    4. Probleme mit ZWave 1.7.2
    SOLVED Probleme mit ZWave 1.7.2
      LaplaceII last edited by Negalein
      Hallo, ich habe auf iobroker.zwave auf Version 1.7.2 gebracht (Rock64, JS Controller 2.1.1, npm 6.11.3, node.js 10.17.0). Leider bekomme ich kein grünes Licht bei den Instanzen (sudo ldconfig mehrfach ausgeführt, System mehrfach neu gestartet, auch alte Versionen funktionieren leider nicht mehr). Folgende Meldung erscheint im Log:
      host.rock64	2019-12-01 22:27:39.662	info	instance system.adapter.zwave.0 terminated with code 0 (NO_ERROR)
      host.rock64	2019-12-01 22:27:39.661	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3) code: 'MODULE_NOT_FOUND' }
      host.rock64	2019-12-01 22:27:39.661	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.rock64	2019-12-01 22:27:39.660	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.rock64	2019-12-01 22:27:39.660	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.rock64	2019-12-01 22:27:39.659	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.rock64	2019-12-01 22:27:39.659	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19)
      host.rock64	2019-12-01 22:27:39.658	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.rock64	2019-12-01 22:27:39.658	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.rock64	2019-12-01 22:27:39.658	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
      host.rock64	2019-12-01 22:27:39.657	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
      host.rock64	2019-12-01 22:27:39.656	error	Caught by controller[0]: { Error: Cannot find module '/opt/iobroker/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
      zwave.0	2019-12-01 22:27:39.097	info	(6810) Terminated (NO_ERROR): Without reason
      zwave.0	2019-12-01 22:27:39.094	info	(6810) terminating
      zwave.0	2019-12-01 22:27:38.967	error	(6810) Error: Cannot find module '/opt/iobroker/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15
      zwave.0	2019-12-01 22:27:38.964	error	(6810) uncaught exception: Cannot find module '/opt/iobroker/node_modules/openzwave-shared/lib/../build/Release/openzwave_shared.node'
      zwave.0	2019-12-01 22:27:33.317	info	(6810) starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.17.0
      host.rock64	2019-12-01 22:27:30.068	info	instance system.adapter.zwave.0 started with pid 6810
      Hat jemand eine Idee, bevor ich das System neu aufsetze? Backup hat leider auch nicht funktioniert...
        arteck Developer Most Active @LaplaceII last edited by arteck
        @LaplaceII da wurde das openzwave nicht kompiliert.. hast du was abgebrochen bei der installation .. das kann so 20 min dauern bis der rock damit fertig ist
        ansonsten mach mal
        cd /opt/iobroker/node_modules/openzwave-shared
        make
        make install
        ldconfig
        und schau dir die Ausgaben von den Befehlen an .. nicht einfach stupide diese Ausführen
          Hallo, leider noch keine Besserung eingetreten, selbst die Neuinstallation des Systems hat nichts gebracht. Wäre um jede Hilfe dankbar!
            ansonsten mach mal
            make
            make install
            ldconfig
              Danke, ich probiere es nochmal aus....wahrscheinlich war ich zu ungeduldig 😬
                Jetzt hat es funktioniert, danke!
                zwave
