    3. Tester
    4. Test Adapter ioBroker.backitup v3.1.x
      Frank_y @Frank_y last edited by
      auch ein Systemneustart bringt keine Änderung
      backitup.0.history.iobrokerLastTime und backitup.0.history.iobrokerSuccess zeigen einen Fehler an
      json zeigt alles i.O. an.
      Datei ist auf Dropbox vorhanden
      • simatec
        simatec Developer Most Active @Frank_y last edited by
        @Frank_y
        Bitte führe iobroker fix aus und poste mal den Debuglog des Backupprozesses
          Frank_y @simatec last edited by Negalein
          @simatec
          fixer ausgeführt (curl -fsL https://iobroker.net/fix.sh | bash -)
          • adapter auf debug gestellt
          cron-job liefert folgendes LOG
          backitup.0	2020-09-24 18:03:57.755	debug	(17894) system.adapter.admin.0: logging true
          backitup.0	2020-09-24 18:03:29.468	debug	(17894) [iobroker/clean] delete /opt/iobroker/backups/redis_2020_09_21-16_09_34_backupiobroker.tar.gz
          backitup.0	2020-09-24 18:03:29.462	debug	(17894) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_23-02_00_10_backupiobroker.tar.gz
          backitup.0	2020-09-24 18:03:29.199	debug	(17894) [iobroker] exec: done
          backitup.0	2020-09-24 18:03:29.190	debug	(17894) [iobroker] exec: done
          backitup.0	2020-09-24 18:03:29.187	debug	(17894) [iobroker/history] backitup.0.history.json
          backitup.0	2020-09-24 18:03:29.179	debug	(17894) [iobroker/history] backitup.0.history.html
          backitup.0	2020-09-24 18:03:29.159	debug	(17894) [iobroker/clean] done
          backitup.0	2020-09-24 18:03:29.151	debug	(17894) [iobroker/dropbox] done
          backitup.0	2020-09-24 18:03:28.620	debug	(17894) [iobroker/dropbox] Dropbox: delete /backupDir/redis_2020_09_09-02_00_18_backupiobroker.tar.gz
          backitup.0	2020-09-24 18:03:28.043	debug	(17894) [iobroker/dropbox] Dropbox: delete /backupDir/iobroker_2020_09_09-02_00_10_backupiobroker.tar.gz
          backitup.0	2020-09-24 18:03:18.542	debug	(17894) [iobroker/dropbox] Dropbox: Copy redis_2020_09_24-18_00_17_backupiobroker.tar.gz...
          backitup.0	2020-09-24 18:00:18.148	debug	(17894) [iobroker/dropbox] Dropbox: Copy iobroker_2020_09_24-18_00_10_backupiobroker.tar.gz...
          backitup.0	2020-09-24 18:00:18.139	debug	(17894) [iobroker/redis] done
          backitup.0	2020-09-24 18:00:17.974	debug	(17894) [iobroker/iobroker] done
          backitup.0	2020-09-24 18:00:16.948	debug	(17894) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_24-18_00_10_backupiobroker.tar.gz
          backitup.0	2020-09-24 18:00:12.747	debug	(17894) [iobroker/iobroker] host.iobrokerVM 4876 objects saved
          ba[ckitup.0	2020-09-24 18:00:12.715	debug	(17894) [iobroker/iobroker] host.iobrokerVM 4042 states saved
          backitup.0	2020-09-24 18:00:10.143	debug	(17894) Backup has started ...
          backitup.0	2020-09-24 17:57:01.485	debug	(17894) system.adapter.admin.0: logging false
          backitup.0	2020-09-24 17:55:42.772	debug	(17894) system.adapter.admin.0: logging true
          backitup.0	2020-09-24 17:55:37.241	debug	(17894) system.adapter.admin.0: logging false[Link Text](Link Adresse)](Link Adresse)
          Leider bleiben beide Datenpunkte fehlerhaft
          Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
          Hier gehts zur Hilfe.
            @simatec
            habe danach noch einmal manuell <jetzt sichern> angestoßen und dann bestätigen beide Datenpunkte das korrekte backup:
            backitup.0.history.iobrokerLastTime 24. September 2020 um 18:10 Uhr
            backitup.0.history.iobrokerSuccess true
            das Log sieht genauso aus
            ->es hat irgendetwas mit dem Cron-Job zu tun
            • simatec
              @Frank_y
              history wird nicht sauber beendet.
              Hatten wir hier schonmal gehabt. ..
