    4. (gelöst)VIS läuft nicht mehr
    • DirkK
      DirkK last edited by
      Hallo Zusammen,
      ich hab vorhin 2 Updates durchgeführt und seit dem läuft Flot nicht mehr.
      Hier mal der Log:
      hm-rpc-1 2016-06-23 20:00:49.371 info Connected
      hm-rpc-1 2016-06-23 20:00:49.330 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 20:00:49.047 info Disconnected
      hm-rpc-1 2016-06-23 19:59:49.029 info Connected
      hm-rpc-1 2016-06-23 19:59:48.985 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:59:48.635 info Disconnected
      hm-rpc-1 2016-06-23 19:58:48.615 info Connected
      hm-rpc-1 2016-06-23 19:58:48.566 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:58:48.259 info Disconnected
      hm-rpc-1 2016-06-23 19:57:48.233 info Connected
      hm-rpc-1 2016-06-23 19:57:48.193 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:57:47.886 info Disconnected
      hm-rpc-1 2016-06-23 19:56:47.869 info Connected
      hm-rpc-1 2016-06-23 19:56:47.822 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:56:47.510 info Disconnected
      fritzbox-0 2016-06-23 19:56:02.393 info data from 192.168.178.1: 23.06.16 19:56:02;DISCONNECT;1;546;
      hm-rpc-1 2016-06-23 19:55:47.496 info Connected
      hm-rpc-1 2016-06-23 19:55:47.439 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:55:47.167 info Disconnected
      history-0 2016-06-23 19:55:36.361 info enabled logging of hm-rpc.0.MEQ0706275.1.POWER
      history-0 2016-06-23 19:55:36.359 info enabled logging of hm-rpc.0.MEQ0706275.1.ENERGY_COUNTER
      history-0 2016-06-23 19:55:36.358 info enabled logging of hm-rpc.0.MEQ0833081.1.TEMPERATURE
      history-0 2016-06-23 19:55:36.356 info enabled logging of hm-rpc.0.MEQ0833081.1.HUMIDITY
      history-0 2016-06-23 19:55:36.352 info enabled logging of hm-rpc.0.NEQ0124755.1.TEMPERATURE
      history-0 2016-06-23 19:55:36.269 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.history
      host-RPi2 2016-06-23 19:55:33.183 info instance system.adapter.history.0 started with pid 751
      host-RPi2 2016-06-23 19:55:30.722 info instance system.adapter.history.0 terminated with code 0 (OK)
      host-RPi2 2016-06-23 19:55:30.616 info stopInstance system.adapter.history.0 killing pid 694
      host-RPi2 2016-06-23 19:55:30.615 info stopInstance system.adapter.history.0
      host-RPi2 2016-06-23 19:55:30.606 info object change system.adapter.history.0
      hm-rpc-1 2016-06-23 19:54:47.148 info Connected
      hm-rpc-1 2016-06-23 19:54:47.091 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:54:46.816 info Disconnected
      host-RPi2 2016-06-23 19:54:09.905 info object change system.adapter.flot.0
      host-RPi2 2016-06-23 19:54:02.397 info object change system.adapter.flot.0
      hm-rpc-1 2016-06-23 19:53:46.801 info Connected
      hm-rpc-1 2016-06-23 19:53:46.762 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:53:46.469 info Disconnected
      hm-rpc-1 2016-06-23 19:52:46.449 info Connected
      hm-rpc-1 2016-06-23 19:52:46.397 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:52:46.088 info Disconnected
      hm-rpc-1 2016-06-23 19:51:46.072 info Connected
      hm-rpc-1 2016-06-23 19:51:46.037 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:51:45.764 info Disconnected
      hm-rpc-1 2016-06-23 19:50:45.749 info Connected
      hm-rpc-1 2016-06-23 19:50:45.692 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:50:45.417 info Disconnected
      hm-rpc-1 2016-06-23 19:49:45.404 info Connected
      hm-rpc-1 2016-06-23 19:49:45.353 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:49:45.028 info Disconnected
      hm-rpc-1 2016-06-23 19:48:45.011 info Connected
      hm-rpc-1 2016-06-23 19:48:44.915 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:48:44.619 info Disconnected
      hm-rpc-1 2016-06-23 19:47:44.597 info Connected
      hm-rpc-1 2016-06-23 19:47:44.553 info binrpc -> listDevices 3
      hm-rpc-1 2016-06-23 19:47:44.215 info Disconnected
      die Adapter laufen alle. Nur das die Daten nicht mehr geschrieben werden.
      Könnte mir bitte jemand helfen?
      Gruß Dirk
        Von flot ist in dem Log nichts zu sehen.
        Dafür schaltet sich dein rpc dauernd an und aus.
        Welche adapter hast du denn upgedatet?
        Und wie?
        • DirkK
          Hallo Rainer,
          ich weiß auch nicht warum der sich dauernd abschaltet. Ich hab irgendwas mit der Logik Schicht geupdatet ich glaub der ReGa war dabei,
          ich kann aber erst morgen noch mal genau nachsehen, da ich gerade zur Arbeit bin. Auf alle fälle hab ich aus der Adapterliste herraus erneuert.
