    3. Tester
    4. Test Adapter swiss-weather-api v0.1.x
      baerengraben last edited by baerengraben
      Aktuelle Test Version 2.2.2
      Veröffentlichungsdatum 9.1.2020
      Github Link https://github.com/baerengraben/ioBroker.swiss-weather-api
      Bereit zum Test
      Hallo zusammen
      Ich einen Adapter geschrieben, der die Wetter-Daten vom schweizer Staatsfernsehen https://developer.srgssr.ch/apis/srgssr-weather liest und im ioBroker zur Verfügung stellt. Ich bitte um Tests.
      Vielen Dank 🙂
      sigi234 P 2 Replies Last reply Reply Quote 1
      • sigi234
        sigi234 Forum Testing Most Active @baerengraben last edited by
        @baerengraben
        swiss-weather-api.0	2020-01-10 12:00:01.623	error	at process._tickCallback (internal/process/next_tick.js:63:19)
        swiss-weather-api.0	2020-01-10 12:00:01.623	error	at endReadableNT (_stream_readable.js:1145:12)
        swiss-weather-api.0	2020-01-10 12:00:01.623	error	at IncomingMessage.emit (events.js:203:15)
        swiss-weather-api.0	2020-01-10 12:00:01.623	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:983:89)
        swiss-weather-api.0	2020-01-10 12:00:01.623	error	(7336) TypeError: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.623	error	(7336) uncaught exception: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.620	error	at process._tickCallback (internal/process/next_tick.js:63:19)
        swiss-weather-api.0	2020-01-10 12:00:01.620	error	at endReadableNT (_stream_readable.js:1145:12)
        swiss-weather-api.0	2020-01-10 12:00:01.620	error	at IncomingMessage.emit (events.js:203:15)
        swiss-weather-api.0	2020-01-10 12:00:01.620	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:427:83)
        swiss-weather-api.0	2020-01-10 12:00:01.620	error	(7336) TypeError: Cannot read property '0' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.619	error	(7336) uncaught exception: Cannot read property '0' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.616	error	at process._tickCallback (internal/process/next_tick.js:63:19)
        swiss-weather-api.0	2020-01-10 12:00:01.616	error	at endReadableNT (_stream_readable.js:1145:12)
        swiss-weather-api.0	2020-01-10 12:00:01.616	error	at IncomingMessage.emit (events.js:203:15)
        swiss-weather-api.0	2020-01-10 12:00:01.616	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:1175:83)
        swiss-weather-api.0	2020-01-10 12:00:01.616	error	(7336) TypeError: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.616	error	(7336) uncaught exception: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.610	error	at process._tickCallback (internal/process/next_tick.js:63:19)
        swiss-weather-api.0	2020-01-10 12:00:01.610	error	at endReadableNT (_stream_readable.js:1145:12)
        swiss-weather-api.0	2020-01-10 12:00:01.610	error	at IncomingMessage.emit (events.js:203:15)
        swiss-weather-api.0	2020-01-10 12:00:01.610	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:123:92)
        swiss-weather-api.0	2020-01-10 12:00:01.610	error	(7336) TypeError: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 12:00:01.610	error	(7336) uncaught exception: Cannot read property 'toString' of undefined
          baerengraben @sigi234 last edited by baerengraben
          @sigi234 Vielen Dank fürs Testen! 🙂
          Ich habe eine kleine Korrektur gemacht und auf Github gestellt. Kannst du bitte die Adapter-Instanz löschen, den Adapter neu von Github ziehen, einen Upload machen und dann den Adapter neu installieren? Falls es weiterhin errors gibt, bitte gleich im Debug-Modus starten und das Log posten. - Das müsste aber eigentlich jetzt gehen...
          • sigi234
            sigi234 Forum Testing Most Active @baerengraben last edited by sigi234
            @baerengraben
            swiss-weather-api.0	2020-01-10 19:43:01.487	info	(24948) Terminated (NO_ERROR): Without reason
            swiss-weather-api.0	2020-01-10 19:43:01.486	info	(24948) terminating
            swiss-weather-api.0	2020-01-10 19:43:00.994	error	(24948) TypeError: Cannot read property 'toString' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:1002:89) at Incom
            swiss-weather-api.0	2020-01-10 19:43:00.993	error	(24948) uncaught exception: Cannot read property 'toString' of undefined
            swiss-weather-api.0	2020-01-10 19:43:00.993	debug	(24948) Hour Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
            swiss-weather-api.0	2020-01-10 19:43:00.992	error	(24948) TypeError: Cannot read property 'toString' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:1194:83) at Incom
            swiss-weather-api.0	2020-01-10 19:43:00.991	error	(24948) uncaught exception: Cannot read property 'toString' of undefined
            swiss-weather-api.0	2020-01-10 19:43:00.991	debug	(24948) 24h Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
            swiss-weather-api.0	2020-01-10 19:43:00.990	debug	(24948) chunksConcat: { "code": "404.02.001", "message": "Resource not found error", "info": "https://developer.srgssr.ch" }
            swiss-weather-api.0	2020-01-10 19:43:00.985	error	(24948) TypeError: Cannot read property 'toString' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:142:92) at Incomi
            swiss-weather-api.0	2020-01-10 19:43:00.985	error	(24948) uncaught exception: Cannot read property 'toString' of undefined
            swiss-weather-api.0	2020-01-10 19:43:00.984	debug	(24948) Current Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
            swiss-weather-api.0	2020-01-10 19:43:00.979	error	(24948) TypeError: Cannot read property '0' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:446:83) at IncomingMessa
            swiss-weather-api.0	2020-01-10 19:43:00.979	error	(24948) uncaught exception: Cannot read property '0' of undefined
            swiss-weather-api.0	2020-01-10 19:43:00.973	debug	(24948) Week Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
            swiss-weather-api.0	2020-01-10 19:43:00.972	debug	(24948) chunksConcat: { "code": "404.02.001", "message": "Resource not found error", "info": "https://developer.srgssr.ch" }
            swiss-weather-api.0	2020-01-10 19:43:00.804	debug	(24948) Access_Token : xxxxxxxxxxxxxxxxxxx
            swiss-weather-api.0	2020-01-10 19:43:00.628	debug	(24948) "xxxxxxxxxxxxxxxx" converted to Base64 is "xxxxxxxxxxxxxxxxxxxxx=="
            swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Define XML File:...
            swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Longitude: 14.xxxxxxxx
            swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Latitude 48.xxxxxxxxxxx
            swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Consumer Secret: xxxxxxxxxxx
            swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Consumer Key: xxxxxxxxxxxxxxx
            swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) App Name: Sigi
            swiss-weather-api.0	2020-01-10 19:43:00.612	info	(24948) starting. Version 0.1.4 in C:/Program Files/iobroker/Test/node_modules/iobroker.swiss-weather-api, node: v10.16.3
              Sehr komisch. Das SSRSSR-API beantwortet die Anfragen mit
              Darf ich wissen mit welcher Longitude / Latitude du die Abfrage machst? Ich habe die leise Vermutung, dass das API sich auf Schweizer Locations beschränkt. Kannst du auch mal Zürich (latitude: 47.36667 und longitude: 8.5) ausprobieren?
              • sigi234
                @baerengraben sagte in Test Adapter swiss-weather-api v0.1.x:
                Ja, mit diesen geht es. Meine sind aus Österreich.
                  Ok, ich "verbessere" den Adapter noch indem ich ihn auf Schweizer Locations einschränke und mache eine neue Version.
                  Vielen Dank für diesen Test! Da wäre ich definitiv nicht darauf gekommen...
                    Die Anpassungen sind erledigt. Ich habe gleich eine neue Version 0.1.5 erstellt.
                    • sigi234
                      Einfach per Git installieren?
                        Ja wieder genau gleich über Github ziehen, uploaden und neu installieren.
                        Der Adapter gibt nun einen Error aus, wenn eine Location gesucht wird, welche nicht vom API unterstützt wird.
                        • sigi234
                          Also nix für Österreich.
                            Leider werden nur Schweizer Adressen unterstützt. Der swiss-weather-api Adapter zieht die Wetter-Daten vom Schweizer Fernsehen. Die können da zwar gratis abgerufen werden, aber sie bieten explizit nur schweizer Adressen an. Dieser Adapter ist deswegen vorallem für Schweizer geeignet oder für Personen, die sich für Wetterdaten in der Schweiz interessieren.
                            dbweb 1 Reply Last reply Reply Quote 0
                            • dbweb
                              dbweb @baerengraben last edited by
                              @baerengraben Bin grade beim Testen, schön gibts jetzt auch mal was für die Schweiz, vielen Dank dafür.
                              Anmerkungen:
                              • ist natürlich etwas schade, dass man erstmal bis zu 30 Minuten warten muss damit etwas kommt. Weis aber auch nicht wie du das bei einem Schedule-Adapter anders lösen kannst ohne irgend ein "Gebastel" in der index_m.
                              • Dasselbe mit den Credentials, wenn man da was falsch eingibt, wartet man mal 30 Minuten um das dann im Log zu merken. Da könntest du evtl. auch vom Client aus einen Request abschicken um zu prüfen ob es soweit passt, auch wenn ich das nicht wirklich sauber finde.
                              Hast du, oder jemand anderes, schon eine VIS-Anzeige dazu gebaut?
                              B sigi234 2 Replies Last reply Reply Quote 1
                                baerengraben @dbweb last edited by baerengraben
                                @dbweb: Merci fürs Testen 🙂
                                @dbweb sagte in Test Adapter swiss-weather-api v0.1.x:
                                Anmerkungen:
                                Das ist ein guter Punkt, für den ich bis jetzt auch noch keine schöne Lösung gefunden habe. Beim Testen habe ich jeweils, nach dem Installieren, den Scheduler kurz auf 1min gesetzt. Anschliessend, wenn alles gut lief, dann wieder auf 30min.
                                Ansonsten habe ich leider auch keine bessere Möglichkeit gefunden das schöner umzusetzen.