              • Instanz löschen
              • Adapter löschen
              • iobroker neustarten
              • backitup neu installieren und einrichten
              Scheint so, als ob bei deinem Update was schief gelaufen ist
                Frank_y @simatec last edited by Frank_y
                @simatec
                alles gemacht, gleiches Bild:
                -manuelle Auslösung in Ordnung
                -über den cron-job werden die Datenpunkte nicht richtig gesetzt
                bin per Rollback wieder zurück zur v1.5.8....hier läuft alles einwandfrei durch, manuell und per cron
                • simatec
                  @Frank_y
                  Was steht bei der 1.6.7 in folgenden Objekt nach dem Backup?
                  backitup.0.output.line
                  Gib mir mal bitte den Inhalt ...
                    @simatec
                    [DEBUG] [clean] - delete /opt/iobroker/backups/redis_2020_09_09-02_00_18_backupiobroker.tar.gz
                    • simatec
                      @Frank_y
                      Kann das sein, dass genau hier das Problem liegt?
                      Laut deinem anderen Post, gibt es in dem Ordner kein Redis-Backup.
                      Stimmen deine Rechte in dem Ordner backup
                        @simatec
                        die Ordner-Berechtigungen sind in beiden Versionen gleich:
                        v.1.5.8:
                        v1.6.7:
                        Wenn ich manuell starte funktioniert ja auch alles. Auch beim Cron-Job werden Backups erstellt. Nur die Rückmeldungen in den beiden Datenpunkt scheinen nicht korrekt
                        • simatec
                          simatec Developer Most Active @Frank_y last edited by simatec
                          @Frank_y
                          Bei einem manuellen Backup werden keine alten Dateien gelöscht.
                          Deshalb kommt der Fehler dort nicht.
                          Zeige doch bitte mal den kompletten Inhalt deines Backup-Ordners ...
                            @simatec
                            v1.5.8
                            v.1.6.7
                            Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @Frank_y last edited by Thomas Braun
                              @Frank_y
                              Falsche Rechte.
                              Das sollte so aussehen:
                              -rw-rwxr--+ 1 iobroker iobroker 5127439 Sep 20 02:42 iobroker_2020_09_20-02_42_51_backupiobroker.tar.gz
                              Bzw. so:
                              pi@raspberrypi:~ $ getfacl /opt/iobroker/backups/iobroker_2020_09_20-02_42_51_backupiobroker.tar.gz
                              getfacl: Entferne führende '/' von absoluten Pfadnamen
                              # file: opt/iobroker/backups/iobroker_2020_09_20-02_42_51_backupiobroker.tar.gz
                              # owner: iobroker
                              # group: iobroker
                              user::rw-
                              group::r-x
                              group:iobroker:rwx
                              mask::rwx
                              other::r--
                              Konsolenausgaben bitte nicht als Screenshot sondern als Text in CodeTags setzen.
                              • simatec
                                @Frank_y
                                So wie es aber ausschaut, wird auch mit der 1.5.8 dein altes Redis Backup nicht gelöscht
                                  @simatec sagte in Test Adapter Backitup v1.6.x:
                                  @Frank_y
                                  kann ich nicht bestätigen....mit den Rechten werden in 1.5.8 auch die alten Redis-Backups gelöscht. Und zwar im System als auch auf Dropbox.
                                  Aber egal, was kann ich tun. Den Fixer hatte ich schon laufen lassen.
                                  • simatec
                                    @Frank_y
                                    Hmmm sehe ich nicht so. Bei der 1.6.7 bleibt er bei dem Redis Backup vom 9.9. hängen und bei der 1.5.8 ist es auch noch da. Also wird es nicht gelöscht.
                                    Passe deine Rechte nach den Vorgaben von @Thomas-Braun an.
                                      BoehserWolf @Thomas Braun last edited by
                                      @Thomas-Braun
                                      Ok, Rechte waren bei mir im Backup Verzeichnis ebenfalls anders, iobroker fix hat es nicht gerichtet. Habe die für die iobroker*.tar.gz nun angepasst.
                                      Von:
                                      getfacl iobroker_2020_09_27-03_30_10_iobroker_wald_backupiobroker.tar.gz
                                      # file: iobroker_2020_09_27-03_30_10_iobroker_wald_backupiobroker.tar.gz
                                      # owner: iobroker
                                      # group: iobroker
                                      user::rw-
                                      group::rwx                      #effective:rw-
                                      group:iobroker:rwx              #effective:rw-
                                      mask::rw-
                                      other::rw-
                                      Nach:
                                      # owner: iobroker
                                      # group: iobroker
                                      user::rw-
                                      group::r-x
                                      group:iobroker:rwx
                                      mask::rwx
                                      other::r--
                                      Verzeichnis:
                                      getfacl: Removing leading '/' from absolute path names
                                      # owner: iobroker
                                      # group: iobroker
                                      user::rwx
                                      group::rwx
                                      group:iobroker:rwx
                                      mask::rwx
                                      other::rwx
                                      default:user::rwx
                                      default:group::rwx
                                      default:group:iobroker:rwx
                                      default:mask::rwx
                                      default:other::rwx
                                      @simatec Mir stellt sich nun die Frage wie kommt es dazu und was hat backitup v1.6.7 damit zu tun? Bei mir tritt das "Phänomen" seit v1.6.7 auf. Irgendetwas muss sich da geändert haben.
