    5. TR-064 community Adapter - Wie mit javascript?
      LoxDUS last edited by
      Liebe Gemeinde,
      ich bekomme es einfach nicht hin mit dem TR064 community Adapter über den "command" Datenpunkt bestimmte Werte aus der Fritzbox auszulesen.
      Kann mir jemand ein Codebeispiel in Javascript geben wie man z.B. die Externe IP-Adresse ausließt?
      Was ich bisher versucht habe:
      //command = '{"service": "urn:dslforum-org:service:WANCommonInterfaceConfig:1","action": "NewByteReceiveRate","params": {}}';
      // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:GetExternalIPAddress","action": "NewExternalIPAddress", "params":{}', true);
      // NOK setState('tr-064-community.0.states.command', '{"service": "urn:WANCIfConfig-com:serviceId:WANCommonInterfaceConfig1", "action": "GetTotalBytesSent", "params": { "NewTotalBytesSent"}};', true);
      // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WLANConfiguration:1","action": "X_AVM-DE_SetWPSConfig","params": {"NewX_AVM-DE_WPSMode": "pbc","NewX_AVM-DE_WPSClientPIN": ""}}', true);
      // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetGenericPortMappingEntry","params": {"NewExternalPort": ""}}', true);
      setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetInfo","params": {"": ""}}',  (err, state) => {
        log("SetState: " + JSON.stringify(state));
          for(var index in state) {
                  log(index);
                  log(JSON.stringify(state[index]));
      // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetInfo","params": {"": ""}}',  true);
      // NOK setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetExternalIPAddress","params": {"NewExternalIPAddress": ""}};', true);
      setState('tr-064-community.0.states.command', '{"service": "urn:dslforum-org:service:WANIPConnection:1","action": "GetExternalIPAddress","params": {"NewExternalIPAddress": ""}};',  (err, status) => {
          if(err) log("Fehler:" + err);
          log("SetState: " + JSON.stringify(status));
          getState("tr-064-community.0.states.commandResult", (err, state) => {
              log("GetState: " + JSON.stringify(state));
                      log(index);
      Dann wird aber immer die irgendwann mal einmalig funktionierende GetInfo Action ausgegeben. Der Wert in "CommandResult" ändert sich irgendwie gar nicht mehr.
      14:28:05.828	info	javascript.1 (14753) script.js.common.Testumgebung: SetState: undefined
      14:28:05.830	info	javascript.1 (14753) script.js.common.Testumgebung: GetState: {"val":"{\"NewEnable\":\"1\",\"NewConnectionStatus\":\"Connected\",\"NewPossibleConnectionTypes\":\"IP_Routed, IP_Bridged\",\"NewConnectionType\":\"IP_Routed\",\"NewName\":\"internet\",\"NewUptime\":\"5687998\",\"NewLastConnectionError\":\"ERROR_NONE\",\"NewRSIPAvailable\":\"0\",\"NewNATEnabled\":\"1\",\"NewExternalIPAddress\":\"...rausgelöscht...\",\"NewDNSServers\":\"...rausgelöscht..., ...rausgelöscht...\",\"NewMACAddress\":\"rausgelöscht\",\"NewConnectionTrigger\":\"OnDemand\",\"NewRouteProtocolRx\":\"Off\",\"NewDNSEnabled\":\"1\",\"NewDNSOverrideAllowed\":\"1\"}","ack":true,"ts":1577866696482,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1577866696482}
      14:28:05.832	info	javascript.1 (14753) script.js.common.Testumgebung: val
      14:28:05.833	info	javascript.1 (14753) script.js.common.Testumgebung: "{\"NewEnable\":\"1\",\"NewConnectionStatus\":\"Connected\",\"NewPossibleConnectionTypes\":\"IP_Routed, IP_Bridged\",\"NewConnectionType\":\"IP_Routed\",\"NewName\":\"internet\",\"NewUptime\":\"5687998\",\"NewLastConnectionError\":\"ERROR_NONE\",\"NewRSIPAvailable\":\"0\",\"NewNATEnabled\":\"1\",\"NewExternalIPAddress\":\"...rausgelöscht...\",\"NewDNSServers\":\"...rausgelöscht..., ...rausgelöscht...\",\"NewMACAddress\":\"....rausgelöscht...\",\"NewConnectionTrigger\":\"OnDemand\",\"NewRouteProtocolRx\":\"Off\",\"NewDNSEnabled\":\"1\",\"NewDNSOverrideAllowed\":\"1\"}"
      14:28:05.834	info	javascript.1 (14753) script.js.common.Testumgebung: ack
      14:28:05.834	info	javascript.1 (14753) script.js.common.Testumgebung: true
      14:28:05.835	info	javascript.1 (14753) script.js.common.Testumgebung: ts
      14:28:05.835	info	javascript.1 (14753) script.js.common.Testumgebung: 1577866696482
      14:28:05.835	info	javascript.1 (14753) script.js.common.Testumgebung: q
      14:28:05.836	info	javascript.1 (14753) script.js.common.Testumgebung: 0
      14:28:05.836	info	javascript.1 (14753) script.js.common.Testumgebung: from
      14:28:05.837	info	javascript.1 (14753) script.js.common.Testumgebung: "system.adapter.tr-064-community.0"
      14:28:05.837	info	javascript.1 (14753) script.js.common.Testumgebung: user
      14:28:05.837	info	javascript.1 (14753) script.js.common.Testumgebung: "system.user.admin"
      14:28:05.838	info	javascript.1 (14753) script.js.common.Testumgebung: lc
      14:28:05.838	info	javascript.1 (14753) script.js.common.Testumgebung: 1577866696482
      Ich brauche nur ein einfaches Beispiel wie das gehen soll. Wie geschrieben ich habe das einmalig hinbekommen aber seit dem ändert sich der Wert im datenpunkt "CommandResult" nicht mehr auch nicht wenn ich andere Parameter über den TR-064 aus der Fritzbox abfragen will.
      Vielen Dank,
      Dominik F. 1 Reply Last reply Reply Quote 0
      • Dominik F.
        Dominik F. @LoxDUS last edited by
        @LoxDUS
        die externe IP Adresse ist bei mir unter folgendem Datenpunkt zu finden :
        tr-064-community.0.states.externalIP.
        Dafür brauchst du kein Script schreiben.
          LoxDUS @Dominik F. last edited by
          @Dominik-F
          Bei mir ist dieser Datenpunkt leer, wahrscheinlich weil ich von UnityMedia nur eine IP V6 IpAdresse bekomme. Es geht mir aber nicht unbedingt um die Externe Adresse sondern um z.B Download und Upload Raten und vor allem um den Status der Internetanbindung weil hier schon mal öfters bei UnityMedia die INternetverbindung wegbricht.
          Dominik F. bahnuhr 2 Replies Last reply Reply Quote 0
          • Dominik F.
            @LoxDUS
            okay, dann bin ich bei dem Adapter raus. Ich ziehe mir die Download und Upload raten und sonstiges aus dem UPNP Adapter.
              Weiß denn niemand wie man über den TR-064 Adapter per command Datenpunkt Werte aus der Fritzbox abfragen kann?
              • bahnuhr
                bahnuhr Forum Testing Most Active @LoxDUS last edited by
                @LoxDUS sagte in TR-064 community Adapter - Wie mit javascript?:
                Ich habe ausschließlich ipv6. Bei mir ist dieser Punkt befüllt.
                communication javascript
