    5. wrong type of...
    wrong type of...
      Jetzt hat es mich auch erwischt.
      ich habe
      javascript.0	2019-12-26 13:42:02.610	warn	(1053) at processImmediate (timers.js:658:5)
      javascript.0	2019-12-26 13:42:02.610	warn	(1053) at tryOnImmediate (timers.js:676:5)
      javascript.0	2019-12-26 13:42:02.610	warn	(1053) at runCallback (timers.js:705:18)
      javascript.0	2019-12-26 13:42:02.610	warn	(1053) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
      javascript.0	2019-12-26 13:42:02.610	warn	(1053) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
      javascript.0	2019-12-26 13:42:02.609	warn	(1053) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
      javascript.0	2019-12-26 13:42:02.609	warn	(1053) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
      javascript.0	2019-12-26 13:42:02.609	warn	(1053) at Object.<anonymous> (script.js.Luftdaten_kumulieren:7:3)
      javascript.0	2019-12-26 13:42:02.608	warn	(1053) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      javascript.0	2019-12-26 13:42:02.607	warn	(1053) Wrong type of 0_userdata.0.Umwelt.PM2_5_Summe: "string". Please fix, while deprecated and will not work in next versions.
      Aber ich habe alles kontrolliert und alles ist "number":
        "_id": "0_userdata.0.Umwelt.PM2_5_Summe",
        "type": "state",
        "common": {
          "name": "PM2_5_Summe",
          "role": "value",
          "type": "number",
          "desc": "Manuell erzeugt",
          "read": true,
          "write": true,
          "def": false
        "native": {},
        "user": "system.user.admin",
        "ts": 1577356159237,
        "acl": {
          "object": 1638,
          "owner": "system.user.admin",
          "ownerGroup": "system.group.administrator",
          "state": 1638
      und im Script steht:
      on({id: 'luftdaten.0.34499.SDS_P1', change: "any"}, function (obj) {
        var value = obj.state.val;
        setState("0_userdata.0.Umwelt.PM10_Anzahl"/*PM10_Anzahl*/, (getState("0_userdata.0.Umwelt.PM10_Anzahl").val + 1), true);
        setState("0_userdata.0.Umwelt.PM10_Summe"/*PM10_Summe*/, (getState("0_userdata.0.Umwelt.PM10_Summe").val + getState("luftdaten.0.34499.SDS_P1").val), true);
        setState("0_userdata.0.Umwelt.PM2_5_Anzahl"/*PM2_5_Anzahl*/, (getState("0_userdata.0.Umwelt.PM2_5_Anzahl").val + 1), true);
        setState("0_userdata.0.Umwelt.PM2_5_Summe"/*PM2_5_Summe*/, (getState("luftdaten.0.34499.SDS_P2").val + 1), true);
      schedule("59 23 * * *", function () {
        setState("0_userdata.0.Umwelt.PM10_Tagesmittel"/*PM10_Tagesmittel*/, (getState("0_userdata.0.Umwelt.PM10_Summe").val / getState("0_userdata.0.Umwelt.PM10_Anzahl").val), true);
        setState("0_userdata.0.Umwelt.PM2_5_Tagesmittel"/*PM2_5_Tagesmittel*/, (getState("0_userdata.0.Umwelt.PM2_5_Summe").val / getState("0_userdata.0.Umwelt.PM2_5_Anzahl").val), true);
      Alle diese States sind vom typ number.
        "type": "state",
        "common": {
          "name": "PM2.5",
          "type": "number",
          "role": "value.ppm",
          "unit": "µg/m³",
          "read": true,
          "write": false,
          "custom": {
            "history.0": {
              "enabled": true,
              "changesOnly": true,
              "debounce": "1000",
              "maxLength": "20",
              "retention": 0,
              "changesRelogInterval": "1800",
              "changesMinDelta": 0,
              "aliasId": ""
        "native": {},
        "from": "system.adapter.luftdaten.0",
        "ts": 1577284209810,
        "_id": "luftdaten.0.34499.SDS_P2",
        "acl": {
          "object": 1638,
          "state": 1638
      muss ich trotzdem eine Konvertierung zu Zahl durchführen?
