Test Adapter ioBroker.backitup v3.1.x
@simatec HURRA !!!!
Du bist Klasse - es funktioniert.
2020-09-07 16:41:01.838 - info: backitup.0 (16113) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6 2020-09-07 16:41:01.892 - info: backitup.0 (16113) [iobroker] backup was activated at 16:42 every 1 day(s) 2020-09-07 16:41:01.907 - debug: backitup.0 (16113) No backup file was found 2020-09-07 16:42:10.195 - debug: backitup.0 (16113) Backup has started ... 2020-09-07 16:42:13.032 - debug: backitup.0 (16113) [iobroker/iobroker] host.MWHome 3657 states saved 2020-09-07 16:42:13.078 - debug: backitup.0 (16113) [iobroker/iobroker] host.MWHome 3310 objects saved 2020-09-07 16:45:17.393 - debug: backitup.0 (16113) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_07-16_42_10_backupiobroker.tar.gz 2020-09-07 16:45:18.422 - debug: backitup.0 (16113) [iobroker/iobroker] done 2020-09-07 16:45:18.649 - debug: backitup.0 (16113) [iobroker/mysql] MySql File deleted! 2020-09-07 16:45:18.651 - debug: backitup.0 (16113) [iobroker/mysql] done 2020-09-07 16:45:18.658 - debug: backitup.0 (16113) [iobroker/zigbee] found zigbee database: zigbee.0 2020-09-07 16:45:18.659 - debug: backitup.0 (16113) [iobroker/zigbee] done 2020-09-07 16:45:18.670 - debug: backitup.0 (16113) [iobroker/clean] done 2020-09-07 16:45:18.689 - debug: backitup.0 (16113) [iobroker] exec: done 2020-09-07 16:45:18.699 - debug: backitup.0 (16113) [iobroker/history] backitup.0.history.html 2020-09-07 16:45:18.700 - debug: backitup.0 (16113) [iobroker] exec: done 2020-09-07 16:45:18.711 - debug: backitup.0 (16113) [iobroker/history] backitup.0.history.json 2020-09-07 16:45:18.714 - debug: backitup.0 (16113) [iobroker] exec: done 2020-09-07 16:45:18.973 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_04-00_55_45_backupiobroker.tar.gz 2020-09-07 16:45:18.980 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_09_04-00_59_09_backupiobroker.tar.gz 2020-09-07 16:45:18.986 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_09_04-00_59_11_backupiobroker.tar.gz 2020-09-07 16:45:18.989 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_09_04-00_54_55_backupiobroker.tar.gz 2020-09-07 16:45:18.994 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_09_03-02_03_24_backupiobroker.tar.gz 2020-09-07 16:45:18.997 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_09_02-02_03_44_backupiobroker.tar.gz 2020-09-07 16:45:19.000 - debug: backitup.0 (16113) [iobroker/clean] delete /opt/iobroker/backups/zigbee.0_2020_09_01-02_03_34_backupiobroker.tar.gz
Das exec:done und clean:done kommt jetzt wohl vorher !!! - aber das wars! - deswegen habe ich noch gewartet, ob da noch was kommt.
Ab sofort steht die Version 1.6.6 auf Github und in Kürze auch im latest bereit ...
Changelog
1.6.6 (08.09.2020)
- (simatec) Bugfix clean local backups
- (simatec) Bugfix mount and umount for sentry.io
Musste heute nach langer Zeit mal wieder ein Restore fahren - dabei ist mir aufgefallen, das von den "Aufzählungen" die Funktionen nicht gesichert waren. Die Räume ja, die Funktionen nicht.
Ist das nicht Bestandteil von BackItup?
@JB_Sullivan
Da Backitup die iobroker Backup Funktion aus dem js-controller nutzt, wäre das ein Issue für den js-controller -
@simatec
ich bin gerade dabei ein komplett neues System aufzusetzten.
Jetzt scheitere ich am letzten Punkt.
Ich kann die Redis Datenbank nicht wiederherstellen!Folgende Fehlermeldung erhalte ich:
====================== Log Backitup Restore: ====================== [DEBUG] [redis] Start Redis Restore ... [DEBUG] [redis] Created Redis tmp [ERROR] [redis] Redis Restore not completed [ERROR] [redis] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/tmp/' [EXIT] undefined **** Restore completed successfully!! **** The log can be closed ...
