzt, eingeben, glücklich sein.
        Auf die konsole im iobroker, im Verzeichnis / opt/iobroker den Befehl npm rebuild ausführen.
        A.
          Leider hat npm rebuild das Problem nicht behoben.
          • Asgothian
            @Realzippo
            Dann empfehle ich den yahka Adapter einmal zu deinstallieren und neu zu installieren. Deine Einstellungen bleiben erhalten, es werden nur alle benötigten Pakete neu übersetzt.
            A.
              bjoernson @Asgothian last edited by
              @asgothian said in Adapter Yahka macht Probleme nach Update:
              Nur als Info für alle, die auf diesen Thread stoßen. Nach einer De- und Neuinstallation von Yahka sind alle Geräte und Einstellungen gelöscht. Besser ein Backup vorher erstellen.
              yahka
