    4. Bei Zugriff stürzt iobroker admin ab
    SOLVED Bei Zugriff stürzt iobroker admin ab
      ChrisXY last edited by ChrisXY
      hallo,
      nach einen Umzug auf INtel Nuc und 3 Tagen habe ich nun mal einen reboot gemacht.
      Per sudo iobroker start wird iobroker gestartet.
      Alles läuft
      root@iobroker:/opt/iobroker# lsof -i -n -P | grep 8081
      io.admin. 2467 iobroker   25u  IPv6 177056599      0t0  TCP *:8081 (LISTEN)
      Sobald ich aber per Browser drauf will kommt kurz das iobroker admin layout und weg.
      Admin Adapter ist abgestürzt
      Log:
      root@iobroker:/opt/iobroker# node node_modules/iobroker.admin/admin.js --logs
      internal/modules/cjs/loader.js:638
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.admin/admin.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      Hab schon einen admin.2 angelegt bricht auch ab
      Noch mehr logs:
      2019-12-25 22:27:16.191  - info: host.iobroker instance system.adapter.admin.1 started with pid 6191
      TypeError: Cannot read property 'isValidUTF8' of undefined
          at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
          at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
          at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
          at afterWrite (_stream_writable.js:485:3)
          at onwrite (_stream_writable.js:476:7)
          at InflateRaw.afterTransform (_stream_transform.js:94:3)
          at Zlib.processCallback (zlib.js:557:8)
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      2019-12-25 22:27:18.042  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
      2019-12-25 22:27:18.042  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
      2019-12-25 22:27:18.042  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
      2019-12-25 22:27:18.042  - error: host.iobroker Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
      2019-12-25 22:27:18.042  - error: host.iobroker Caught by controller[0]:     at afterWrite (_stream_writable.js:485:3)
      2019-12-25 22:27:18.043  - error: host.iobroker Caught by controller[0]:     at onwrite (_stream_writable.js:476:7)
      2019-12-25 22:27:18.043  - error: host.iobroker Caught by controller[0]:     at InflateRaw.afterTransform (_stream_transform.js:94:3)
      2019-12-25 22:27:18.043  - error: host.iobroker Caught by controller[0]:     at Zlib.processCallback (zlib.js:557:8)
      2019-12-25 22:27:18.043  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2019-12-25 22:27:18.043  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      ================================== > LOG REDIRECT system.adapter.admin.1 => false [Process stopped]
      2019-12-25 22:27:19.317  - error: host.iobroker instance system.adapter.admin.1 terminated with code 156 (156)
      2019-12-25 22:27:19.318  - info: host.iobroker Restart adapter system.adapter.admin.1 because enabled
      ================================== > LOG REDIRECT system.adapter.admin.1 => false [system.adapter.admin.1.logging]
        hab von Proxmox ein Backup Eingespielt ..
        ich glaube es liegt immer noch am Docker auf Nuc umstellung ..
        Hab schon alles mögliche versucht iobroker install. Auch das ganze mit 2. admin
            throw err;
        EDIT: Hab es nun zurückgesetzt bis vor der Zeitanpassung. Meine Uhrzeit war nicht richtig und ich habe dies gemacht:
        https://www.eidenschink.eu/2014/05/uhrzeit-und-zeitzone-proxmox-ubuntu-container-setzen.html
        Denke an dem letzten befehl wird es gelegen haben...
        EDIT2: Hab es nun auf den neuen "Ring" Adapter zurückführen können. Per "iobroker del ring" läuft der Admin weider.
        admin adapter läuft nicht