          Gruß Dirk
            Ein Reboot ist vielleicht die schnelle Lösung
            • DirkK
              Ich glaub jetzt weiß ich wieder, den HomeMatic ReGaHSS und den HomeMatic RPC hab ich erneuert.
              Hilft das?
              Ansonsten muß ich den Logschnipsel noch mal suchen.
              Gruß Dirk
              • DirkK
                Hab ich bereits 2mal getan. Mach ich eigentlich immer nach einem Update.
                Gruß Dirk
                  Das Passt immerhin zu dem Effekt.
                  Aber das passiert normalerweise nicht bei einem Update.
                  Vielleicht solltest du wirklich mal rebooten.
                  Und dann nachsehen ob es im Log warn und Errors gibt.
                  • DirkK
                    Ok, dann bis morgen, nach der Schicht. Dir noch einen schönen warmen Abend.
                    Dirk
                      …und stell mal im hm rpc von BIN-RPC auf XML-RPC um.
                      • DirkK
                        Danke Rainer, habs probiert, leider kein erfolg im gegenteil noch mehr Fehler.
                        Ich sende gleich eine neue Log, vom kompletten reboot.
                        Gruß Dirk
                        • DirkK
                          Hier der log ich hoffe ist nicht zu unübersichtlich:
                          hm-rpc.1 2016-06-24 15:48:15.068 info hm-rpc.1 Connected
                          hm-rpc.1 2016-06-24 15:48:15.019 info hm-rpc.1 binrpc -> listDevices 3
                          hm-rpc.1 2016-06-24 15:48:14.756 info hm-rpc.1 Disconnected
                          hm-rpc.0 2016-06-24 15:47:48.869 error hm-rpc.0 Socket error: Error: read ECONNRESET
                          hm-rpc.1 2016-06-24 15:47:14.742 info hm-rpc.1 Connected
                          hm-rpc.1 2016-06-24 15:47:14.690 info hm-rpc.1 binrpc -> listDevices 3
                          hm-rpc.1 2016-06-24 15:47:14.430 info hm-rpc.1 Disconnected
                          hm-rpc.1 2016-06-24 15:46:14.389 info hm-rpc.1 Connected
                          hm-rpc.1 2016-06-24 15:46:14.339 info hm-rpc.1 binrpc -> listDevices 3
                          hm-rpc.1 2016-06-24 15:46:14.054 info hm-rpc.1 Disconnected
                          hm-rpc-0 2016-06-24 15:45:31.104 error Socket error: Error: read ECONNRESET
                          hm-rpc-1 2016-06-24 15:45:14.018 info Connected
                          hm-rpc-1 2016-06-24 15:45:13.984 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:45:13.659 info Disconnected
                          admin-0 2016-06-24 15:45:02.569 info Repository received successfully.
                          host-RPi2 2016-06-24 15:45:02.190 warn warning: Timeout by read all package.json (87) seconds
                          host-RPi2 2016-06-24 15:44:34.643 info instance system.adapter.vis.0 terminated while should be started once
                          vis-0 2016-06-24 15:44:24.913 info starting. Version 0.10.5 in /opt/iobroker/node_modules/iobroker.vis
                          history-0 2016-06-24 15:44:17.091 info enabled logging of hm-rpc.0.MEQ0706275.1.POWER
                          history-0 2016-06-24 15:44:17.089 info enabled logging of hm-rpc.0.MEQ0706275.1.ENERGY_COUNTER
                          history-0 2016-06-24 15:44:17.087 info enabled logging of hm-rpc.0.MEQ0833081.1.TEMPERATURE
                          history-0 2016-06-24 15:44:17.085 info enabled logging of hm-rpc.0.MEQ0833081.1.HUMIDITY
                          history-0 2016-06-24 15:44:17.077 info enabled logging of hm-rpc.0.NEQ0124755.1.TEMPERATURE
                          history-0 2016-06-24 15:44:16.982 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.history
                          host-RPi2 2016-06-24 15:44:14.519 info instance system.adapter.history.0 started with pid 683
                          hm-rpc-1 2016-06-24 15:44:13.630 info Connected
                          hm-rpc-1 2016-06-24 15:44:13.559 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:44:13.402 info binrpc client is trying to connect to 192.168.178.21:8701 with ["xmlrpc_bin://0.0.0.0:8701","hm-rpc.1"]
                          hm-rpc-1 2016-06-24 15:44:13.396 info binrpc server is trying to listen on 0.0.0.0:8701
                          hm-rpc-1 2016-06-24 15:44:12.990 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                          host-RPi2 2016-06-24 15:44:10.521 info instance system.adapter.hm-rpc.1 started with pid 674
                          host-RPi2 2016-06-24 15:44:08.374 info instance system.adapter.ical.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:44:04.531 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                          dwd-0 2016-06-24 15:44:03.027 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
