Test Adapter ioBroker.backitup v3.1.x
@simatec Danke. Ich gehe mal auf die Suche. Wenn ich die Einstellungen gefunden habe, geb ich nochmal bescheid.
@homoran sagte in Test Adapter ioBroker.backitup v2.8.x:
@simatec sagte in Test Adapter ioBroker.backitup v2.8.x:
und den Debug-Log des letzten Backups
hab ich nicht, willst du morgen den von dieser Nacht
hier wie versprochen
2023-10-14 02:40:10.009 - debug: backitup.0 (28505) The local storage check was completed successfully. On the host "VM03" are currently 188277 MB free space available! 2023-10-14 02:40:10.021 - debug: backitup.0 (28505) Backup has started ... 2023-10-14 02:40:10.899 - debug: backitup.0 (28505) [iobroker/iobroker] host.VM03 105 states saved 2023-10-14 02:40:10.907 - debug: backitup.0 (28505) [iobroker/iobroker] host.VM03 144 objects saved 2023-10-14 02:40:11.373 - debug: backitup.0 (28505) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_14-02_40_10_backupiobroker.tar.gz 2023-10-14 02:40:11.374 - debug: backitup.0 (28505) [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1 2023-10-14 02:40:12.386 - debug: backitup.0 (28505) [iobroker/iobroker] done 2023-10-14 02:40:14.940 - debug: backitup.0 (28505) [iobroker/cifs] used copy path: /media/usbstick/backups 2023-10-14 02:40:14.941 - debug: backitup.0 (28505) [iobroker/cifs] Copy iobroker_2023_10_14-02_40_10_backupiobroker.tar.gz... 2023-10-14 02:40:14.949 - debug: backitup.0 (28505) [iobroker/cifs] done 2023-10-14 02:40:15.551 - debug: backitup.0 (28505) [iobroker/clean] done 2023-10-14 02:40:16.760 - debug: backitup.0 (28505) [iobroker/historyHTML] new history html values created 2023-10-14 02:40:16.847 - debug: backitup.0 (28505) [iobroker/historyHTML] done 2023-10-14 02:40:17.000 - debug: backitup.0 (28505) [iobroker/historyJSON] new history json values created 2023-10-14 02:40:17.000 - debug: backitup.0 (28505) [iobroker/historyJSON] done 2023-10-14 02:40:17.302 - debug: backitup.0 (28505) [iobroker] exec: done 2023-10-14 09:14:37.251 - debug: backitup.0 (28505) The local storage check was completed successfully. On the host "VM03" are currently 188303 MB free space available! 2023-10-14 09:14:39.890 - debug: backitup.0 (28505) Backup list cannot be read ... 2023-10-14 09:14:39.891 - debug: backitup.0 (28505) Backup list cannot be read ... 2023-10-14 09:15:11.300 - debug: backitup.0 (28505) Backup list cannot be read ... 2023-10-14 09:15:11.301 - debug: backitup.0 (28505) Backup list cannot be read ...
diese Nacht wurde vermutlich durch den Neustart wieder ein Backup geschrieben aber nichts gelöscht
Backitup v2.8.2
@homoran Gut das sieht etwas komisch aus. Zeige mal bitte die Config alss JSON
@homoran so wie ich es in deiner Config sehe, werden 15 iobroker Backups aufbewahrt.
Des Weiteren ist löschen des USB Sticks nicht aktiviert, so dass nur lokal gelöscht wird. -
@simatec danke! das sehe ich mir an.
du baust einfach zu viele Optionen einden letzten hatte ich vor Ewigkeiten aufgesetzt.
edit
habs gefunden und geändert.
werde es beobachten. -
@homoran ich bin unschuldig… die User wollen die Optionen
@thomas-braun sagte in Test Adapter ioBroker.backitup v2.8.x:
@ichderarnd sagte in Test Adapter ioBroker.backitup v2.8.x:
Nach welcher Anleitung sollte ich vorgehen?
Ich hab mir seinerzeit meine eigene Anleitung geschrieben. Schau durch meine Themen durch.
Ich habe das Update von buster auf bullseye gestern nach Deiner Anleitung durchgeführt. Habe dann ein paar Stunden gebraucht, bis ioBroker und piVCCU3 wieder liefen.
Problem 1 war eth0, dass trotz manueller IP immer wieder eine Auto IP Adresse bekam wodurch das Default-Routing nicht mehr klappte. Erst als ich connman deinstalliert hatte, war dann endlich Ruhe. Problem 2 war piVCCU3. Diesen musste ich schließlich neu installieren. Der war mehr oder weniger komplett weggeflogen.Die Fehler in "iob diag" sind geblieben. Auch der icmp Fehler. Ich habe das Modul in /opt/iobroker/node_modules/icmp mal neu gebaut/installiert, aber ohne Erfolg. dann fiel mir auf, dass es der Javascript-Adapter wohl aus /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-socket zieht. Mir ist aber nicht klar, wie ich es dort aktualisieren kann.
