    2. English
    3. ioBroker general
    4. Conected to z-wave: false
      BrokinMold last edited by
      I am wondering why I have a yellow led light on my z-wave instance. when I hover over it it says:
      Connected to host: true
      Heartbeat:true
      Connected to z-wave: false
      Here is my Log:
      host.GatewayTA7 2020-01-03 02:18:07.735 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      host.GatewayTA7 2020-01-03 02:12:38.306 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      zwave.0 2020-01-03 02:12:14.583 info (612) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
      zwave.0 2020-01-03 02:09:22.686 info (612) node ready nodeID: 1, nodeInfo: {"manufacturer":"AEON Labs","manufacturerid":"0x0086","product":"ZW090 Z-Stick Gen5 US","producttype":"0x0101","productid":"0x005a","type":"Static PC Controller"
      zwave.0 2020-01-03 02:09:22.661 info (612) driver ready: homeid = ffc0bb34
      zwave.0 2020-01-03 02:09:22.660 info (612) scanning homeid=0xffc0bb34...
      info.0 2020-01-03 02:08:41.952 error (591) Error: getaddrinfo EAI_AGAIN raw.githubusercontent.com raw.githubusercontent.com:443
      info.0 2020-01-03 02:08:40.155 info (591) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.15.2
      admin.0 2020-01-03 02:08:26.327 info (566) Use link "http://localhost:8081" to configure.
      admin.0 2020-01-03 02:08:26.327 info (566) http server listening on port 8081
      admin.0 2020-01-03 02:08:26.191 info (566) received all objects
      admin.0 2020-01-03 02:08:25.898 info (566) requesting all objects
      admin.0 2020-01-03 02:08:25.898 info (566) requesting all states
      admin.0 2020-01-03 02:08:25.832 info (566) starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.15.2
      zwave.0 2020-01-03 02:08:24.681 info (612) starting. Version 1.7.3 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.15.2
      host.GatewayTA7 2020-01-03 02:08:21.579 info instance system.adapter.zwave.0 started with pid 612
      discovery.0 2020-01-03 02:08:19.065 info (578) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.15.2
      host.GatewayTA7 2020-01-03 02:08:17.611 info instance system.adapter.info.0 started with pid 591
      host.GatewayTA7 2020-01-03 02:08:13.578 info instance system.adapter.discovery.0 started with pid 578
      host.GatewayTA7 2020-01-03 02:08:09.692 info instance system.adapter.admin.0 started with pid 566
      host.GatewayTA7 2020-01-03 02:08:09.526 info starting 4 instances
      host.GatewayTA7 2020-01-03 02:08:09.517 info 4 instances found
      host.GatewayTA7 2020-01-03 02:08:09.457 info connected to Objects and States
      host.GatewayTA7 2020-01-03 02:08:09.072 info ip addresses:
      host.GatewayTA7 2020-01-03 02:08:09.070 info hostname: GatewayTA7, node: v10.15.2
      host.GatewayTA7 2020-01-03 02:08:09.070 info Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
      host.GatewayTA7 2020-01-03 02:08:09.061 info iobroker.js-controller version 2.1.1 js-controller starting
      1.2k
      z-wave aeotec gen 5 z-stick
