    4. gelöst: Cloudadapter startet nicht mehr
    SOLVED gelöst: Cloudadapter startet nicht mehr
    • Matzebhv
      Matzebhv last edited by Matzebhv
      Moin,
      nach dem Update auf 3.0.0 startet der Adapter nicht mehr.
      Fehlermeldung:
      host.raspberry	2020-01-04 22:22:30.011	error	instance system.adapter.cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspberry	2020-01-04 22:22:30.011	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:189:7)
      host.raspberry	2020-01-04 22:22:30.011	error	Caught by controller[0]: at <anonymous>
      host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:65119)
      host.raspberry	2020-01-04 22:22:30.010	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2450:65)
      host.raspberry	2020-01-04 22:22:30.007	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.cloud/main.js:757:36)
      host.raspberry	2020-01-04 22:22:30.006	error	Caught by controller[0]: TypeError: alexaCustom.setLanguage is not a function
      cloud.0	2020-01-04 22:22:29.109	info	(18983) terminating
      cloud.0	2020-01-04 22:22:28.930	warn	(18983) Terminated (UNCAUGHT_EXCEPTION): Without reason
      cloud.0	2020-01-04 22:22:28.457	info	(18983) Connection changed: io client disconnect
      cloud.0	2020-01-04 22:22:28.453	info	(18983) Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
      cloud.0	2020-01-04 22:22:28.234	info	(18983) Trying to connect as system.user.admin
      cloud.0	2020-01-04 22:22:27.927	error	(18983) TypeError: alexaCustom.setLanguage is not a function at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.cloud/main.js:757:36) at objects.getObject (/opt/iobroker/node_mod
      cloud.0	2020-01-04 22:22:27.926	error	(18983) uncaught exception: alexaCustom.setLanguage is not a function
      cloud.0	2020-01-04 22:22:27.909	info	(18983) Connecting with https://iobroker.net:10555 with "******************************************************"
      cloud.0	2020-01-04 22:22:27.905	warn	(18983) Pleas use ioBroker.iot for alexa control
      cloud.0	2020-01-04 22:22:27.753	info	(18983) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v8.17.0
      host.raspberry	2020-01-04 22:22:24.296	info	instance system.adapter.cloud.0 started with pid 18983
      host.raspberry	2020-01-04 22:22:24.222	info	"system.adapter.cloud.0" enabled
      Ganz so viel einstellen kann man hier jetzt ja nicht mehr. Benötige den Fernzugriff nur ganz selten und könnte daher drauf verzichten, ist ja aber vermutlich nicht im Sinne des Erfinders.
      System latest / aktuell
      Betriebssystem
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      1497 MHz
      Modell
      Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      RAM
      3.86 GB
      System Betriebszeit
      5 T. 10:14:02
      Node.js
      v8.17.0 (Empfohlene Version v10.18.0)
      NPM
      6.13.4
      Festplatte Größe
      11.75 GB
      Festplatte frei
      5.74 GB
      Anzahl der Adapter
      311
      Betriebszeit
      5 T. 09:31:19
      Aktive Instanzen
      41
      Hostname
      raspberry
      Matze
      • Matzebhv
        Nach dem Update auf 3.0.1 funktioniert der Adapter wieder.
        Matze
        • Negalein
          Negalein Global Moderator @Matzebhv last edited by Negalein
          @Matzebhv sagte in Cloudadapter startet nach Update nicht mehr:
          Der Cloud-Adapter wurde deaktiviert.
          Gibt jetzt nur noch den IOT.
          https://forum.iobroker.net/topic/28454/04-01-deaktivierung-alexa-service-free-cloud
          • haselchen
            haselchen Most Active @Negalein last edited by haselchen
            @Negalein
            Was für ein Nonsens 🙈Der Cloudadapter kann für Alexa Befehle nicht mehr genutzt werden. Verlinkst es sogar noch selber.
            Für Fernzugriff was der TE möchte, ist er sehr wohl nutzbar.
            "Falls der Fernzugriff auf Eure Visualisierungen über die Free-Cloud nicht gebraucht wird bitten wir Euch den cloud-Adapter zu deaktivieren, um Ressourcen auf dem Free-Cloud Server zu sparen und den Usern zur Verfügung zu stellen die es benötigen. Danke!"
            • Negalein
              Negalein Global Moderator @haselchen last edited by
              @haselchen sagte in Cloudadapter startet nach Update nicht mehr:
              Sorry, das hab ich beim TE überlesen.
              Kann ja mal passieren.
              • Matzebhv
                Matze
                cloud adapter
