Test Adapter ioBroker.backitup v3.1.x
@JB_Sullivan
Mache mal folgendes...- In den Instanzen löschen
- In Adapter löschen
- backitup.0 in den Objekten löschen
- iobroker neustarten
- backitup über den weiter oben geposteten Github-Link installieren
- backitup manuell einrichten (kein Restore der settings)
Ab sofort steht die Version 1.6.9 auf Github und in Kürze auch im latest zum testen bereit.
Changelog
1.6.9 (30.09.2020)
- (simatec) Timeout fix for backup process
"Holzhammer" Methode der Neuinstallation war leider auch nicht von Erfolg gekrönt. Habe jetzt schon die 1.6.9 aus dem GIT drauf und habe es so gemacht wie von dir beschrieben.
Trotzdem noch: error: 30. September 2020 um 10:57 Uhr
Output:
[DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"30. September 2020 um 10:57 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
Im übrigen braucht man nach dem löschen der Instanz, die Objekte nicht mehr separat löschen. Die werden einfach gleich mit gelöscht wenn man die Instanz entfernt.
Hat das ggf. etwas mit der Fehlermeldung während der Deinstallation zu tun?
2020-09-30 10:45:13.749 - info: host.GLT(GLT) iobroker del backitup 2020-09-30 10:45:15.322 - info: daswetter.0 (12624) Terminated (NO_ERROR): Without reason 2020-09-30 10:45:15.866 - info: host.GLT(GLT) instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR) 2020-09-30 10:45:16.652 - info: host.GLT(GLT) iobroker Delete adapter "backitup" 2020-09-30 10:45:16.722 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 meta of backitup 2020-09-30 10:45:16.731 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 adapter for backitup 2020-09-30 10:45:16.817 - info: host.GLT(GLT) iobroker host.GLT(GLT) Counted 1 states of system.adapter.backitup 2020-09-30 10:45:19.307 - info: host.GLT(GLT) iobroker host.GLT(GLT) file backitup.admin deleted 2020-09-30 10:45:19.316 - info: host.GLT(GLT) iobroker host.GLT(GLT) object backitup deleted 2020-09-30 10:45:19.321 - info: host.GLT(GLT) iobroker host.GLT(GLT) object backitup.admin deleted 2020-09-30 10:45:19.322 - info: host.GLT(GLT) iobroker host.GLT(GLT) Deleting 3 object(s). 2020-09-30 10:45:19.391 - info: host.GLT(GLT) iobroker npm uninstall iobroker.backitup --error (System call) 2020-09-30 10:45:20.298 - error: host.GLT(GLT) Cannot write files: C:\iobroker\GLT\iobroker-data\files\backitup.admin\_data.json: ENOENT: no such file or directory, open 'C:\iobroker\GLT\iobroker-data\files\backitup.admin\_data.json' 2020-09-30 10:45:57.045 - info: host.GLT(GLT) iobroker npm 2020-09-30 10:45:57.046 - info: host.GLT(GLT) iobroker WARN jscs-loader@0.3.0 requires a peer of jscs@^3.0.3 but none is installed. You must install peer dependencies yourself. 2020-09-30 10:45:57.050 - info: host.GLT(GLT) iobroker npm 2020-09-30 10:45:57.051 - info: host.GLT(GLT) iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules\fsevents): 2020-09-30 10:45:57.054 - info: host.GLT(GLT) iobroker npm 2020-09-30 10:45:57.056 - info: host.GLT(GLT) iobroker 2020-09-30 10:45:57.057 - info: host.GLT(GLT) iobroker WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"}) 2020-09-30 10:45:57.060 - info: host.GLT(GLT) iobroker npm 2020-09-30 10:45:57.063 - info: host.GLT(GLT) iobroker 2020-09-30 10:45:57.064 - info: host.GLT(GLT) iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules\osx-temperature-sensor): 2020-09-30 10:45:57.066 - info: host.GLT(GLT) iobroker npm 2020-09-30 10:45:57.067 - info: host.GLT(GLT) iobroker 2020-09-30 10:45:57.069 - info: host.GLT(GLT) iobroker WARN 2020-09-30 10:45:57.070 - info: host.GLT(GLT) iobroker notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"}) 2020-09-30 10:45:57.071 - info: host.GLT(GLT) iobroker 2020-09-30 10:45:58.183 - info: host.GLT(GLT) iobroker exit 0
@JB_Sullivan
In der Theorie sollten die Objekte gelöscht sein ...
Was sagt dein Debug Log?
Wie viele History-Einträge hast du in deine Config drin?Hast du mal ein iobroker fix laufen lassen?
Wie sieht dein Softwarestand aus? node, nodejs, js-controller?
Es ist eine Windows Installation - also nix fix.