Und der tr-064 Adapter (V4.2.18) gibt mir auch den "Cannot start callmonitor: Error: connect ECONNREFUSED 192.168.200.1:1012". Vielleicht hat sich da mit der neuen Fritz OS Version 7.57 was geändert?
Da das Thema hier OT ist: In welchen Faden passt das besser?
connman
GUI Tool. Hat auf der Kiste eh nix verloren.
Ein Daemon. Er klebt nach ca. 30 Sekunden einfach eine Auto IP an eth0. Ob der vor dem Update drauf war glaube ich nicht, denn da gab es das Problem nicht. Oder er war unter buster nicht so aggressiv. Installiert habe ich den sicher nicht…
@ichderarnd Bitte mache dazu einen separaten Thread auf... Hier geht es um Backitup Berichte
@simatec
ich wollte heute meinen iobroker auf Node.js 18 bzw. NPM 9.8 aktualisieren und habe daher ein Backup der bisherigen iobroker Installation (Docker mit Node.js 16 und Backup 2.8.4) gemacht. Das Backup liegt auf dem FTP-Server. Danach ein komplett neues Docker-Image (9.0.1) geladen und wollte das Backup vom FTP wiederherstellen. Ich kann das Backup auch auswählen, jedoch kommt als letzte Info "Restore startet" und danach kann der Browser nicht auf IP:8091 zugreifen. Habe dies mit Chrome und FireFox getestet. Im Log gibt es lediglich diese Infos:backitup.0 2023-10-29 15:16:49.676 debug FTP: connected. backitup.0 2023-10-29 15:16:49.617 debug Backup list be read ...
Dann passiert nichts mehr. Irgend eine Idee, was ich tun kann?
@somansch Nimm die aktuelle latest Version von Backitup. Im Docker Image gab es Änderungen, die in v2.8.7 angepasst wurden
@simatec
was soll ich sagen, wie immer ein perfekter Support hier im ForumDANKE
ich kann derzeit mit der 2.8.7 keine Backups meiner InfluxDB 2.7 Instanz (beide laufen in Docker Containern) erstellen. Die entsprechende Checkbox im BackItUp ist ausgegraut. Dies hat früher funktioniert.
So ganz falsch kann meine Influx / IOBroker Konfiguration nicht aufgesetzt sein, denn von Hand kann ich aus dem Influx Container heraus ein remote Backup machen:
influx backup --org xyz --host http://192.168.0.4:8086 --token abc "/opt/iobroker/backups/testflux/"
funktioniert und läuft ohne Fehler durch. Das wäre meinem Verständnis nach das, was BackItUp auch aufrufen würde.Auch die entsprechenden Environments für den IOBroker Container habe ich gesetzt:
- IOB_BACKITUP_EXTDB = true
- PACKAGES = influxdb2-cliDas Problem ist wie folgt aufgetaucht:
Ich habe heute morgen bemerkt, dass ich nach der Umstellung von InfluxDB 1.8 auf 2.7 vor ein paar Monaten im Influx Adapter von IOBroker noch die Version 1.x eingetragen hatte. Das hat monatelang keine offensichtlichen Probleme bereitet, aber seit ein paar Tagen gab es beim Schreiben einiger Werte in die Datenbank Fehlermeldungen. Den Eintrag im Influx Adapter habe ich heute morgen korrigiert, damit sind auch die Fehlermeldungen verschwunden.
Leider ist damit aber auch der Influx Reiter im BackItUp Adapter verschwunden (der war gestern noch da. Die Influx Backups gingen ja auch früher).Da die Backups von Hand funktionieren, hat jemand eine Idee, wie den entsprechenden Reiter im BackItUp wieder sichtbar machen kann?
@hansjochen sagte in Test Adapter ioBroker.backitup v2.8.x:
Zeig mal bitte das Docker Log, was beim Start des ioBroker geschrieben wird. Da kann man gut sehen, welche Umgebungsvariablen effektiv im Container ankommen.
Ich kann mir beim besten Willen nicht vorstellen, wie das funktioniert haben soll. Wenn der Adapter auf 1.x eingestellt ist, kannst du keine Organisation und Token eingeben. Ohne diese Infos kann der Adapter aber unmöglich eine Verbindung zu einer 2.x DB aufgebaut haben.
Was für Fehlermeldungen erschienen da?Und zeig mal bitte noch die Adapter-Einstellungen.
Hallo @marc-berg ,
danke für Deine Unterstützung.