Backitup Adapter in der Version 1.5.8
Sieht für mich nach irgendeinem Rechteproblem aus, ich kann es aber nicht lösen.
iobroker install Fixer habe ich schon versucht. -
Erst Redis installieren...
sudo apt-get install redis-server
Dann folgendes ausführen
sudo usermod -a -G redis iobroker sudo reboot
@simatec sagte in Test Adapter Backitup v1.6.x:
Alles ohne Fehler ausgeführt, aber die Fehlermeldung beim Wiederherstellen bleibt die Gleiche.
sudo -u iobroker groups
@Thomas-Braun sagte in Test Adapter Backitup v1.6.x:
Auch keine Veränderung.
Im Log steht noch zusätzlich:backitup.0 2020-09-13 20:16:00.952 warn (1394) Cannot read log file: ReferenceError: config is not defined
@slonnet Du sollst die Ausgabe posten. Der Befehl ändert nichts.
Ok, macht Sinn
pi@orangepiplus2e:~$ sudo -u iobroker groups iobroker tty dialout audio video redis
@simatec Morgen, setzte backitup in v1.6.7 ein. Wurde heute morgen mit einer Fehlermeldung beim Backup in diesem Datenpunkt begrüßt:
backitup.0.history.iobrokerLastTime
Meldung:
error: 20. September 2020 um 03:30 Uhr
Wenn ich allerdings auf Filesystem Ebene nachsehe scheint alles ok:
ls -la total 96200 drwxrwxrwx+ 2 iobroker iobroker 4096 Sep 20 03:30 . drwxrwxrwx+ 8 iobroker iobroker 4096 Sep 19 10:05 .. -rw-rw-rw-+ 1 iobroker iobroker 6842369 May 9 13:25 2020_05_09-13_25_34_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 8210513 Jun 10 18:53 2020_06_10-18_53_46_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 8298907 Jun 28 11:26 2020_06_28-11_26_20_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 7 01:30 homematic_2020_09_07-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 10 01:30 homematic_2020_09_10-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 13 01:30 homematic_2020_09_13-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 16 01:30 homematic_2020_09_16-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 19 01:30 homematic_2020_09_19-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk -rw-rw-rw-+ 1 iobroker iobroker 8345290 Sep 16 03:30 iobroker_2020_09_16-03_30_10_iobroker_wald_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 8345873 Sep 17 03:30 iobroker_2020_09_17-03_30_10_iobroker_wald_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 8345298 Sep 18 03:30 iobroker_2020_09_18-03_30_10_iobroker_wald_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 8449703 Sep 19 03:30 iobroker_2020_09_19-03_30_10_iobroker_wald_backupiobroker.tar.gz -rw-rw-rw-+ 1 iobroker iobroker 8401710 Sep 20 03:30 iobroker_2020_09_20-03_30_10_iobroker_wald_backupiobroker.tar.gz
Das Archiv iobroker_2020_09_20-03_30_10_iobroker_wald_backupiobroker.tar.gz lässt sich entpacken und ist damit wohl i.O.
Eine Idee dazu?
@BoehserWolf
Bitte poste mal den Debuglog von Backitup -
@simatec Gerade manuell ausgeführt. Der Datenpunkt steht weiterhin auf false.