                                      Mit homematic*.tar.sbk sehen die Rechte bei mir auch nicht wie im Post von @Thomas-Braun aus. Der Datenpunkt backitup.0.history.ccuSuccess steht auf false. Sollte ich diese Dateien auch anpassen? Bspw. jetzt:
                                      getfacl homematic_2020_09_25-01_30_10_3.51.6.20200229_backupiobroker.tar.sbk
                                      # file: homematic_2020_09_25-01_30_10_3.51.6.20200229_backupiobroker.tar.sbk
                                      # owner: iobroker
                                      # group: iobroker
                                      user::rw-
                                      mask::rw-
                                      other::rw-
                                        Frank_y @BoehserWolf last edited by
                                        @simatec
                                        @Thomas-Braun
                                        Dem Ordner /backups habe ich über chmod 777 Rechte gegeben.
                                        @iobrokerVM:/opt/iobroker$ sudo chmod 777 backups/
                                        [sudo] Passwort für
                                        @iobrokerVM:/opt/iobroker$ getfacl backups/
                                        # file: backups/
                                        # owner: iobroker
                                        # group: iobroker
                                        user::rwx
                                        group::r-x
                                        group:iobroker:rwx
                                        mask::rwx
                                        other::rwx
                                        default:user::rwx
                                        default:group::r-x
                                        default:mask::rwx
                                        default:other::r-x]
                                        Datei-Rechte im /backups habe ich manuell mit setfacl angepasst, dann Update auf 1.6.7.
                                        Backup über Cron-job gestartet. Die neu erzeugten Dateien (Sep 27 12:30 ) haben wieder die Rechte -rw-rw-r--+ 1
                                        @iobrokerVM:/opt/iobroker/backups$ ls -l
                                        insgesamt 116460
                                        -rw-rwxr--+ 1 iobroker iobroker 10407690 Sep  7 02:00 iobroker_2020_09_07-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10408118 Sep  9 02:00 iobroker_2020_09_09-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10405895 Sep 11 02:00 iobroker_2020_09_11-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10404922 Sep 13 02:00 iobroker_2020_09_13-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10405309 Sep 15 02:00 iobroker_2020_09_15-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10406213 Sep 17 02:00 iobroker_2020_09_17-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10414384 Sep 19 02:00 iobroker_2020_09_19-02_00_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10424841 Sep 24 21:51 iobroker_2020_09_24-21_51_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10425075 Sep 25 02:00 iobroker_2020_09_25-02_00_14_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 10434793 Sep 27 02:00 iobroker_2020_09_27-02_00_10_backupiobroker.tar.gz
                                        -rw-rw-r--+ 1 iobroker iobroker 10437056 Sep 27 12:30 iobroker_2020_09_27-12_30_10_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   418520 Sep  7 02:00 redis_2020_09_07-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   419410 Sep  9 02:00 redis_2020_09_09-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   414630 Sep 11 02:00 redis_2020_09_11-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   416276 Sep 13 02:00 redis_2020_09_13-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   418406 Sep 15 02:00 redis_2020_09_15-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   419599 Sep 17 02:00 redis_2020_09_17-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   419813 Sep 19 02:00 redis_2020_09_19-02_00_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   420060 Sep 24 21:51 redis_2020_09_24-21_51_18_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   419945 Sep 25 02:00 redis_2020_09_25-02_00_22_backupiobroker.tar.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   429191 Sep 27 02:00 redis_2020_09_27-02_00_19_backupiobroker.tar.gz
                                        -rw-rw-r--+ 1 iobroker iobroker   430312 Sep 27 12:30 redis_2020_09_27-12_30_18_backupiobroker.tar.gz
                                        Die Datenpunkte zeigen weiterhin ein fehlerhaftes Backup an
                                        • simatec
                                          @Frank_y @BoehserWolf
                                          Bitte postet mal genauere Info zu eurem System.
                                          Backitup setzt keine Dateirechte.
                                          Bitte folgendes mal angeben:
                                          • node
                                          • nodejs
                                          • npm
                                          • js-controller
                                          Bitte auch mal das System neustarten und danach folgenden Befehl iobroker fix noch einmal ausführen und im Anschluss noch einmal zur Sicherheit neustarten
                                            BoehserWolf @simatec last edited by
                                            @simatec
                                            Betreibe ein Debian 10.6 x64 in einem LXC Container unter Proxmox 6 vom stable Repo.