                          ical-0 2016-06-24 15:44:00.676 info processing URL: Dirk Kuhl https://calendar.google.com/calendar/ical/dirkkuhl%40gmail.com/private-3057398946f84443c8f01a177bf408d2/basic.ics
                          fritzbox-0 2016-06-24 15:43:59.959 info adapter connected to fritzbox: 192.168.178.1
                          fritzbox-0 2016-06-24 15:43:59.833 info try to connect: 192.168.178.1
                          fritzbox-0 2016-06-24 15:43:59.743 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox
                          host-RPi2 2016-06-24 15:43:58.533 info instance system.adapter.dwd.0 started with pid 661
                          host-RPi2 2016-06-24 15:43:58.510 info instance scheduled system.adapter.dwd.0 3 * * * *
                          ical-0 2016-06-24 15:43:57.988 info starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
                          host-RPi2 2016-06-24 15:43:55.398 info instance system.adapter.fritzbox.0 started with pid 652
                          host-RPi2 2016-06-24 15:43:51.251 info instance system.adapter.ical.0 started with pid 647
                          host-RPi2 2016-06-24 15:43:51.225 info instance scheduled system.adapter.ical.0 1,5 * * *
                          hm-rega-0 2016-06-24 15:43:48.776 info got state values
                          hm-rega-0 2016-06-24 15:43:47.034 info request state values
                          hm-rega-0 2016-06-24 15:43:47.031 info deleted 0 variables
                          hm-rega-0 2016-06-24 15:43:47.029 info added/updated 15 variables
                          hm-rega-0 2016-06-24 15:43:46.891 info got 15 variables
                          hm-rega-0 2016-06-24 15:43:46.504 info deleted 0 programs
                          hm-rega-0 2016-06-24 15:43:46.503 info added/updated 13 programs
                          hm-rega-0 2016-06-24 15:43:46.387 info got 13 programs
                          hm-rega-0 2016-06-24 15:43:46.335 info renamed hm-rpc.1.CUX9100001 to "Mail"
                          hm-rega-0 2016-06-24 15:43:46.313 info renamed hm-rpc.1.CUX9100001.0 to "Mail:0"
                          hm-rega-0 2016-06-24 15:43:46.296 info renamed hm-rpc.1.CUX9100001.1 to "Mail:1"
                          hm-rega-0 2016-06-24 15:43:44.866 info added/updated rooms to enum.rooms
                          hm-rega-0 2016-06-24 15:43:44.737 info added/updated functions to enum.functions
                          hm-rega-0 2016-06-24 15:43:44.517 info added/updated 0 favorites to enum.favorites
                          hm-rega-0 2016-06-24 15:43:44.421 info time difference local-ccu 0s
                          hm-rega-0 2016-06-24 15:43:44.302 info ReGaHSS 192.168.178.21 up
                          hm-rega-0 2016-06-24 15:43:41.261 info subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                          hm-rega-0 2016-06-24 15:43:41.212 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rega
                          hm-rpc-0 2016-06-24 15:43:43.919 info binrpc client is trying to connect to 192.168.178.21:2001 with ["xmlrpc_bin://0.0.0.0:2001","hm-rpc.0"]
                          hm-rpc-0 2016-06-24 15:43:43.913 info binrpc server is trying to listen on 0.0.0.0:2001
                          hm-rpc-0 2016-06-24 15:43:42.941 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                          host-RPi2 2016-06-24 15:43:40.124 info instance system.adapter.hm-rpc.0 started with pid 634
                          hmm-0 2016-06-24 15:43:36.188 info Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
                          hmm-0 2016-06-24 15:43:36.123 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.hmm
                          host-RPi2 2016-06-24 15:43:18.092 info instance system.adapter.hm-rega.0 started with pid 616
                          web-0 2016-06-24 15:43:16.852 info http server listening on port 8082
                          web-0 2016-06-24 15:43:16.838 info socket.io server listening on port 8082
                          host-RPi2 2016-06-24 15:43:16.477 info Update repository "default" under "conf/sources-dist.json"
                          admin-0 2016-06-24 15:43:15.943 info received all objects
                          web-0 2016-06-24 15:43:15.085 info starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.web
                          admin-0 2016-06-24 15:43:14.968 info received all states
                          host-RPi2 2016-06-24 15:43:14.260 info instance system.adapter.hmm.0 started with pid 607
                          admin-0 2016-06-24 15:43:12.660 info Use link "http://localhost:8081" to configure.
                          admin-0 2016-06-24 15:43:12.658 info http server listening on port 8081
                          admin-0 2016-06-24 15:43:12.650 info Request actual repository...