backitup.0 2020-09-20 12:42:51.127 debug (32749) system.adapter.admin.0: logging true backitup.0 2020-09-20 12:41:47.829 debug (32749) system.adapter.admin.0: logging false backitup.0 2020-09-20 12:41:22.662 debug (32749) system.adapter.admin.0: logging true backitup.0 2020-09-20 12:41:11.453 debug (32749) [iobroker] exec: done backitup.0 2020-09-20 12:41:11.452 debug (32749) [iobroker] exec: done backitup.0 2020-09-20 12:41:11.452 debug (32749) [iobroker/history] backitup.0.history.json backitup.0 2020-09-20 12:41:11.452 debug (32749) [iobroker/history] backitup.0.history.html backitup.0 2020-09-20 12:41:11.446 debug (32749) [iobroker/clean] done backitup.0 2020-09-20 12:41:11.445 debug (32749) [iobroker/iobroker] done backitup.0 2020-09-20 12:41:10.435 debug (32749) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_20-12_41_07_iobroker_wald_backupiobroker.tar.gz backitup.0 2020-09-20 12:41:08.875 debug (32749) system.adapter.admin.0: logging false backitup.0 2020-09-20 12:41:08.480 debug (32749) [iobroker/iobroker] host.iobroker 5414 objects saved backitup.0 2020-09-20 12:41:08.471 debug (32749) [iobroker/iobroker] host.iobroker 4997 states saved backitup.0 2020-09-20 12:41:07.300 debug (32749) Backup has started ... backitup.0 2020-09-20 12:40:19.566 debug (32749) No backup file was found backitup.0 2020-09-20 12:40:19.565 debug (32749) [ccu] 10 30 01 */3 * * backitup.0 2020-09-20 12:40:19.564 info (32749) [ccu] backup was activated at 01:30 every 3 day(s) backitup.0 2020-09-20 12:40:19.563 debug (32749) [iobroker] 10 30 03 */1 * * backitup.0 2020-09-20 12:40:19.558 info (32749) [iobroker] backup was activated at 03:30 every 1 day(s) backitup.0 2020-09-20 12:40:19.540 info (32749) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.22.1, js-controller: 3.1.6 backitup.0 2020-09-20 12:40:19.535 info (32749) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system backitup.0 2020-09-20 12:40:19.533 debug (32749) Plugin sentry Initialize Plugin (enabled=true) backitup.0 2020-09-20 12:40:19.275 debug (32749) statesDB connected backitup.0 2020-09-20 12:40:19.275 debug (32749) States connected to redis: 127.0.0.1:9000 backitup.0 2020-09-20 12:40:19.273 debug (32749) States create System PubSub Client backitup.0 2020-09-20 12:40:19.272 debug (32749) States create User PubSub Client backitup.0 2020-09-20 12:40:19.270 debug (32749) Redis States: Use Redis connection: 127.0.0.1:9000 backitup.0 2020-09-20 12:40:19.269 debug (32749) objectDB connected backitup.0 2020-09-20 12:40:19.267 debug (32749) Objects connected to redis: 127.0.0.1:9001 backitup.0 2020-09-20 12:40:19.263 debug (32749) Objects client initialize lua scripts backitup.0 2020-09-20 12:40:19.263 debug (32749) Objects create User PubSub Client backitup.0 2020-09-20 12:40:19.263 debug (32749) Objects create System PubSub Client backitup.0 2020-09-20 12:40:19.261 debug (32749) Objects client ready ... initialize now backitup.0 2020-09-20 12:40:19.249 debug (32749) Redis Objects: Use Redis connection: 127.0.0.1:9001
hallo zusammen,
kurze frage..
mir wurde empfohlen, mein anliegen in diesem thread zu posten...ich bin aktuell auf der version 0.1.6 von dem whatsapp-cmb.0 adapter und wollte den adapter benutzen um mich benachrichtigen zu lassen, wenn backitup kein backup erstellen konnte.
in dem whatsapp-cmb.0 habe ich soweit alles eingerichtet wie auf dem bild unten zu sehen incl. des api keys, welches ich per whatsapp bekommen hatte.
in dem backitup.0 adapter habe ich soweit auch alles aktiviert
doch leider kommt nichts bei mir an..mittlerweile sind schon ein paar stündchen vergangen...
wenn ich eine test nachricht verschicke über
https://api.callmebot.com/whatsapp.php?phone=[phone_number]&text=[message]&apikey=[your_apikey]
funktioniert es einwandfrei...kann es sein, dass der backtitup adapter das noch nicht sauber integriert hat bzw. in der aktuellesten version 1.6.7 ein problem hat?
@ltsalvatore sagte in Test Adapter Backitup v1.6.x:
Da du in den Einstellungen das Häkchen "Benachrichtigung nur bei Fehlern" aktiv hast, kommt auch nur eine Meldung bei Fehlern.
hi simatec
ich habe sowohl mit als auch ohne dieser option getestet.
ich habe auch absichtlich ein fehler in den einstellungen gesetzt um entsprechend ein fehler zu simulieren. -
@ltsalvatore
Dann teste, ob deine Einstellungen im Whatsapp Adapter korrekt sind und schicke dir Testnachrichten aus iobroker (Blockly oder Javascript)Backitup verwendet am Ende die gleichen Funktionen ...
