    4. Caught + CHMOD Error
    UNSOLVED Caught + CHMOD Error
      kaifly last edited by Negalein
      ich erhalte im Logfile alle paar Sekunden diese ganzen Error-Meldungen. Da ich doch sehr neu bin im Thema Raspberry PI habe ich leider keine Ahnung, was ich noch ausprobieren kann... Ich hoffe, mir kann hier jemand einen Tipp geben.
      Liebe Grüße
      Kai
      host.raspberrypi	2019-12-02 21:39:17.779	info	Restart adapter system.adapter.info.0 because enabled
      host.raspberrypi	2019-12-02 21:39:17.778	info	instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2019-12-02 21:39:17.777	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.raspberrypi	2019-12-02 21:39:17.777	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.raspberrypi	2019-12-02 21:39:17.777	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:81767)
      host.raspberrypi	2019-12-02 21:39:17.776	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
      host.raspberrypi	2019-12-02 21:39:17.776	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
      host.raspberrypi	2019-12-02 21:39:17.775	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi	2019-12-02 21:39:17.774	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
      host.raspberrypi	2019-12-02 21:39:17.774	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi	2019-12-02 21:39:17.774	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
      host.raspberrypi	2019-12-02 21:39:17.773	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
      host.raspberrypi	2019-12-02 21:39:17.772	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      Gerade auch ein Update auf die aktuelle JS-Controller Version versucht und da klingt es nur so (Auszug...)
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Release/none.node': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Release/obj.target': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Release/obj.target/none.node': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Makefile': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/none.target.mk': Die Operation ist nicht erlaubt
      Hostname
      raspberrypi
      Betriebssystem
      linux
      Architektur
      arm
      CPUs
      Geschwindigkeit
      1400 MHz
      Modell
      ARMv7 Processor rev 4 (v7l)
      RAM
      926.08 MB
      System Betriebszeit
      00:07:15
      Node.js
      v10.16.3 (Es gibt eine neuere Version: v10.17.0)
      NPM
      6.9.0
      Festplatte Größe
      12.6 GB
      Festplatte frei
      5.81 GB
      Anzahl der Adapter
      260
      Betriebszeit
      00:10:23
      Aktive Instanzen
      16
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
        welche js-controller Version ??
          roolix last edited by
          Bei mir dieselben Fehler:
          Hardwaresystem: PI4
          Arbeitsspeicher: 4GB
          Betriebssystem: Debian buster
          Nodejs-Version: 10.19.0
          NPM-Version: 6.13.4
          js-controller: 2.2.8 (macht man doch über iobroker version, oder?)
          Installationsart: Skript (ursprünglich)
          Image genutzt: Ja
          Stoppe ich den Adapter "iobroker Informationsseite" (info.0) verschwinden die Fehler.
          errorr chmod caught