                          admin-0 2016-06-24 15:43:12.645 info requesting all objects
                          admin-0 2016-06-24 15:43:12.637 info requesting all states
                          admin-0 2016-06-24 15:43:12.449 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.admin
                          host-RPi2 2016-06-24 15:43:09.376 info instance system.adapter.web.0 started with pid 598
                          host-RPi2 2016-06-24 15:43:05.470 info instance system.adapter.admin.0 started with pid 502
                          host-RPi2 2016-06-24 15:43:05.343 info starting 16 instances
                          host-RPi2 2016-06-24 15:43:05.337 info 20 instances found
                          host-RPi2 2016-06-24 15:43:05.295 info InMemoryDB connected
                          inMem-objects 2016-06-24 15:43:05.267 info listening on port 9001
                          inMem-states 2016-06-24 15:43:04.866 info listening on port 9000
                          host-RPi2 2016-06-24 15:43:04.667 info ip addresses: fe80::a809:eb38:e347:bcd3
                          host-RPi2 2016-06-24 15:43:04.663 info hostname: RPi2
                          host-RPi2 2016-06-24 15:43:04.661 info Copyright (c) 2014-2016 bluefox, hobbyquaker
                          host-RPi2 2016-06-24 15:43:04.634 info iobroker.js-controller version 0.9.0 js-controller starting
                          host-RPi2 2016-06-24 15:42:56.633 info terminated
                          host-RPi2 2016-06-24 15:42:56.556 warn stopInstance system.adapter.text2command.0 not running
                          host-RPi2 2016-06-24 15:42:56.555 info stopInstance system.adapter.text2command.0
                          host-RPi2 2016-06-24 15:42:56.555 warn stopInstance system.adapter.telegram.0 not running
                          host-RPi2 2016-06-24 15:42:56.555 info stopInstance system.adapter.telegram.0
                          host-RPi2 2016-06-24 15:42:56.555 info stopInstance system.adapter.vis.0
                          host-RPi2 2016-06-24 15:42:56.554 info stopInstance system.adapter.vis-metro.0
                          host-RPi2 2016-06-24 15:42:56.554 warn stopInstance system.adapter.history.0 not running
                          host-RPi2 2016-06-24 15:42:56.554 info stopInstance system.adapter.history.0
                          host-RPi2 2016-06-24 15:42:56.553 warn stopInstance system.adapter.hm-rpc.1 not running
                          host-RPi2 2016-06-24 15:42:56.553 info stopInstance system.adapter.hm-rpc.1
                          host-RPi2 2016-06-24 15:42:56.552 warn stopInstance system.adapter.sayit.0 not running
                          host-RPi2 2016-06-24 15:42:56.552 info stopInstance system.adapter.sayit.0
                          host-RPi2 2016-06-24 15:42:56.551 info stopInstance system.adapter.vis-plumb.0
                          host-RPi2 2016-06-24 15:42:56.550 info stopInstance system.adapter.vis-fancyswitch.0
                          host-RPi2 2016-06-24 15:42:56.548 warn stopInstance system.adapter.dwd.0 not scheduled
                          host-RPi2 2016-06-24 15:42:56.529 info stopInstance system.adapter.dwd.0
                          host-RPi2 2016-06-24 15:42:56.523 warn stopInstance system.adapter.fritzbox.0 not running
                          host-RPi2 2016-06-24 15:42:56.523 info stopInstance system.adapter.fritzbox.0
                          host-RPi2 2016-06-24 15:42:56.522 warn stopInstance system.adapter.ical.0 not scheduled
                          host-RPi2 2016-06-24 15:42:56.520 info stopInstance system.adapter.ical.0
                          host-RPi2 2016-06-24 15:42:56.520 info stopInstance system.adapter.vis-timeandweather.0
                          host-RPi2 2016-06-24 15:42:56.519 info stopInstance system.adapter.vis-hqwidgets.0
                          host-RPi2 2016-06-24 15:42:56.519 warn stopInstance system.adapter.hm-rpc.0 not running
                          host-RPi2 2016-06-24 15:42:56.519 info stopInstance system.adapter.hm-rpc.0
                          host-RPi2 2016-06-24 15:42:56.518 warn stopInstance system.adapter.hm-rega.0 not running
                          host-RPi2 2016-06-24 15:42:56.518 info stopInstance system.adapter.hm-rega.0
                          host-RPi2 2016-06-24 15:42:56.518 warn stopInstance system.adapter.hmm.0 not running
                          host-RPi2 2016-06-24 15:42:56.517 info stopInstance system.adapter.hmm.0
                          host-RPi2 2016-06-24 15:42:56.517 warn stopInstance system.adapter.web.0 not running
                          host-RPi2 2016-06-24 15:42:56.517 info stopInstance system.adapter.web.0
                          host-RPi2 2016-06-24 15:42:56.516 warn stopInstance system.adapter.admin.0 not running
                          host-RPi2 2016-06-24 15:42:56.516 info stopInstance system.adapter.admin.0
                          host-RPi2 2016-06-24 15:42:56.514 info received SIGTERM
                          host-RPi2 2016-06-24 15:42:55.898 info terminated
                          host-RPi2 2016-06-24 15:42:55.677 info terminated
                          host-RPi2 2016-06-24 15:42:55.575 info instance system.adapter.hmm.0 terminated with code 0 (OK)
                          hmm-0 2016-06-24 15:42:55.557 info terminating
                          host-RPi2 2016-06-24 15:42:55.541 info stopInstance system.adapter.hmm.0 killing pid 607
                          host-RPi2 2016-06-24 15:42:55.540 warn stopInstance system.adapter.text2command.0 not running
                          host-RPi2 2016-06-24 15:42:55.539 info stopInstance system.adapter.text2command.0
                          host-RPi2 2016-06-24 15:42:55.538 warn stopInstance system.adapter.telegram.0 not running
                          host-RPi2 2016-06-24 15:42:55.537 info stopInstance system.adapter.telegram.0