Ansonsten bitte debuglog schicken -
@ltsalvatore
Ansonsten bitte debuglog schickenhi simatec,
über blockly und objekt "send message" funktioniert es einwandfrei.
ich habe dann diverse male getestet und es scheint wohl tatsächlich daran zu liegen, was man beim backitup adapter als benachrichtigungsstil auswählt.wenn ich "kurze benachrichtigungen" wähle, dann kommen die messages sofort an.
wähle ich stattdessen "lange benachrichtigungen" kommt nichts an...mir reicht im endeffekt die kurze benachrichtigung vollkommen aus... sollte sich doch jemand das ganze noch mal im detail anschauen wollen hier das log file:
whatsapp-cmb.0 2020-09-22 22:56:19.396 debug (29603) system.adapter.admin.0: logging true whatsapp-cmb.0 2020-09-22 22:53:27.906 debug (29603) system.adapter.admin.0: logging false whatsapp-cmb.0 2020-09-22 22:50:24.653 debug (29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:50 Uhr erstellt.<p><b>Message queued.</b> You will receive it in a few sec whatsapp-cmb.0 2020-09-22 22:50:24.388 debug (29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A50%20Uhr%20erstellt.&apike whatsapp-cmb.0 2020-09-22 22:50:24.388 info Ein neues iobroker Backup wurde am 22. September 2020 um 22:50 Uhr erstellt. to +491799700000 whatsapp-cmb.0 2020-09-22 22:50:24.388 info (29603) Send BackItUp: whatsapp-cmb.0 2020-09-22 22:48:55.316 debug (29603) system.adapter.admin.0: logging true whatsapp-cmb.0 2020-09-22 22:48:41.649 debug (29603) system.adapter.admin.0: logging false whatsapp-cmb.0 2020-09-22 22:47:24.706 debug (29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:47 Uhr erstellt, und unter //192.168.111.100/"prv\Salva\P1\Backups\Server\ whatsapp-cmb.0 2020-09-22 22:47:24.504 debug (29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A47%20Uhr%20erstellt%2C%20u whatsapp-cmb.0 2020-09-22 22:47:24.504 info Ein neues iobroker Backup wurde am 22. September 2020 um 22:47 Uhr erstellt, und unter //192.168.111.100/"prv\Salva\P1\Backups\Server\Smarthome\iobroker\minimal" gespeichert. to +491799700000 whatsapp-cmb.0 2020-09-22 22:47:24.504 info (29603) Send BackItUp: whatsapp-cmb.0 2020-09-22 22:44:24.815 debug (29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:44 Uhr erstellt.<p><b>Message queued.</b> You will receive it in a few sec whatsapp-cmb.0 2020-09-22 22:44:24.502 debug (29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A44%20Uhr%20erstellt.&apike whatsapp-cmb.0 2020-09-22 22:44:24.502 info Ein neues iobroker Backup wurde am 22. September 2020 um 22:44 Uhr erstellt. to +491799700000 whatsapp-cmb.0 2020-09-22 22:44:24.502 info (29603) Send BackItUp: whatsapp-cmb.0 2020-09-22 22:43:17.411 info (29603) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.21.0, js-controller: 3.1.6 whatsapp-cmb.0 2020-09-22 22:43:16.954 debug (29603) statesDB connected whatsapp-cmb.0 2020-09-22 22:43:16.954 debug (29603) States connected to redis: 127.0.0.1:9000 whatsapp-cmb.0 2020-09-22 22:43:16.950 debug (29603) States create System PubSub Client whatsapp-cmb.0 2020-09-22 22:43:16.950 debug (29603) States create User PubSub Client whatsapp-cmb.0 2020-09-22 22:43:16.947 debug (29603) Redis States: Use Redis connection: 127.0.0.1:9000 whatsapp-cmb.0 2020-09-22 22:43:16.946 debug (29603) objectDB connected whatsapp-cmb.0 2020-09-22 22:43:16.944 debug (29603) Objects connected to redis: 127.0.0.1:9001 whatsapp-cmb.0 2020-09-22 22:43:16.939 debug (29603) Objects client initialize lua scripts whatsapp-cmb.0 2020-09-22 22:43:16.939 debug (29603) Objects create User PubSub Client whatsapp-cmb.0 2020-09-22 22:43:16.938 debug (29603) Objects create System PubSub Client whatsapp-cmb.0 2020-09-22 22:43:16.937 debug (29603) Objects client ready ... initialize now whatsapp-cmb.0 2020-09-22 22:43:16.921 debug (29603) Redis Objects: Use Redis connection: 127.0.0.1:9001
@ltsalvatore
Schaue ich mir noch einmal an. Allerdings kann ich den Fehler nicht nachstellen, da auf meinem Dev-System "Lange Benachrichtigung" eingestellt ist und die Nachrichten sauber gesendet werden