Aktuell läuft Influx sauber in IOBroker. Hier der Auszug aus dem Start Log:
2023-11-05 11:01:46.458 - [32minfo[39m: host.iobroker instance system.adapter.influxdb.0 started with pid 18879 2023-11-05 11:01:47.807 - [32minfo[39m: influxdb.0 (18879) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v16.20.2, js-controller: 5.0.12 2023-11-05 11:01:47.831 - [32minfo[39m: influxdb.0 (18879) No stored data from last exit found 2023-11-05 11:01:47.833 - [32minfo[39m: influxdb.0 (18879) Connecting http://192.168.0.4:8086/ ... 2023-11-05 11:01:47.833 - [32minfo[39m: influxdb.0 (18879) Influx DB Version used: 2.x 2023-11-05 11:01:47.875 - [32minfo[39m: influxdb.0 (18879) Applying retention policy for iobroker to 31536000 seconds. Shard Group Duration (calculated): 604800 seconds 2023-11-05 11:01:47.921 - [32minfo[39m: influxdb.0 (18879) Connected!
Ich visualisiere ja auch eine ganze Menge Werte über Grafana und das sieht alles sauber aus. Meine Adapter Konfiguration ist diese
Zur Historie: Nach dem Update meines Containers hatte ich vermutlich vergessen, den Eintrag in der Adapter Konfiguration zu ändern. Mich hat ja auch gewundert, dass das trotzdem problemlos lief. Organisation und Token hatte ich im IOBroker InfluxDB Adapter auch erst nach der Umstellung heute morgen eingegeben. Davor konnte ich aber offenbar über die alten 1.8 Verbindungsdaten immer noch Werte in die Datenbank schreiben. Meine Charts in Grafana funktionieren nahtlos seit Jahren über die Umstellung von heute morgen hinweg.
Im Docker Log sehe ich keine Umgebungsvariablen. Hier der Auszug, den ich über
sudo docker logs iobroker 2&>1 meinDocker.log
erstellt habe vom Start gestern morgen.
(Die Umgebungsvariablen hatte ich schon vor Monaten gesetzt. BackItUp hatte früher damit auch funktioniert. Jetzt kann ich nicht neu starten, sonst geht die Heizung aus).
-------------------------------------------------------------------------------- ------------------------- 2023-11-04 07:57:33 ------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- ----- Welcome to your ioBroker-container! ----- ----- Startupscript is now running. ----- ----- Please be patient! ----- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- ----- Debugging information ----- ----- ----- ----- System ----- ----- arch: x86_64 ----- ----- hostname: iobroker ----- ----- ----- ----- Docker-Image ----- ----- image: v7.0.1 ----- ----- build: 2022-07-05T18:51:52+00:00 ----- ----- ----- ----- Versions ----- ----- node: v16.20.1 ----- ----- npm: 8.19.4 ----- ----- ----- ----- ENV ----- ----- SETGID: 1000 ----- ----- SETUID: 1000 ----- ----- USBDEVICES: /dev/ttyACM0 ----- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- ----- Step 1 of 5: Preparing container ----- -------------------------------------------------------------------------------- This is not the first run of this container. Skipping first run preparation. Installing additional packages is set by ENV. Checking the following Packages: ... Reading package lists... Building dependency tree... Reading state information... Reading package lists... Building dependency tree... Reading state information... 0 upgraded, 0 newly installed, 0 to remove and 45 not upgraded. Done. -------------------------------------------------------------------------------- ----- Step 2 of 5: Detecting ioBroker installation ----- -------------------------------------------------------------------------------- Existing installation of ioBroker detected in /opt/iobroker. -------------------------------------------------------------------------------- ----- Step 3 of 5: Checking ioBroker installation ----- -------------------------------------------------------------------------------- (Re)Setting folder permissions (This might take a while! Please be patient!)... Done. Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done. -------------------------------------------------------------------------------- ----- Step 4 of 5: Applying special settings ----- -------------------------------------------------------------------------------- Some adapters have special requirements/ settings which can be activated by the use of environment variables. For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/). Usb-device-support is activated by ENV. Setting permissions for /dev/ttyACM0... Done. Userscript for every start detected. Running userscript_everystart.sh... The plugin "sentry" was successfully disabled for host "iobroker". Done. -------------------------------------------------------------------------------- ----- Step 5 of 5: ioBroker startup ----- -------------------------------------------------------------------------------- Starting ioBroker... ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting] ================================== > LOG REDIRECT system.adapter.jarvis.0 => true [starting] host.iobroker check instance "system.adapter.admin.0" for host "iobroker" host.iobroker check instance "system.adapter.email.0" for host "iobroker" host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker" host.iobroker check instance "system.adapter.javascript.0" for host "iobroker" host.iobroker check instance "system.adapter.fritzbox.0" for host "iobroker" host.iobroker check instance "system.adapter.ical.0" for host "iobroker" host.iobroker check instance "system.adapter.ical.1" for host "iobroker" host.iobroker check instance "system.adapter.modbus.0" for host "iobroker" host.iobroker check instance "system.adapter.mqtt-client.0" for host "iobroker" host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker" host.iobroker check instance "system.adapter.mqtt.1" for host "iobroker" host.iobroker check instance "system.adapter.mqtt.2" for host "iobroker" host.iobroker check instance "system.adapter.shelly.0" for host "iobroker" host.iobroker check instance "system.adapter.tvspielfilm.0" for host "iobroker" host.iobroker check instance "system.adapter.zigbee.0" for host "iobroker" host.iobroker check instance "system.adapter.modbus.1" for host "iobroker" host.iobroker check instance "system.adapter.melcloud.0" for host "iobroker" host.iobroker check instance "system.adapter.discovery.0" for host "iobroker" host.iobroker check instance "system.adapter.backitup.0" for host "iobroker" host.iobroker check instance "system.adapter.awattar.0" for host "iobroker" host.iobroker check instance "system.adapter.daswetter.0" for host "iobroker" host.iobroker check instance "system.adapter.dwd.0" for host "iobroker" host.iobroker check instance "system.adapter.exchangerates.0" for host "iobroker" host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker" host.iobroker check instance "system.adapter.fritzdect.0" for host "iobroker" host.iobroker check instance "system.adapter.fullcalendar.0" for host "iobroker" host.iobroker check instance "system.adapter.heizoel.0" for host "iobroker" host.iobroker check instance "system.adapter.homeconnect.0" for host "iobroker" host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker" host.iobroker check instance "system.adapter.klf200.0" for host "iobroker" host.iobroker check instance "system.adapter.openligadb.0" for host "iobroker" host.iobroker check instance "system.adapter.parser.0" for host "iobroker" host.iobroker check instance "system.adapter.sayit.0" for host "iobroker" host.iobroker check instance "system.adapter.schoolfree.0" for host "iobroker" host.iobroker check instance "system.adapter.senec.0" for host "iobroker" host.iobroker check instance "system.adapter.solaredge.0" for host "iobroker" host.iobroker check instance "system.adapter.tankerkoenig.0" for host "iobroker" host.iobroker check instance "system.adapter.tibberconnect.0" for host "iobroker" host.iobroker check instance "system.adapter.trashschedule.0" for host "iobroker" host.iobroker check instance "system.adapter.tvprogram.0" for host "iobroker" host.iobroker check instance "system.adapter.vis.0" for host "iobroker" host.iobroker check instance "system.adapter.web.0" for host "iobroker" host.iobroker check instance "system.adapter.webuntis.0" for host "iobroker" host.iobroker check instance "system.adapter.bluelink.0" for host "iobroker" host.iobroker check instance "system.adapter.renault.0" for host "iobroker" host.iobroker check instance "system.adapter.tibberlink.0" for host "iobroker" host.iobroker check instance "system.adapter.device-reminder.0" for host "iobroker" ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging] ================================== > LOG REDIRECT system.adapter.jarvis.0 => true [system.adapter.jarvis.0.logging]
Seit 3 Tagen hatte ich bei den nächtlichen Backups diese Fehlermeldung bekommen:
BackItUp: Your backup was not completely created. Please check the errors!! influxDB: Error: Command failed: influxd backup -portable -database iobroker/autogen -host 192.168.0.4:8086 "/opt/iobroker/backups/influxDB_2023_11_04-02_40_19_backupiobroker" 2023/11/04 02:40:19 Invalid metadata blob, ensure the metadata service is running (default port 8088) backup: invalid metadata received cifs: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/influxDB_2023_11_04-02_40_19_backupiobroker.tar.gz'
Ich habe das darauf zurück geführt, dass auch im Backup Adapter noch die Influx 1.8 eingetragen war. Manuell ging dieses Kommando natürlich auch nicht, aber jetzt kann ich manuell ja wieder Backups durchführen.
@hansjochen Wenn du die InfluxDB 2.x nutzt, musst du dies auch in Backitup so konfigurieren.
Benutzerdaten, token etc. werden benötigt -
Darum geht es mir doch: Ich kann nicht, weil seit heute morgen das Tab ausgegraut ist:
Zuvor hatte ich es heute morgen noch gesehen.
Ich kann mir immer noch kein Szenario vorstellen, wie das funktionieren sollte, aber egal.
Dein Ursprungsproblem liegt darin begründet, dass die Umgebungsvariable "IOB_BACKITUP_EXTDB" nicht im Container ankommt. Wie setzt du diese und wie sieht deine Umgebung aus?
EDIT: Außerdem könnte dein Container mal ein Update vertragen.