                          host-RPi2 2016-06-24 15:42:55.537 info stopInstance system.adapter.vis.0
                          host-RPi2 2016-06-24 15:42:55.537 info stopInstance system.adapter.vis-metro.0
                          host-RPi2 2016-06-24 15:42:55.536 warn stopInstance system.adapter.history.0 not running
                          host-RPi2 2016-06-24 15:42:55.536 info stopInstance system.adapter.history.0
                          host-RPi2 2016-06-24 15:42:55.536 warn stopInstance system.adapter.hm-rpc.1 not running
                          host-RPi2 2016-06-24 15:42:55.535 info stopInstance system.adapter.hm-rpc.1
                          host-RPi2 2016-06-24 15:42:55.535 warn stopInstance system.adapter.sayit.0 not running
                          host-RPi2 2016-06-24 15:42:55.533 info stopInstance system.adapter.sayit.0
                          host-RPi2 2016-06-24 15:42:55.532 info stopInstance system.adapter.vis-plumb.0
                          host-RPi2 2016-06-24 15:42:55.532 info stopInstance system.adapter.vis-fancyswitch.0
                          host-RPi2 2016-06-24 15:42:55.531 warn stopInstance system.adapter.dwd.0 not scheduled
                          host-RPi2 2016-06-24 15:42:55.531 info stopInstance system.adapter.dwd.0
                          host-RPi2 2016-06-24 15:42:55.529 warn stopInstance system.adapter.fritzbox.0 not running
                          host-RPi2 2016-06-24 15:42:55.529 info stopInstance system.adapter.fritzbox.0
                          host-RPi2 2016-06-24 15:42:55.528 warn stopInstance system.adapter.ical.0 not scheduled
                          host-RPi2 2016-06-24 15:42:55.527 info stopInstance system.adapter.ical.0
                          host-RPi2 2016-06-24 15:42:55.527 info stopInstance system.adapter.vis-timeandweather.0
                          host-RPi2 2016-06-24 15:42:55.527 info stopInstance system.adapter.vis-hqwidgets.0
                          host-RPi2 2016-06-24 15:42:55.526 warn stopInstance system.adapter.hm-rpc.0 not running
                          host-RPi2 2016-06-24 15:42:55.525 info stopInstance system.adapter.hm-rpc.0
                          host-RPi2 2016-06-24 15:42:55.525 warn stopInstance system.adapter.hm-rega.0 not running
                          host-RPi2 2016-06-24 15:42:55.524 info stopInstance system.adapter.hm-rega.0
                          host-RPi2 2016-06-24 15:42:55.516 info stopInstance system.adapter.hmm.0
                          host-RPi2 2016-06-24 15:42:55.516 warn stopInstance system.adapter.web.0 not running
                          host-RPi2 2016-06-24 15:42:55.515 info stopInstance system.adapter.web.0
                          host-RPi2 2016-06-24 15:42:55.513 warn stopInstance system.adapter.admin.0 not running
                          host-RPi2 2016-06-24 15:42:55.512 info stopInstance system.adapter.admin.0
                          host-RPi2 2016-06-24 15:42:55.510 info received SIGTERM
                          host-RPi2 2016-06-24 15:42:55.105 info instance system.adapter.fritzbox.0 terminated with code 0 (OK)
                          fritzbox-0 2016-06-24 15:42:55.084 info terminating
                          host-RPi2 2016-06-24 15:42:54.783 info instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:42:54.753 info instance system.adapter.web.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:42:54.750 info instance system.adapter.history.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:42:54.748 info instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:42:54.745 info instance system.adapter.admin.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:42:54.561 warn stopInstance system.adapter.text2command.0 not running
                          host-RPi2 2016-06-24 15:42:54.560 info stopInstance system.adapter.text2command.0
                          host-RPi2 2016-06-24 15:42:54.559 warn stopInstance system.adapter.telegram.0 not running
                          host-RPi2 2016-06-24 15:42:54.558 info stopInstance system.adapter.telegram.0
                          host-RPi2 2016-06-24 15:42:54.554 info stopInstance system.adapter.vis.0
                          host-RPi2 2016-06-24 15:42:54.553 info stopInstance system.adapter.vis-metro.0
                          host-RPi2 2016-06-24 15:42:54.543 info stopInstance system.adapter.history.0 killing pid 693
                          host-RPi2 2016-06-24 15:42:54.542 info stopInstance system.adapter.history.0
                          host-RPi2 2016-06-24 15:42:54.541 info stopInstance system.adapter.hm-rpc.1 killing pid 684
                          host-RPi2 2016-06-24 15:42:54.540 info stopInstance system.adapter.hm-rpc.1
                          host-RPi2 2016-06-24 15:42:54.539 warn stopInstance system.adapter.sayit.0 not running
                          host-RPi2 2016-06-24 15:42:54.537 info stopInstance system.adapter.sayit.0
                          host-RPi2 2016-06-24 15:42:54.536 info stopInstance system.adapter.vis-plumb.0
                          host-RPi2 2016-06-24 15:42:54.536 info stopInstance system.adapter.vis-fancyswitch.0
                          host-RPi2 2016-06-24 15:42:54.535 info stopInstance canceled schedule system.adapter.dwd.0
                          host-RPi2 2016-06-24 15:42:54.533 info stopInstance system.adapter.dwd.0
                          host-RPi2 2016-06-24 15:42:54.532 info stopInstance system.adapter.fritzbox.0 killing pid 653
                          host-RPi2 2016-06-24 15:42:54.531 info stopInstance system.adapter.fritzbox.0
                          host-RPi2 2016-06-24 15:42:54.530 info stopInstance canceled schedule system.adapter.ical.0
                          host-RPi2 2016-06-24 15:42:54.526 info stopInstance system.adapter.ical.0
                          host-RPi2 2016-06-24 15:42:54.526 info stopInstance system.adapter.vis-timeandweather.0
