    3. Tester
    4. Test Adapter ioBroker.backitup v3.1.x
    • JB_Sullivan
      JB_Sullivan @simatec last edited by
      @simatec sagte in Test Adapter Backitup v1.3.x:
      iobroker host this
      BINGO !!!!!! Ich komme wieder drauf !!!!!
      C:\iobroker\GLT>iobroker stop
      2019-12-06 22:37:02,462 INFO  - Stopping the service with id 'iobroker(GLT)'
      C:\iobroker\GLT>iobroker host this
      Host "iobroker(ioBroker)" successfully renamed to "GLT".
      The host for instance "system.adapter.admin.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.alexa2.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.backitup.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.bring.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.cloud.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.daswetter.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.deconz.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.discovergy.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.discovery.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.dwd.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.email.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.flot.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.fritzbox.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.fritzdect.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.fullybrowser.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.history.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.ical.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.ical.1" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.icons-material-png.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.icons-material-svg.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.info.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.innogy-smarthome.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.iot.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.javascript.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.mihome-vacuum.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.octoprint.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.ping.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.proxy.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.rflink.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.roomba.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.socketio.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.sonoff.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.sourceanalytix.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.spotify-premium.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.tankerkoenig.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.telegram.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.tr-064.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.trashschedule.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-canvas-gauges.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-colorpicker.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-history.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-hqwidgets.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-jqui-mfd.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-justgage.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-materialdesign.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-plumb.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-timeandweather.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis-weather.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.vis.0" was changed from "GLT(GLT)" to "GLT".
      The host for instance "system.adapter.web.0" was changed from "GLT(GLT)" to "GLT".
      C:\iobroker\GLT>iobroker start
      2019-12-06 22:37:22,326 INFO  - Starting the service with id 'iobroker(GLT)'
      • simatec
        simatec Developer Most Active @JB_Sullivan last edited by
        @JB_Sullivan 👍
        JB_Sullivan 1 Reply Last reply Reply Quote 0
        • JB_Sullivan
          @simatec
          Jetzt sieht man im LOG, das er mächtig am nachladen ist - was war des Rätsels Lösung, bzw. warum dieses "Fehlverhalten"?
          • simatec
            @JB_Sullivan
            Lag nicht am restore oder backitup.
            Es wurde der Hostname von deinem alten System gesetzt
            Stabilostick 1 Reply Last reply Reply Quote 0
            • Stabilostick
              Stabilostick @simatec last edited by Stabilostick
              @simatec @JB_Sullivan
              Wenn man die Wiederherstellung des gesicherten iobroker-data-Ordners mit dem Windows Installer macht, wird dabei u.a. auch der Hostname automatisch auf den aktuellen Stand gebracht.
              • simatec
                simatec Developer Most Active @Stabilostick last edited by
                @Stabilostick
                Das sollte dann bei backitup auch mit rein.
                Aber für sollten uns beide noch einmal kurzschließen ...
                • JB_Sullivan
                  @simatec
                  Also vielen Dank für deine Geduld und deine Unterstützung. Alleine hätte ich das NIE lösen können - Also nochmals vielen vielen Dank !!! 👍 👍 👍 👍
                  • Dr. Bakterius
                    Dr. Bakterius Most Active @JB_Sullivan last edited by Dr. Bakterius
                    Wo wird die Konsole mit dem Fortschritt angezeigt? Bei mir läuft nur der Balken endlos durch. Habe auch mal versucht http://IP:PORT/backitup-restore selbst aufzurufen. Da war keine Seite erreichbar.
                    • opossum
                      opossum last edited by
                      Hallo, @Dr-Bakterius ,
                      hast Du im Browser einen Popupblocker? Bei mir wurde das erst angezeigt, als ich den Popupblocker ausgeschaltet hatte.
                      Dr. Bakterius 1 Reply Last reply Reply Quote 0
                      • Dr. Bakterius
                        Dr. Bakterius Most Active @opossum last edited by Dr. Bakterius
                        @opossum Kann schon sein (Chrome). Müsste ich beim nächsten Mal testen und alles was blocken könnte abschalten.