                                            cat /etc/os-release
                                            PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                                            NAME="Debian GNU/Linux"
                                            VERSION_ID="10"
                                            VERSION="10 (buster)"
                                            VERSION_CODENAME=buster
                                            ID=debian
                                            HOME_URL="https://www.debian.org/"
                                            SUPPORT_URL="https://www.debian.org/support"
                                            BUG_REPORT_URL="https://bugs.debian.org/"
                                            free -m
                                            Mem:           4096        1034        2609          15         451        3061
                                            Swap:          1536           0        1535
                                            which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                            /usr/bin/nodejs
                                            v10.22.1
                                            /usr/bin/node
                                            v10.22.1
                                            /usr/bin/npm
                                            6.14.6
                                            nodejs:
                                              Installed: 10.22.1-1nodesource1
                                              Candidate: 10.22.1-1nodesource1
                                              Version table:
                                             *** 10.22.1-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_10.x buster/main amd64 Packages
                                                    100 /var/lib/dpkg/status
                                                 10.21.0~dfsg-1~deb10u1 500
                                                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                                    500 http://security.debian.org buster/updates/main amd64 Packages
                                            Typ: js-controller
                                            Titel: JS controller
                                            OS: linux
                                            Verfügbar: 3.1.6
                                            Installiert: 3.1.6
                                            Reboot, fix, reboot habe ich durchgeführt.
                                            Danach backitup auf Debug und Backupzeit in den Adapter-Einstellungen angepasst (also per cron). Log:
                                            backitup.0	2020-09-27 17:32:14.471	debug	(3664) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_26-03_30_10_iobroker_wald_backupiobroker.tar.gz
                                            backitup.0	2020-09-27 17:32:14.177	debug	(3664) [iobroker] exec: done
                                            backitup.0	2020-09-27 17:32:14.177	debug	(3664) [iobroker/history] backitup.0.history.json
                                            backitup.0	2020-09-27 17:32:14.175	debug	(3664) [iobroker] exec: done
                                            backitup.0	2020-09-27 17:32:14.175	debug	(3664) [iobroker/history] backitup.0.history.html
                                            backitup.0	2020-09-27 17:32:14.170	debug	(3664) [iobroker/clean] done
                                            backitup.0	2020-09-27 17:32:14.169	debug	(3664) [iobroker/iobroker] done
                                            backitup.0	2020-09-27 17:32:13.160	debug	(3664) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_27-17_32_10_iobroker_wald_backupiobroker.tar.gz
                                            backitup.0	2020-09-27 17:32:11.258	debug	(3664) [iobroker/iobroker] host.iobroker 5439 objects saved
                                            backitup.0	2020-09-27 17:32:11.250	debug	(3664) [iobroker/iobroker] host.iobroker 5038 states saved
                                            backitup.0	2020-09-27 17:32:10.035	debug	(3664) Backup has started ...
                                            backitup.0	2020-09-27 17:31:21.195	debug	(3664) No backup file was found
                                            backitup.0	2020-09-27 17:31:21.194	debug	(3664) [ccu] 10 30 01 */3 * *
                                            backitup.0	2020-09-27 17:31:21.192	info	(3664) [ccu] backup was activated at 01:30 every 3 day(s)
                                            backitup.0	2020-09-27 17:31:21.192	debug	(3664) [iobroker] 10 32 17 */1 * *
                                            backitup.0	2020-09-27 17:31:21.187	info	(3664) [iobroker] backup was activated at 17:32 every 1 day(s)
                                            backitup.0	2020-09-27 17:31:21.172	info	(3664) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.22.1, js-controller: 3.1.6
                                            backitup.0	2020-09-27 17:31:21.163	info	(3664) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                            backitup.0	2020-09-27 17:31:21.157	debug	(3664) Plugin sentry Initialize Plugin (enabled=true)
                                            Rechte neu:
                                            ls -l /opt/iobroker/backups/iobroker_2020_09_27-17_32_10_iobroker_wald_backupiobroker.tar.gz
                                            -rw-rw-rw-+ 1 iobroker iobroker 8417676 Sep 27 17:32 /opt/iobroker/backups/iobroker_2020_09_27-17_32_10_iobroker_wald_backupiobroker.tar.gz
                                            bzw.:
                                            getfacl /opt/iobroker/backups/iobroker_2020_09_27-17_32_10_iobroker_wald_backupiobroker.tar.gz
                                            # file: opt/iobroker/backups/iobroker_2020_09_27-17_32_10_iobroker_wald_backupiobroker.tar.gz
                                            # owner: iobroker
                                            # group: iobroker
                                            user::rw-
                                            mask::rw-
                                            other::rw-
                                            backitup backitup backup ccu history mysql redis restore restore backup
                                            170
                                            2779
                                            2244032
