    2. English
    3. ioBroker general
    4. EACCES: permission denied
    • Akra Bato
      Akra Bato last edited by Akra Bato
      Error EACCES: permission denied happens when I try to install adapters.
      root@wirenboard-AUCPMJ6J:~# iobroker install mqtt
      sudo: unable to resolve host wirenboard-AUCPMJ6J: No such file or directory
      NPM version: 6.11.3
      npm install iobroker.mqtt@2.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCES
      npm ERR! syscall mkdir
      npm ERR! path /home/iobroker
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'
      npm ERR!  { [Error: EACCES: permission denied, mkdir '/home/iobroker']
      npm ERR!   cause:
      npm ERR!    { Error: EACCES: permission denied, mkdir '/home/iobroker'
      npm ERR!      errno: -13,
      npm ERR!      code: 'EACCES',
      npm ERR!      syscall: 'mkdir',
      npm ERR!      path: '/home/iobroker' },
      npm ERR!   isOperational: true,
      npm ERR!   stack: 'Error: EACCES: permission denied, mkdir \'/home/iobroker\'',
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      I've found this topic https://forum.iobroker.net/topic/17206/javascript-adapter-lässt-sich-nicht-mehr-installieren and tried to follow recomendations from it:
      sudo chmod 777 /opt/iobroker
      sudo chown -R $(whoami) ~/.npm
      sudo chown -R $(whoami) ~/.config
      sudo chown -R $(whoami) /opt/iobroker
      also, as alternative:
      sudo chown -R iobroker /opt/iobroker
      All was useless.
      Could you help to solve the problem?
        check this
        curl -sL https://iobroker.net/fix.sh | bash -
        • Akra Bato
          I made it. Problem still exists.
            @Akra-Bato sagte in EACCES: permission denied:
            this is wron also
            check from
            cd /opt/iobroker
            • Akra Bato
              I think the problem is that iobroker don't have rights to make any changes in /home/iobroker directory,
              although I work under root.
                arteck Developer Most Active @Akra Bato last edited by
                @Akra-Bato the folder /home/iobroker is the User folder.... here OK
                the install folder is /opt/iobroker .. OK also..
                • Akra Bato
                  I made some subdirectories manually, but it continues to display error messages with other subdirectories.
                  • AlCalzone
                    AlCalzone Developer @arteck last edited by AlCalzone
                    @arteck sagte in EACCES: permission denied:
                    That command can be executed anywhere. Only for npm install you have to be careful.
                    @Akra-Bato
                    Does this help?
                    sudo chown -R iobroker:iobroker /home/iobroker
                    sudo chmod -R 755 /home/iobroker
                    Did you have any user named iobroker before installing?
                    Akra Bato 1 Reply Last reply Reply Quote 0
                    • Akra Bato
                      Akra Bato @AlCalzone last edited by
                      @AlCalzone , thank you! I solved the problem.
                      adapters mqtt permission