                        Edit: Habe es jetzt auch mal mit Edge und v1.3.2 probiert, da ging das Statusfenster auf. 👍
                        Habe meinen Post von oben angepasst da ich wohl doch nicht v1.3.2 sondern die stable installiert hatte. Habe zuvor vergessen auf 'latest' umzustellen. 🙄
                        Passt also alles! Mein Test in einem Proxmox-Container hat reibungslos funktioniert. Super Tool! 👏
                        • simatec
                          simatec Developer Most Active @Dr. Bakterius last edited by
                          @Dr-Bakterius
                          Welche Version hast du installiert?
                          Das Feature gibt es erst ab Version 1.3.2
                          • SRo769
                            SRo769 last edited by
                            Hi, hab mal den Adapter 1.3.2 getestet. Klappt soweit alles (mysql, redis, ccu - alles enthalten - keine Fehlermeldungen). Allerdings habe ich folgendes Problem:
                            Nach dem eigentlichen Backup-Ende kommen die folgenden Log-Einträge dauerhaft:
                            Alle paar Sekunden ein neuer Eintrag- die Redis-Sicherung ist auch nur 1kb groß und lässt sich nicht entpacken. Habe ich so auch noch nicht gehabt. Ist das schon mal woanders aufgetreten?
                            VG Sven
                            • Dr. Bakterius
                              Dr. Bakterius Most Active @simatec last edited by
                              @Dr-Bakterius
                              Sieh mal mein Post direkt ober deinem. 😉 Hab' meinen Fehler schon gefunden gehabt.
                              • JB_Sullivan
                                So, da bin ich wieder : )
                                Ich habe heute erst festgestellt, das meine ganzen Einstellungen für sourceanalytix und history nach dem Backup beim Sonoff Adapter komplett nicht mehr vorhanden sind.
                                Da das ein Haufen Zeug war was ich neu einstellen müsste, kann man das irgendwie einzeln restoren? Wo werden diese Einstellungen üblicherweise gespeichert? Vielleicht ist es ja auch möglich aus der alten ioB Installation die Datei mit diesen Infos einzeln rüber zu kopieren?
                                • simatec
                                  simatec Developer Most Active @JB_Sullivan last edited by simatec
                                  @JB_Sullivan
                                  History Daten kannst du in backitup separat sichern.
                                  Zu den Daten von sourceanalytix müsste @Dutchman eventuell mal was zu sagen
                                  Dutchman 1 Reply Last reply Reply Quote 0
                                  • JB_Sullivan
                                    Das mit dem history Pfad habe ich noch nicht so ganz verstanden.
                                    Da steht bei mir "media/usb/history" drin. Was ist das für ein Pfad? Da wohin gesichert werden soll, oder der Pfad wo das History Verzeichnis liegt (liegen sollte)?
                                    History liegt zumindest bei meiner Windows Installation hier: - \iobroker-data\history
                                    Wie gesagt, das mit der history Sicherung erschließt sich mir noch nicht so wirklich.
                                    • simatec
                                      @JB_Sullivan
                                      Da muss der Pfad eingetragen werden, wo du deine History Daten abgelegt hast.
                                      • JB_Sullivan
                                        @simatec
                                        OK, Danke, das mit dem Pfad Angabe hat schonmal funktioniert. Die history Dateien wurden auch wieder restored.
                                        Der LOG Eintrag aus dem separaten Browser TAB sagt aber ".... abgebrochen".
                                        Das history Backup ist ~35 MB groß.
                                        Log Backitup Restore:
                                        Restore is started ...
                                        [DEBUG] [historyDB] Extracting...
                                        [EXIT] historyDB restore done **** Restore was canceled!! ****
                                        The log can be closed ...
                                        ..... und das schreibt BackItUp in das ioBroker Fenster
                                        Gestartet...
                                        [EXIT] 0
                                        • simatec
                                          @JB_Sullivan
                                          Da ist noch ein kleiner Bug im Webinterface.
                                          Aber das betrifft nur die Ausgabe und ist nicht relevant für den Restore.
                                          Ist auf Github bereits gefixt
                                          • Dutchman
                                            Dutchman Developer Most Active Administrators @simatec last edited by
                                            @JB_Sullivan
                                            @JB_Sullivan
                                            SourceAnalytix speichert alle werte in de States, bedeutet also das die imm BackitUp backup sitzen entweder in den object files oder dem Redis backup je nachdem wie man es eingerichtet hat
                                            backitup backitup backup ccu history mysql redis restore restore backup
                                            170
                                            2779
                                            2285275