                          host-RPi2 2016-06-24 15:42:54.525 info stopInstance system.adapter.vis-hqwidgets.0
                          host-RPi2 2016-06-24 15:42:54.524 info stopInstance system.adapter.hm-rpc.0 killing pid 621
                          host-RPi2 2016-06-24 15:42:54.523 info stopInstance system.adapter.hm-rpc.0
                          host-RPi2 2016-06-24 15:42:54.522 info stopInstance system.adapter.hm-rega.0 killing pid 616
                          host-RPi2 2016-06-24 15:42:54.518 info stopInstance system.adapter.hm-rega.0
                          host-RPi2 2016-06-24 15:42:54.514 info stopInstance system.adapter.hmm.0
                          host-RPi2 2016-06-24 15:42:54.513 info stopInstance system.adapter.web.0 killing pid 510
                          host-RPi2 2016-06-24 15:42:54.508 info stopInstance system.adapter.admin.0 killing pid 502
                          host-RPi2 2016-06-24 15:42:54.507 info stopInstance system.adapter.admin.0
                          host-RPi2 2016-06-24 15:42:54.503 info received SIGTERM
                          hm-rpc-1 2016-06-24 15:42:54.738 info terminating
                          web-0 2016-06-24 15:42:54.717 info terminating
                          web-0 2016-06-24 15:42:54.577 info terminated http server on port 8082
                          web-0 2016-06-24 15:42:54.520 info terminating http server on port 8082
                          hm-rpc-1 2016-06-24 15:42:54.623 info Disconnected
                          hm-rpc-0 2016-06-24 15:42:54.539 info binrpc -> 192.168.178.21:2001 init ["xmlrpc_bin://0.0.0.0:2001",""]
                          admin-0 2016-06-24 15:42:54.598 info terminating
                          hm-rpc-1 2016-06-24 15:42:54.570 info binrpc -> 192.168.178.21:8701 init ["xmlrpc_bin://0.0.0.0:8701",""]
                          admin-0 2016-06-24 15:42:54.515 info terminating http server on port 8081
                          hmm-0 2016-06-24 15:42:54.525 info kill hmm task
                          hm-rpc-1 2016-06-24 15:42:19.095 info Connected
                          hm-rpc-1 2016-06-24 15:42:19.037 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:42:18.774 info Disconnected
                          fritzbox-0 2016-06-24 15:42:09.697 info data from 192.168.178.1: 24.06.16 15:42:09;DISCONNECT;1;173;
                          hm-rpc-1 2016-06-24 15:41:18.762 info Connected
                          hm-rpc-1 2016-06-24 15:41:18.709 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:41:18.436 info Disconnected
                          hm-rpc-0 2016-06-24 15:41:04.387 error Socket error: Error: read ECONNRESET
                          host-RPi2 2016-06-24 15:40:43.731 info instance system.adapter.text2command.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:40:43.184 info stopInstance system.adapter.text2command.0 killing pid 716
                          host-RPi2 2016-06-24 15:40:43.183 info stopInstance system.adapter.text2command.0
                          host-RPi2 2016-06-24 15:40:43.182 info object change system.adapter.text2command.0
                          host-RPi2 2016-06-24 15:40:42.196 info instance system.adapter.telegram.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:40:41.628 info stopInstance system.adapter.telegram.0 killing pid 711
                          host-RPi2 2016-06-24 15:40:41.627 info stopInstance system.adapter.telegram.0
                          host-RPi2 2016-06-24 15:40:41.626 info object change system.adapter.telegram.0
                          host-RPi2 2016-06-24 15:40:39.860 info instance system.adapter.sayit.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:40:39.307 info stopInstance system.adapter.sayit.0 killing pid 675
                          host-RPi2 2016-06-24 15:40:39.306 info stopInstance system.adapter.sayit.0
                          host-RPi2 2016-06-24 15:40:39.298 info object change system.adapter.sayit.0
                          hm-rpc-1 2016-06-24 15:40:18.420 info Connected
                          hm-rpc-1 2016-06-24 15:40:18.323 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:40:18.036 info Disconnected
                          hm-rpc-0 2016-06-24 15:39:30.075 error Socket error: Error: read ECONNRESET
                          hm-rpc-1 2016-06-24 15:39:18.011 info Connected
                          hm-rpc-1 2016-06-24 15:39:17.969 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:39:17.647 info Disconnected
                          fritzbox-0 2016-06-24 15:39:16.938 info data from 192.168.178.1: 24.06.16 15:39:16;CONNECT;1;10;035365441721;
                          fritzbox-0 2016-06-24 15:39:10.386 info data from 192.168.178.1: 24.06.16 15:39:10;CALL;1;10;23798;035365441721;SIP0;
                          telegram-0 2016-06-24 15:38:38.735 info getMe: {"id":220635275,"first_name":"HMBaseBot1","username":"ioKuhlBot"}
                          host-RPi2 2016-06-24 15:38:38.338 info instance system.adapter.vis.0 terminated while should be started once
                          telegram-0 2016-06-24 15:38:38.135 info starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.telegram
                          telegram-0 2016-06-24 15:38:37.601 error no connection to objects DB
                          text2command-0 2016-06-24 15:38:37.172 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.text2command
                          vis-0 2016-06-24 15:38:28.334 info starting. Version 0.10.5 in /opt/iobroker/node_modules/iobroker.vis
                          host-RPi2 2016-06-24 15:38:33.860 info instance system.adapter.text2command.0 started with pid 716
                          host-RPi2 2016-06-24 15:38:29.859 info instance system.adapter.telegram.0 started with pid 711
                          admin-0 2016-06-24 15:38:25.786 info Repository received successfully.