                                Hier kann man eigentlich auch kurz den Scheduler auf 1min stellen, so dass man schneller feststellen kann ob's ok durchläuft oder nicht. Aber evtl. kann ich dem auch beikommen indem ich das noch besser Dokumentiere (z.B. mit Printscreens)?
                                Eine Visualisierung habe ich nicht umgesetzt. Ich persönlich verwende das API um die Daten vom ioBroker auf mein KNX-System zu schicken. Da wird es bei dann visualisiert. Wenn hier jemand die Visu im ioBroker dafür beitragen möchte/könnte wäre das natürlich super 🙂
                                • sigi234
                                  sigi234 Forum Testing Most Active @dbweb last edited by
                                  Nicht direkt, aber:
                                  https://forum.iobroker.net/topic/28717/vis-von-sigi234/23
                                    Al Bundy last edited by
                                    Ich nutze den Adapter in der Version 0.2.0. Seit einem Update von node.js von 10x auf 12.16.3 funktioniert dieser nicht mehr (Fehlermeldung im Log: error: instance system.adapter.swiss-weather-api.0 terminated with code 1 (JS_CONTROLLER_STOPPED))
                                    Gibt es Probleme mit dem Adapter und der 12er Version?
                                      trasaonis @Al Bundy last edited by
                                      @Al-Bundy said in Test Adapter swiss-weather-api v0.1.x:
                                      Hab das gleiche Problem seit dem Update. Adapter lässt dich nicht mehr starten.
                                        Al Bundy @trasaonis last edited by
                                        @trasaonis
                                        Ich habe die Instanz und den Adapter deinstalliert und nochmals komplett neu installiert. Nun läuft es wieder.
                                          @Al-Bundy
                                          Danke! Hat bei mir auch funktioniert. Bin leider erst jetzt dazugekommen Adapter und Instanz neu zu installieren. Läuft wieder!👍
                                            M240-Swiss last edited by
                                            Hallo zusammen
                                            Als erstes: Ich bin noch Anfänger was iObroker angeht und falls der Beitrag hier nicht hingehört bitte verschieben.
                                            Ich konnte ioBroker auf einem Raspberry Pi 4 installieren und im Anschluss erste Adapter erfolgreich in Betrieb nehmen.
                                            Ich habe nun den swiss-weather Adapter installiert, Costumer-Key und - Secret eingegeben und auch die Koordinaten (innerhalb der Schweiz) eingetragen.
                                            Nun jedoch erscheinen mir im Log laufend Fehlermeldungen (siehe Spoiler unten)
                                            Hat mir dort jemand einen Tip? Besten Dank im Voraus und Gruss aus der Schweiz
                                            2020-07-22 21:00:01.447 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'ttn' of undefined
                                            2020-07-22 21:00:01.448 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'ttn' of undefined
                                            at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:602:26)
                                            at IncomingMessage.emit (events.js:326:22)
                                            at endReadableNT (_stream_readable.js:1244:12)
                                            at processTicksAndRejections (internal/process/task_queues.js:80:21)
                                            2020-07-22 21:00:01.455 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property '0' of undefined
                                            2020-07-22 21:00:01.459 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property '0' of undefined
                                            at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:595:28
                                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55
                                            at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703
                                            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                                            at processTicksAndRejections (internal/process/task_queues.js:93:5)
                                            2020-07-22 21:00:01.462 - info: swiss-weather-api.0 (5701) terminating
                                            2020-07-22 21:00:01.464 - info: swiss-weather-api.0 (5701) Terminated (NO_ERROR): Without reason
                                            2020-07-22 21:00:01.473 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'smb3' of undefined
                                            2020-07-22 21:00:01.474 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'smb3' of undefined
                                            at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1690:26)
                                            2020-07-22 21:00:01.478 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'toString' of undefined
                                            2020-07-22 21:00:01.479 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'toString' of undefined
                                            at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1664:34
                                            2020-07-22 21:00:01.481 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property '0' of undefined
                                            2020-07-22 21:00:01.482 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property '0' of undefined
                                            at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1682:34
                                            2020-07-22 21:00:01.493 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot convert undefined or null to object
                                            2020-07-22 21:00:01.494 - error: swiss-weather-api.0 (5701) TypeError: Cannot convert undefined or null to object
                                            at Function.keys ()
                                            at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1402:18)
                                            2020-07-22 21:00:01.499 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'ttn' of undefined
                                            2020-07-22 21:00:01.500 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'ttn' of undefined
                                            at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:191:26)
                                            2020-07-22 21:00:01.505 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'toString' of undefined
                                            2020-07-22 21:00:01.506 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'toString' of undefined
                                            at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1394:34
                                            2020-07-22 21:00:01.507 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'toString' of undefined
                                            2020-07-22 21:00:01.508 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'toString' of undefined
                                            at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:165:34
                                            2020-07-22 21:00:01.510 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'date' of undefined
                                            2020-07-22 21:00:01.511 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'date' of undefined
                                            at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:183:31
                                            2020-07-22 21:00:01.977 - info: host.raspberrypi instance system.adapter.swiss-weather-api.0 terminated with code 0 (NO_ERROR)
                                            adapter test weather
                                            17
                                            91
                                            11271
