    4. update von Adapter immer Fehler 25
    SOLVED update von Adapter immer Fehler 25
    • chucky666
      chucky666 last edited by
      Hallo Zusammen,
      beim updaten von Adapter bekomme ich immer eine Fehlermeldung .
      $ ./iobroker upgrade daswetter
      Update daswetter from @2.8.0 to @2.8.1
      NPM version: 6.11.3
      npm install iobroker.daswetter@2.8.1 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EACCESnpm ERR! syscall mkdirnpm ERR! path /home/iobroker
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'npm ERR!  { [Error: EACCES: permission denied, mkdir '/home/iobroker']npm ERR!   cause:npm ERR!    { Error: EACCES: permission denied, mkdir '/home/iobroker'npm ERR!      errno: -13,npm ERR!      code: 'EACCES',npm ERR!      syscall: 'mkdir',npm ERR!      path: '/home/iobroker' },npm ERR!   isOperational: true,npm ERR!   stack: 'Error: EACCES: permission denied, mkdir \'/home/iobroker\'',npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'mkdir',npm ERR!   path: '/home/iobroker' }
      npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      ERROR: host.iobroker Cannot install iobroker.daswetter@2.8.1: 243
      ERROR: process exited with code 25
      was muss ich machen um diesen Fehler zu beseitigen?
      • AlCalzone
        AlCalzone Developer @chucky666 last edited by
        @chucky666
        Was für ein Linux ist das? Wann installiert und wie?
        Scheinbar fehlt das homedir für den User iobroker. Sollte sich so fixen lassen:
        sudo mkdir /home/iobroker
        sudo chown iobroker:iobroker /home/iobroker
        sudo chmod 751 /home/iobroker
          Homoran Global Moderator Administrators @chucky666 last edited by
          @chucky666 sagte in update von Adapter immer Fehler 25:
          mal den Fixer drüberlaufen
          • chucky666
            habe ich jetzt versucht , leider gleicher Fehler
            • AlCalzone
              @chucky666
              • chucky666
                super danke dir , jetzt klappt es .
                Debian 9.5 ist installiert auf Proxmox
                Node habe ich jetzt auf 10.18 geupdatet
                • AlCalzone
                  Debian 9.5
                  Kannst du bitte mal in die Datei /etc/login.defs schauen, ob da CREATE_HOME=no oder ähnlich steht?
                  adapter installieren fehler