                          history-0 2016-06-24 15:38:20.474 info enabled logging of hm-rpc.0.MEQ0706275.1.POWER
                          history-0 2016-06-24 15:38:20.472 info enabled logging of hm-rpc.0.MEQ0706275.1.ENERGY_COUNTER
                          history-0 2016-06-24 15:38:20.471 info enabled logging of hm-rpc.0.MEQ0833081.1.TEMPERATURE
                          history-0 2016-06-24 15:38:20.469 info enabled logging of hm-rpc.0.MEQ0833081.1.HUMIDITY
                          history-0 2016-06-24 15:38:20.464 info enabled logging of hm-rpc.0.NEQ0124755.1.TEMPERATURE
                          history-0 2016-06-24 15:38:20.374 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.history
                          host-RPi2 2016-06-24 15:38:17.856 info instance system.adapter.history.0 started with pid 693
                          hm-rpc-1 2016-06-24 15:38:17.619 info Connected
                          hm-rpc-1 2016-06-24 15:38:17.502 info binrpc -> listDevices 3
                          hm-rpc-1 2016-06-24 15:38:17.334 info binrpc client is trying to connect to 192.168.178.21:8701 with ["xmlrpc_bin://0.0.0.0:8701","hm-rpc.1"]
                          hm-rpc-1 2016-06-24 15:38:17.329 info binrpc server is trying to listen on 0.0.0.0:8701
                          hm-rpc-1 2016-06-24 15:38:16.919 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                          host-RPi2 2016-06-24 15:38:13.861 info instance system.adapter.hm-rpc.1 started with pid 684
                          sayit-0 2016-06-24 15:38:12.494 info Upload announce mp3 files
                          sayit-0 2016-06-24 15:38:12.438 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.sayit
                          host-RPi2 2016-06-24 15:38:09.853 info instance system.adapter.sayit.0 started with pid 675
                          host-RPi2 2016-06-24 15:38:07.604 info instance system.adapter.ical.0 terminated with code 0 (OK)
                          host-RPi2 2016-06-24 15:38:04.013 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                          dwd-0 2016-06-24 15:38:02.464 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
                          ical-0 2016-06-24 15:37:59.845 info processing URL: Dirk Kuhl https://calendar.google.com/calendar/ical/dirkkuhl%40gmail.com/private-3057398946f84443c8f01a177bf408d2/basic.ics
                          fritzbox-0 2016-06-24 15:37:59.584 info adapter connected to fritzbox: 192.168.178.1
                          fritzbox-0 2016-06-24 15:37:59.461 info try to connect: 192.168.178.1
                          fritzbox-0 2016-06-24 15:37:59.345 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox
                          host-RPi2 2016-06-24 15:37:57.866 info instance system.adapter.dwd.0 started with pid 662
                          host-RPi2 2016-06-24 15:37:57.841 info instance scheduled system.adapter.dwd.0 3 * * * *
                          ical-0 2016-06-24 15:37:57.005 info starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
                          host-RPi2 2016-06-24 15:37:54.905 info instance system.adapter.fritzbox.0 started with pid 653
                          host-RPi2 2016-06-24 15:37:50.073 info instance system.adapter.ical.0 started with pid 648
                          host-RPi2 2016-06-24 15:37:50.038 info instance scheduled system.adapter.ical.0 1,5 * * *
                          hm-rega-0 2016-06-24 15:37:48.060 info got state values
                          hm-rega-0 2016-06-24 15:37:46.301 info request state values
                          hm-rega-0 2016-06-24 15:37:46.298 info deleted 0 variables
                          hm-rega-0 2016-06-24 15:37:46.297 info added/updated 15 variables
                          hm-rega-0 2016-06-24 15:37:46.153 info got 15 variables
                          hm-rega-0 2016-06-24 15:37:45.793 info deleted 0 programs
                          hm-rega-0 2016-06-24 15:37:45.791 info added/updated 13 programs
                          hm-rega-0 2016-06-24 15:37:45.689 info got 13 programs
                          hm-rega-0 2016-06-24 15:37:45.626 info renamed hm-rpc.1.CUX9100001 to "Mail"
                          hm-rega-0 2016-06-24 15:37:45.615 info renamed hm-rpc.1.CUX9100001.0 to "Mail:0"
                          hm-rega-0 2016-06-24 15:37:45.596 info renamed hm-rpc.1.CUX9100001.1 to "Mail:1"
                          hm-rega-0 2016-06-24 15:37:44.376 info added/updated rooms to enum.rooms
                          hm-rega-0 2016-06-24 15:37:44.203 info added/updated functions to enum.functions
                          hm-rega-0 2016-06-24 15:37:44.007 info added/updated 0 favorites to enum.favorites
                          hm-rega-0 2016-06-24 15:37:43.910 info time difference local-ccu 1s
                          hm-rega-0 2016-06-24 15:37:43.795 info ReGaHSS 192.168.178.21 up
                          hm-rega-0 2016-06-24 15:37:40.308 info subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                          hm-rega-0 2016-06-24 15:37:40.254 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rega
                          hm-rpc-0 2016-06-24 15:37:42.820 info binrpc client is trying to connect to 192.168.178.21:2001 with ["xmlrpc_bin://0.0.0.0:2001","hm-rpc.0"]
                          hm-rpc-0 2016-06-24 15:37:42.814 info binrpc server is trying to listen on 0.0.0.0:2001
                          hm-rpc-0 2016-06-24 15:37:41.795 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                          hmm-0 2016-06-24 15:37:39.653 info Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