      Jey Cee paul53 ? 3 Replies Last reply Reply Quote 0
      • Jey Cee
        Jey Cee Developer @Homoran last edited by
        @Homoran ja du musst Konvertieren. Es gibt fälle da behandelt js zahlen wie einen String.
          @Homoran sagte:
          enthält offenbar einen String.
          SBorg Homoran 2 Replies Last reply Reply Quote 0
          • SBorg
            SBorg Forum Testing Most Active @paul53 last edited by
            Wahrscheinlich 12,5, nicht 12.5 ...
              @paul53 sagte in wrong type of...:
              @Homoran sagte:
              wie bekomme ich das raus?
              Der Datenpunkt ist vom Typ Number
              Ich denke ich werde sicherheitshalber einen konvert Block dazunehmen
                paul53 @Homoran last edited by paul53
                @Homoran sagte:
                log(typeof getState("luftdaten.0.34499.SDS_P2").val);
                @Homoran sagte in wrong type of...:
                Das sagt nichts darüber aus, welcher Typ tatsächlich in val enthalten ist.
                  Danke!
                  14:32:00.412	info	javascript.0 (1053) Start javascript script.js.typtest
                  14:32:00.416	info	javascript.0 (1053) script.js.typtest: string
                  Obwohl, die Config auf number steht
                    @Homoran sagte:
                    Ein Fall für ein Issue auf Github.
                      Done!
                        Danke an alle!
                        Habe jetzt erst einmal alle States mit "nach Zahl" konvertiert. Läuftjetzt ohne Fehlermeldung.
                        Issue beim Luftdaten-Adapter ist erstellt.
                        @SBorg sagte in wrong type of...:
                        Zumindest nicht sichtbar
                        paul53 K 2 Replies Last reply Reply Quote 0
                          @Homoran sagte:
                          Du meinst alle Werte aus "luftdaten.0" ? Das wäre ausreichend.
                            Homoran Global Moderator Administrators @paul53 last edited by Homoran
                            Danke!
                            Da war ich mir eben nicht sicher, ob die States, in denen er das Ergebnis aus einer "Text-Addition" eingetragen hatte nicht auch den falschen Typ haben.
                            Mit diesen Werten rechnet er ja nachher weiter.
                              @Homoran sagte:
                              Ja, das muss einmalig korrigiert werden.
                                Dann setze ich alles auf 0 und beginne von vorn.
                                Da stimmt sowie so etwas nicht 😉
                                Die potentiellen Tagesmittelwerte sind unplausibel.
                                  @Homoran sagte:
                                  Wenn bisher eine String-Verkettung anstelle einer Addition erfolgte, können die Werte nicht stimmen.
                                  Homoran SBorg 2 Replies Last reply Reply Quote 0
                                    Das habe ich mir auch gedacht
                                    • SBorg
                                      @Homoran sagte:
                                      Das war wohl schon immer String:
                                      self.setState(path + 'SDS_' + obj.value_type, {val: obj.value, ack: true});
                                      Ich finde aber nix was obj.value prüft oder als Zahl konvertiert. Mein JS ist "so naja", aber was ich dabei nicht verstehe, die Funktion ist für 2.5 + 10, warum meckert er nur die 2.5 an (10 ist, wie es die Funktion ja auch vorgibt, ebenfalls String)?
                                        Homoran Global Moderator Administrators @SBorg last edited by
                                        @SBorg
                                        er hatte beides angemeckert.
                                        Ich hatte nur das eine als Beispiel genommen
                                        • SBorg
                                          SBorg Forum Testing Most Active @Homoran last edited by
                                          @Homoran Ok, danke, dann raff ich das auch ^^
                                          Muss Matthias fixen... 🙂
                                            paul53 @SBorg last edited by
                                            @SBorg sagte:
                                            Ist der Code aus dem Adapter ?
                                            Wenn es eine Zahl sein soll, wie es common.type = 'number' vorgibt, muss gewandelt werden.
                                            self.setState(path + 'SDS_' + obj.value_type, {val: parseFloat(obj.value), ack: true});
                                            blockly
                                            1469
