    4. Script Engine Update Error
    SOLVED Script Engine Update Error
      Jaschkopf last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: RPi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Linux
      Node-Version: v10.17.0
      Nodejs-Version: v10.17.0
      NPM-Version: 6.11.3
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Servus. Bei mir bricht das Update von Script Engine von v4.3.2 auf 4.3.4 mit folgendem Fehler an:
      $ ./iobroker upgrade javascript
      Update javascript from @4.3.2 to @4.3.4
      NPM version: 6.11.3
      npm install iobroker.javascript@4.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat\'',npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat' }
      npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-12-21T13_06_18_408Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.javascript@4.3.4: 243
      ERROR: process exited with code 25
      Anbei auch das Log:
      Kann mir da jemand weiter helfen?
      Glasfaser Homoran 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @Jaschkopf last edited by
        @Jaschkopf
        Du hast keine Rechte …
        Lasse den Fixer vorher mal drüber laufen .
        curl -sL https://iobroker.net/fix.sh | bash -
        • Glasfaser
          @Jaschkopf
            Homoran Global Moderator Administrators @Jaschkopf last edited by
            @Jaschkopf
            Wie alt ist die Installation?
            als root? oder einfacher User installiert?
            Ich würde mal den Fixer drüberjagen.
              Super hat gereicht den fixer laufen zu lassen. Anschließend einmal reboot und das update lief problemlos durch. Viele Dank für die schnelle Hilfe! 👍
              javascript script engine update error