                          hmm-0 2016-06-24 15:37:39.590 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.hmm
                          host-RPi2 2016-06-24 15:37:38.602 info instance system.adapter.hm-rpc.0 started with pid 621
                          host-RPi2 2016-06-24 15:37:17.964 info instance system.adapter.hm-rega.0 started with pid 616
                          web-0 2016-06-24 15:37:16.787 info http server listening on port 8082
                          web-0 2016-06-24 15:37:16.772 info socket.io server listening on port 8082
                          host-RPi2 2016-06-24 15:37:16.350 info Update repository "default" under "conf/sources-dist.json"
                          admin-0 2016-06-24 15:37:15.821 info received all objects
                          web-0 2016-06-24 15:37:15.017 info starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.web
                          admin-0 2016-06-24 15:37:14.907 info received all states
                          host-RPi2 2016-06-24 15:37:14.221 info instance system.adapter.hmm.0 started with pid 607
                          admin-0 2016-06-24 15:37:12.605 info Use link "http://localhost:8081" to configure.
                          admin-0 2016-06-24 15:37:12.604 info http server listening on port 8081
                          admin-0 2016-06-24 15:37:12.596 info Request actual repository...
                          admin-0 2016-06-24 15:37:12.591 info requesting all objects
                          admin-0 2016-06-24 15:37:12.583 info requesting all states
                          admin-0 2016-06-24 15:37:12.393 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.admin
                          host-RPi2 2016-06-24 15:37:09.345 info instance system.adapter.web.0 started with pid 510
                          host-RPi2 2016-06-24 15:37:05.442 info instance system.adapter.admin.0 started with pid 502
                          Dirk
                            Ich habe das log mal in spoiler versteckt 😉
                            sieht gar nicht sooo wild aus. nur in den letzten (obersten) Zeilen
                            lediglich 2x error, 1x warn, aber die gleichen.
                            • Timeout beim Versuch mit dem repository zu verbinden
                            • hm-rpc.0 hat probleme mit der Verbindung (dort mal die Konfig überprüfen!)
                            • hm-rpc-1 steigt dauernd aus.
                            Da bin ich jetzt auch überfragt.
                            Trotzdem:
                            stelle mal dein Repo auf "online"
                            geh mal bitte auf die Konsole und mach ein
                            cd /opt/iobroker
                            iobroker update
                            iobroker upgrade
                              jhg last edited by
                              ich habe dasselbe Problem.
                              Bei einem Neustart werden die Daten aktualisiert, aber dann nicht weiter geschrieben.
                              • DirkK
                                Hallo Zusammen, ich hab mal das Thema geändert den meine Komplette Visualisierung ist frozen.
                                Ich häng mal noch ein Bild vom Systemadapter ran, eigentlich sollte dort die IP vom IO stehen.
                                Wenn ich diese händisch eintrage fällt sie wieder raus. Hat jemeand eine Idee?
                                Rainer deine Tipps hab ich alle durchgefüht, der Aha effeckt blieb leider aus.
                                Gruß Dirk
                                  @DirkK:
                                  eigentlich sollte dort die IP vom IO stehen. `
                                  korrekt!
                                  …und was steht in der Konfiguration der Instanz?
                                  • DirkK
                                    Hier das Bild Rainer
                                      @DirkK:
                                      Hier das Bild Rainer `
                                      Und dich stört das Wort "invalid" gar nicht? 🙂
                                      Wähle bitte da die IP Adresse, die von CCU erreichbar ist.
                                        und was steht da, wenn du auf den Pfeil neben 0.0.0.0 (invalid) klickst?
                                        • DirkK
                                          Hallo Bluefox,
                                          @Bluefox:
                                          Und dich stört das Wort "invalid" gar nicht? Wähle bitte da die IP Adresse, die von CCU erreichbar ist. `
                                          natürlich stört mich das und das Thema hatten wir schon, ich kann dort die IP nicht auswählen
                                          http://forum.iobroker.net/download/file … &mode=view
                                          deswegen den Umweg über den System Adapter, aber geht diesmal auch nicht.
                                          @Homoran:
                                          und was steht da, wenn du auf den Pfeil neben 0.0.0.0 (invalid) klickst? `
                                          Das Bild kann ich erst morgen senden, steht aber keine IP drinn.
                                          Gruß Dirk
                                            Dann bitte auch dieses wie hier:
                                            http://forum.iobroker.net/viewtopic.php … 018#p29016
                                            2031
