    5. Fehlermeldungen im Log
      djsirius last edited by
      Moin.
      Ich habe seit gestern ein großes Problem mit dem iobroker. Der iobroker stürzt regelmäßig ab und im Log befinden sich jede Menge Warnungen zum Javascript-Adapter.
      Kann mir jemand sagen was da los ist? Es hat doch vorher alles wunderbar funktioniert.
      Hier ein Auszug:
      javascript.0	2020-01-04 09:02:52.962	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2020-01-04 09:02:52.959	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2020-01-04 09:02:52.957	warn	at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-04 09:02:52.957	warn	at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-04 09:02:52.957	warn	at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-04 09:02:52.957	warn	at ontimeout (timers.js:436:11)
      javascript.0	2020-01-04 09:02:52.957	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-04 09:02:52.957	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-04 09:02:52.957	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-04 09:02:52.957	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
      javascript.0	2020-01-04 09:02:52.957	warn	at Object.<anonymous> (script.js.smarthome.system.zeiten_v01:85:5)
      javascript.0	2020-01-04 09:02:52.957	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
      javascript.0	2020-01-04 09:02:52.957	warn	Wrong type of javascript.0.zeiten.tageslaenge_differenz: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0	2020-01-04 09:02:52.957	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2020-01-04 09:02:52.953	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2020-01-04 09:02:52.947	warn	at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-04 09:02:52.947	warn	at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-04 09:02:52.947	warn	at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-04 09:02:52.947	warn	at ontimeout (timers.js:436:11)
      javascript.0	2020-01-04 09:02:52.947	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-04 09:02:52.947	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-04 09:02:52.947	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-04 09:02:52.947	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
      javascript.0	2020-01-04 09:02:52.947	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
      javascript.0	2020-01-04 09:02:52.947	warn	at countService (script.js.hm_meldungen:47:27)
      javascript.0	2020-01-04 09:02:52.947	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
      javascript.0	2020-01-04 09:02:52.946	warn	at script.js.hm_meldungen:48:7
      javascript.0	2020-01-04 09:02:52.946	warn	at count (script.js.hm_meldungen:32:20)
      javascript.0	2020-01-04 09:02:52.946	warn	getState "hm-rpc.0.NEQ0077231.0.CONFIG_PENDING" not found (3) states[id]=null
      javascript.0	2020-01-04 09:02:52.946	warn	at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-04 09:02:52.946	warn	at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-04 09:02:52.946	warn	at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-04 09:02:52.946	warn	at ontimeout (timers.js:436:11)
      javascript.0	2020-01-04 09:02:52.946	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-04 09:02:52.946	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-04 09:02:52.946	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-04 09:02:52.946	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
      javascript.0	2020-01-04 09:02:52.946	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
      javascript.0	2020-01-04 09:02:52.946	warn	at countService (script.js.hm_meldungen:47:27)
      javascript.0	2020-01-04 09:02:52.946	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
      javascript.0	2020-01-04 09:02:52.945	warn	getState "hm-rpc.0.OEQ0888039.0.CONFIG_PENDING" not found (3) states[id]=null
      javascript.0	2020-01-04 09:02:52.945	warn	at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-04 09:02:52.945	warn	at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-04 09:02:52.945	warn	at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-04 09:02:52.945	warn	at ontimeout (timers.js:436:11)
      javascript.0	2020-01-04 09:02:52.945	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-04 09:02:52.945	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-04 09:02:52.944	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-04 09:02:52.944	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
      javascript.0	2020-01-04 09:02:52.944	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
      javascript.0	2020-01-04 09:02:52.944	warn	at countService (script.js.hm_meldungen:39:20)
      javascript.0	2020-01-04 09:02:52.943	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
      javascript.0	2020-01-04 09:02:52.943	warn	at script.js.hm_meldungen:40:7
      javascript.0	2020-01-04 09:02:52.943	warn	at count (script.js.hm_meldungen:32:20)
      javascript.0	2020-01-04 09:02:52.943	warn	getState "hm-rpc.0.NEQ0077231.0.UNREACH" not found (3) states[id]=null
      javascript.0	2020-01-04 09:02:52.943	warn	at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-04 09:02:52.943	warn	at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-04 09:02:52.943	warn	at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-04 09:02:52.943	warn	at ontimeout (timers.js:436:11)
      javascript.0	2020-01-04 09:02:52.943	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-04 09:02:52.943	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-04 09:02:52.943	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-04 09:02:52.943	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
      javascript.0	2020-01-04 09:02:52.943	warn	at Object.<anonymous> (script.js.hm_meldungen:82:5)
      javascript.0	2020-01-04 09:02:52.943	warn	at countService (script.js.hm_meldungen:39:20)
      javascript.0	2020-01-04 09:02:52.942	warn	at count (script.js.hm_meldungen:32:20)
      javascript.0	2020-01-04 09:02:52.942	warn	getState "hm-rpc.0.OEQ0888039.0.UNREACH" not found (3) states[id]=null
      Vielen Dank!
      Gruß Sirius
      • dslraser
        dslraser Forum Testing Most Active @djsirius last edited by
        @djsirius
        dieses Script findet dieses Gerät nicht.
          paul53 @dslraser last edited by paul53
          @dslraser sagte:
          Oder der Datenpunkt hat (noch) keinen Zustand. Dann hilft, manuell false einzutragen.
          1.2k
          javascript