History (DB) sind 5 - Historie Eintragungen sind 10
Debug Log:
Gestartet... [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"} [DEBUG] [iobroker] - host.GLT(GLT) 15691 states saved [DEBUG] [iobroker] - host.GLT(GLT) 17574 objects saved [DEBUG] [iobroker] - Backup created: C:\iobroker\GLT\backups\iobroker_2020_09_30-12_22_00_backupiobroker.tar.gz [DEBUG] [iobroker] - done [DEBUG] [historyDB] - Packed 2MB so far... [DEBUG] [historyDB] - Packed 11MB so far... [DEBUG] [historyDB] - Packed 20MB so far... [DEBUG] [historyDB] - Packed 28MB so far... [DEBUG] [historyDB] - Packed 38MB so far... [DEBUG] [historyDB] - Packed 50MB so far... [DEBUG] [historyDB] - Packed 62MB so far... [DEBUG] [historyDB] - done [DEBUG] [googledrive] - Google Drive: Copy iobroker_2020_09_30-12_22_00_backupiobroker.tar.gz... [DEBUG] [googledrive] start with {"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal","deleteBackupAfter":0} [DEBUG] [googledrive] - Google Drive: Copy historyDB_2020_09_30-12_22_17_backupiobroker.tar.gz... [DEBUG] [googledrive] - done [DEBUG] [clean] - done [DEBUG] [history] - backitup.0.history.html [DEBUG] [history] - backitup.0.history.json [EXIT] 0 [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"dir":"C:/iobroker/GLT","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:\\iobroker\\GLT\\iobroker-data\\history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"C:\\iobroker\\GLT\\node_modules\\iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":true,"dir":"/GLT/minimal","dirMinimal":"/GLT/minimal"},"path":"C:/iobroker/GLT/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de","time":"30. September 2020 um 12:24 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"C:/iobroker/GLT/backups"}
Software Stände sind Admin, js-controller = latest
@JB_Sullivan
Zeig mal bitte deine Config von backitup als json -
@simatec sagte in Test Adapter Backitup v1.6.x:
@JB_Sullivan
Zeig mal bitte deine Config von backitup als jsondie finde ich wo? - iobroker-data\files\backitup.admin?
@JB_Sullivan sagte in Test Adapter Backitup v1.6.x:
@JB_Sullivan
@simatec
heute Nacht erneut fehlerlos mit 1.6.8 durchgelaufen.
Vielen Dank für intensive Unterstützung. -
@JB_Sullivan
Schalte mal in der Adapter Config Debug aus.
In den Instanzen aber bitte anlassen -
@JB_Sullivan
Hast du auch wirklich die Reihenfolge eingehalten? Instanz löschen, Adapter löschen, prüfen ob alles aus den Objekten gelöscht ist, iobroker bzw. System neustarten und im Anschluss Backitup neu installieren und manuell konfigurieren.Die Probleme hatten andere auch ab und an in der Vergangenheit.
Ich vermute es liegt an Fehlern bei irgendwelchen Updates im System ... aber kann es nicht lokalisieren.Aber der Fehler war bei der von mir beschriebenen Reihenfolge im Anschluss weg.
https://forum.iobroker.net/post/392401
Auch ein Update von node und npm wäre ratsam
Ist ja der Knaller - ich habe es eben noch einmal EXAKT so gemacht wie heute Mittag und wie von dir vorgegeben - nun ist der Error weg und im Output steht nur noch [Exit] 0.
Ist schon der Knaller - Ist die Error Meldung eigentlich nur ein textlicher Schönheitsfehler? In der historie json, stand ja trotz des Error - "Fehler - None".
Die Backup Dateien sind ja auch 1A erzeugt und gesichert worden. -
@JB_Sullivan
Nein es ist kein Schönheitsfehler.
Der Prozess bleibt beim erstellen des Historyeintrags hängen.Warum das so ist, kann ich aktuell nicht erklären, da ich den Fehler nicht nachstellen kann.
Aber es muss irgendwas mit beschädigten Paketen/Abhängigkeiten zu tun haben.Durch die komplette Neuinstallation werden die Pakete/Abhängigkeiten auch neu installiert und damit der Fehler behoben
Ab sofort ist auf Github und in kürze auch im latest die Version 1.7.0 verfügbar ...
Changelog
1.7.0 (26.10.2020)
- (simatec) small Bugfix for umount on cifs/nfs mount
- (simatec) Dev-Dependencies updated
- (simatec) Dependencies updated
Sorry, jetzt hatte ich schon in einem anderen Thema gefragt.
Beim zurückspielen meiner zigbee.tar bekomme ich folgende Fehlermeldung :
Mache ich was falsch?
MfG
eMd -
So, Problem gelöst. Habe die Sicherung per Hand nach /opt/iobroker/backup kopiert, danach ließ sie sich einwandfrei einspielen...
MfG
eMd -
ich bin noch auf 1.6.9Seit einiger Zeit so etwa 2 Wochen werden die Daten im json DP immer als undefined angezeigt.
Das Backup File wurde aber auf dem NAS(Fritz:NAS) geschrieben.
Was könnte das sein? Bin für jeden Tipp dankbar!![{"date":"31. Oktober 2020 um 10:34 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"31. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"30. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"29. Oktober 2020 um 10:10 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"29. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"28. Oktober 2020 um 09:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 12:53 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 09:02 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"27. Oktober 2020 um 07:11 Uhr","name":"iobroker_2020_10_27-07_11_24_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"7MB","error":"none"},{"date":"27. Oktober 2020 um 02:04 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 22:43 Uhr","name":"iobroker_2020_10_26-22_43_13_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"7MB","error":"none"},{"date":"26. Oktober 2020 um 22:32 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 22:20 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 16:20 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"26. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"25. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"24. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_24-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"23. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_23-02_00_22_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"22. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_22-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"21. Oktober 2020 um 13:43 Uhr","name":"iobroker_2020_10_21-13_43_19_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"21. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"20. Oktober 2020 um 02:00 Uhr","name":"undefined","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"undefined","error":"none"},{"date":"19. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_19-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"18. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_18-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"},{"date":"17. Oktober 2020 um 02:00 Uhr","name":"iobroker_2020_10_17-02_00_20_elzershark_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"6MB","error":"none"}]
@Bibo-13 Obacht! Nach Update auf 1.7.0 musste ich im Adapter bei CCU-Backup das Kennwort neu eingeben, sonst lief das Backup nicht. Das ioBroker-Backup lief problemlos durch.
@Meister-Mopper Danke sehr, aber bei mir ist es der IOBROKER Backup
