Test Adapter ioBroker.backitup v3.1.x
@PatrickFro
Deine Tabelle ist nicht korrekt aufgebaut. Die Eintragungen passen nicht zu den Überschriften.
Ansonsten zu deinem Problem bitte den Adapter in den Instanzen auf debug schalten und den Log posten -
@PatrickFro
Nein der Log sieht gut aus ... Was steht in dem Datenpunkt "json"? -
[{"date":"11. Maerz 2020 um 12:38 Uhr","name":"iobroker_2020_03_11-12_37_48_Iobroker-Backup_backupiobroker.tar.gz","type":"iobroker","storage":"Google Drive: Ja","filesize":"16MB","error":"none"},{"date":"11. Maerz 2020 um 11:56 Uhr","name":"iobroker_2020_03_11-11_55_35_Iobroker-Backup_backupiobroker.tar.gz","type":"iobroker","storage":"Google Drive: Ja","filesize":"16MB","error":"none"}]
Und obwohl da "none" steht:
@PatrickFro
Was gibt der Datenpunkt "backitup.0.output.line" aus? -
[DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Iobroker-Backup","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"iobroker-data"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"3","systemLang":"de","time":"11. Maerz 2020 um 13:11 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
@PatrickFro OK ... history wird nicht beendet ...
Diese Problem hatten bereits 1-2 User gehabt. Hier schein irgendwas nicht sauber kompiliert zu sein und bei irgendeinem Update ein Problem aufgetreten zu sein.Abhilfe kannst du wie folgt schaffen:
- Instanz von backitup.0 löschen
- Adapter backitup löschen
- wenn vorhanden den Ordner backitup.0 in den Objekten löschen
- iobroker stoppen
- Installer Fix laufen lassen
- iobroker starten
- backitup installieren und konfigurieren
@simatec Vielen Dank, teste ich morgen. Stimmt dann ggf. auch meine Tabelle in VIS? Oder wie kann ich die Tabelle passend zu den Überschriften abfragen? So viel hab ich noch nicht mit JSON gemacht...
@simatec Bei dem ersten Durchlauf kam auch ein Fehler:
Gestartet... [DEBUG] [iobroker] - host.raspberrypi 15396 states saved [DEBUG] [iobroker] - host.raspberrypi 13306 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_03_11-15_32_04_backupiobroker.tar.gz [DEBUG] [iobroker] - done [ERROR] [historyDB] - [IGNORED] No source for compress! [DEBUG] [googledrive] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [history] - backitup.0.history.html [DEBUG] [history] - backitup.0.history.json [EXIT] 0
Allerdings (noch ohne GoogleDrive:
Mit GoogleDrive:
Gestartet... [DEBUG] [iobroker] - host.raspberrypi 15396 states saved [DEBUG] [iobroker] - host.raspberrypi 13306 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_03_11-15_44_05_backupiobroker.tar.gz [DEBUG] [iobroker] - done [ERROR] [historyDB] - [IGNORED] No source for compress! [DEBUG] [googledrive] - Copy iobroker_2020_03_11-15_44_05_backupiobroker.tar.gz... [ERROR] [googledrive] - File "/opt/iobroker/backups/historyDB_2020_03_11-15_44_57_backupiobroker.tar.gz" not found [DEBUG] [googledrive] - done [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors. [DEBUG] [clean] - done [DEBUG] [history] - backitup.0.history.html [DEBUG] [history] - backitup.0.history.json [EXIT] 0``` code_text
Bedeutet doch, dass nur die History-DB den aktuellen Fehler ausgelöst hat, richtig?
@PatrickFro history und history DB ist etwas anders.
Wenn du keinen history Adapter nutzt, schalte das history Backup ab.History hat den Fehler nicht verursacht, sondern irgend ein Fehler unter node
Vielen Dank. Hab heute schon 15 Backups gemacht da ich mich freue, dass es klappt
ich hatte gestern ein seltsames Problem. Scheinbar gab es einen Stromausfall und danach waren sehr viele States nicht mehr gefüllt und ich musste einiges an Konfiguration nachziehen. An Backupitup habe ich in dem Moment natürlich nicht gedacht. In dem Backup habe ich jetzt im Nachgang aber auch keine states.json gefunden. Ist das richtig so, habe ich ein Problem, oder sehe ich die Datei einfach nicht im Backup?
