    4. Log Fehlermeldung Sonoff Adapter
    SOLVED Log Fehlermeldung Sonoff Adapter
      schubs2802 last edited by Negalein
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem:
      Node-Version: 10.18.0
      Nodejs-Version: 10.18.0
      NPM-Version: 6.13.4
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: Link
      Hallo, seit heute Morgen laufen ständig Fehlermeldungen in der Log auf und die über Sonoff geschalteten Geräte tun es nicht mehr. Der Adapter startet ständig neu.
      Die Log sieht so aus.
      host.raspberrypi-io	2020-01-07 15:56:29.138	error	Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
      host.raspberrypi-io	2020-01-07 15:56:29.137	error	Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
      host.raspberrypi-io	2020-01-07 15:56:29.137	error	Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
      host.raspberrypi-io	2020-01-07 15:56:29.137	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
      host.raspberrypi-io	2020-01-07 15:56:29.136	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
      host.raspberrypi-io	2020-01-07 15:56:29.136	error	Caught by controller[0]: at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
      host.raspberrypi-io	2020-01-07 15:56:29.135	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
      host.raspberrypi-io	2020-01-07 15:56:29.135	error	Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
      host.raspberrypi-io	2020-01-07 15:56:29.134	error	Caught by controller[0]: at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1368:58)
      host.raspberrypi-io	2020-01-07 15:56:29.133	error	Caught by controller[0]: TypeError: Cannot read property 'toString' of undefined
      sonoff.0	2020-01-07 15:56:28.577	info	(1513) Terminated (NO_ERROR): Without reason
      sonoff.0	2020-01-07 15:56:28.574	info	(1513) terminating
      sonoff.0	2020-01-07 15:56:28.044	error	at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
      sonoff.0	2020-01-07 15:56:28.044	error	at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
      sonoff.0	2020-01-07 15:56:28.044	error	at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
      sonoff.0	2020-01-07 15:56:28.044	error	at Connection.emit (events.js:198:13)
      sonoff.0	2020-01-07 15:56:28.044	error	at Object.onceWrapper (events.js:286:20)
      sonoff.0	2020-01-07 15:56:28.044	error	at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
      sonoff.0	2020-01-07 15:56:28.044	error	at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
      sonoff.0	2020-01-07 15:56:28.044	error	at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1368:58)
      sonoff.0	2020-01-07 15:56:28.044	error	(1513) TypeError: Cannot read property 'toString' of undefined
      sonoff.0	2020-01-07 15:56:28.042	error	(1513) uncaught exception: Cannot read property 'toString' of undefined
      sonoff.0	2020-01-07 15:56:26.331	info	(1513) Client [Sofa] connected with secret 1578408986329_452
      sonoff.0	2020-01-07 15:56:26.220	info	(1513) Client [hwr] connected with secret 1578408986217_8249
      sonoff.0	2020-01-07 15:56:26.208	info	(1513) Client [Bad] connected with secret 1578408986207_5157
      sonoff.0	2020-01-07 15:56:25.908	info	(1513) Client [Lichterkette] connected with secret 1578408985907_1590
      sonoff.0	2020-01-07 15:56:25.686	info	(1513) Client [Arbeitszimmer] connected with secret 1578408985676_4041
      sonoff.0	2020-01-07 15:56:25.649	info	(1513) Client [Schwibbogen-Arbeitszimmer] connected with secret 1578408985635_6441
      sonoff.0	2020-01-07 15:56:25.645	info	(1513) Client [LED-Schlafzimmer] connected with secret 1578408985633_1059
      sonoff.0	2020-01-07 15:56:25.469	info	(1513) Client [LED-Kueche] connected with secret 1578408985445_9272
      sonoff.0	2020-01-07 15:56:24.989	info	(1513) Starting MQTT authenticated server on port 1883
      sonoff.0	2020-01-07 15:56:24.898	info	(1513) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.0
      host.raspberrypi-io	2020-01-07 15:56:22.409	info	instance system.adapter.sonoff.0 started with pid 1513
      host.raspberrypi-io	2020-01-07 15:55:52.374	info	Restart adapter system.adapter.sonoff.0 because enabled
      Kann mir einer von den erfahrenen helfen, wo das Problem liegt. Bin absoluter Laie. Danke schubs28
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
        Moin, habe den Fehler gefunden. Es lag an einem Sonoff Touch T2 Schalter. Habe ihn nochmal mit dem Tamplate für den T1 gefläscht, nun läuft alles.
          error log sonoff adapter