Habe die Version 1.4.1 im Einsatz. -
Ich spiele gerade mit dem Gedanken von einem Nuc zu einer Synology (1019+) zu ziehen und habe bereits entsprechende Docker Umgebung laufen inkl. ioBroker. Nun würde ich gern per Backitup auf den Docker Container ziehen. Ein Container hat kein SSH also kein WinSCP, kein Putty.
ioBroker NUC: Backup mit Backitup erstellt, an Dropbox übergeben
ioBrocker Docker: neu installiert, Backitup Adapter installiert, Dropbox verbunden. Findet auch das Backup vom NUC aber installiert es nicht. Also opt/iobroker ausgelagert und gemountet, dort in den Backups Ordner das Backup per Filestation hochgeladen.
Backitup findet das Archiv, installiert auch iwas bzw. rödelt vor sich hin. Ergebnis ist dann wieder eine leere Installation. Bleibt dann hier hängen bzw. geht nicht darüber hinaus. Manchmal öffnet sich auch ein neuer BrowserTab mit :8091. Dieser Seite hat dann keinen Inhalt.Woran kann es liegen?
Oder kennt sich sonst jemand auch mit Docker aus? Vielleicht ist da die Lösung zu suchen
Schon mal Danke.
@Gerni
Da sollten die Docker Experten etwas zu sagen.
Grundsätzlich halte ich es aber für die sicherste Restore Methode, das Backup lokal abzulegen, und dann daraus den restore auszuführen. -
Guten Tag,
der automatische Backup funktioniert bei mir über das integrierte NAS der FRITZ!Box, das Ganze ist nur 1,9mb groß, dauert dementsprechend auch nicht lange. Version 1.4.1
Jedoch bekomme ich keine Benachrichtigung per Telegram oder E-Mail. (Telegram funktioniert z.B über CPU Temperatur Warnung) Der Adapter ist auch die ganze Zeit am "laden" obwohl gar nichts mehr geschrieben wird. Also da steht oben "Backitup-Ausführung" und die ganze Zeit (über 10 Minuten etc.) lädt da der Ladebalken, es passiert aber nichts und das Backup ist schon längst fertig (braucht keine 30 Sekunden) Also es beendet sich nicht von alleine obwohl "Schließen wenn fertig" markiert ist, somit kommt wohl anscheinend auch keine Benachrichtigung.
Log:
[DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"XXX","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XXX","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"fritz.nas/USBStick/ioBrokerBackup","dirMinimal":"sharename/backupDir","user":"ioBrokerBackup","pass":"****"} [DEBUG] [mount] - done [DEBUG] [iobroker] start with {"type":"creator","time":"06:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs": Langer Text mit Daten (da steht die macAD usw. deswegen keine copy) [DEBUG] [iobroker] - host.raspberrypi-iob 2125 states saved [DEBUG] [iobroker] - host.raspberrypi-iob 2529 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_03_19-16_10_07_backupiobroker.tar.gz [DEBUG] [iobroker] - done [DEBUG] [mysql] - done [DEBUG] [mysql] - MySql File deleted! [DEBUG] [historyDB] - done
/edit:
"Zigbee Datenbank sichern" deaktivieren, dann gehts... ^^ Redis ebenso (gibt ne Fehlermeldung, aber Benachrichtigung geht und Fenster schließt sich) History, MYSQL (Datenbank vorhanden) und IoBroker/NAS an.
Ab sofort ist die Version 1.4.3 im Github und ab spätestens heute Nacht auch in der latest und stable Repo.
Changelog
1.4.3 (21.03.2020)
- (simatec) Fix for autochecker
- (simatec) Fix start after restore
- (simatec) update dependencies
@simatec
Guten Morgen, ich hab vorhin IOBroker neu installiert und ein Restore gestartet.
Sieht so schlecht nicht bei mir aus, aber perfekt auch noch nicht.Ich weiß nicht ob es an mir oder am Adapter liegt. Daher bitte die Frage ohne Wertung.
IOT wird nicht grün
iot.0 2020-03-22 04:16:02.829 error (4016) Cannot read keys: "error:0909006C:PEM routines:get_name:no start line" / Error: error:0909006C:PEM routines:get_name:no start line
Shelly meckert
shelly.0 2020-03-22 04:19:33.328 error (3630) Wrong http username or http password! Please enter the user credential from restricted login for 192.168.178.67 (shelly1 / sh ......
Kann sein dass das alles normal ist, frage ja nur mal.
Ich dachte Zugangsdaten etc. werden immer mit gesichert. -
@skokarl
Das ist zu Adapter spezifisch. Bitte frage da bei den jeweiligen Entwicklern nach -
wo finde ich in einer gespeicherten Backup Datei die Javascripte?
