    4. Fehlermeldung Controller
    UNSOLVED Fehlermeldung Controller
      rascal last edited by
      ich habe nodejs auf v 12 upgedatet und nun bekomme ich im Log diese Fehlermeldung, wie behebe ich das?
      host.Mastermind	2020-01-11 20:22:17.676	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Mastermind	2020-01-11 20:22:17.676	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
      host.Mastermind	2020-01-11 20:22:17.676	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:811:32)
      host.Mastermind	2020-01-11 20:22:17.676	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:991:10)
      host.Mastermind	2020-01-11 20:22:17.676	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:955:30)
      host.Mastermind	2020-01-11 20:22:17.676	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/node_modules/mmmagic/lib/index.js:1:13)
      host.Mastermind	2020-01-11 20:22:17.675	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.Mastermind	2020-01-11 20:22:17.675	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:848:19)
      host.Mastermind	2020-01-11 20:22:17.675	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:723:14)
      host.Mastermind	2020-01-11 20:22:17.675	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:811:32)
      host.Mastermind	2020-01-11 20:22:17.675	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1021:18)
      host.Mastermind	2020-01-11 20:22:17.675	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.Mastermind	2020-01-11 20:22:17.674	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      host.Mastermind	2020-01-11 20:22:17.674	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
      host.Mastermind	2020-01-11 20:22:17.674	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.Mastermind	2020-01-11 20:22:17.674	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/iobroker.sql/node_modules/mmmagic/build/Release/magic.node'
      host.Mastermind	2020-01-11 20:22:17.674	error	Caught by controller[0]: ^
      host.Mastermind	2020-01-11 20:22:17.673	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      host.Mastermind	2020-01-11 20:22:17.673	error	Caught by controller[0]: internal/modules/cjs/loader.js:1021
      • Glasfaser
        Glasfaser @rascal last edited by Glasfaser
        @rascal
        Warum hast du auf 12 hochgezogen .... aktuell ist 10.18.1 .
        npm rebuild
          weil der hue-Adapter nach einem Adapter-update gemeckert und nicht mehr funktioniert hat 😞
            Ich bekomm's nicht hin. Der Sql Adapter lässt sich nicht mehr starten und mit npm rebuild steigt er mit einer Fehlermeldung aus. Ich habe iobroker übrigens auf einem Ubuntu 18 Server laufen.
            > sqlite3@4.1.1 install /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
            > node-pre-gyp install --fallback-to-build
            node-pre-gyp WARN Using request for node-pre-gyp https download
            node-pre-gyp WARN Pre-built binaries not installable for sqlite3@4.1.1 and node@10.18.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
            node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v64-linux-x64'
            gyp ERR! configure error
            gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
            gyp ERR! System Linux 4.15.0-74-generic
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v64-linux-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v64-linux-x64" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
            gyp ERR! node -v v10.18.1
            gyp ERR! node-gyp -v v5.0.5
            gyp ERR! not ok
            node-pre-gyp ERR! build error
            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v64-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v64-linux-x64 --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
            node-pre-gyp ERR! System Linux 4.15.0-74-generic
            node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.sql/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
            node-pre-gyp ERR! node -v v10.18.1
            node-pre-gyp ERR! node-pre-gyp -v v0.11.0
            node-pre-gyp ERR! not ok
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! sqlite3@4.1.1 install: `node-pre-gyp install --fallback-to-build`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the sqlite3@4.1.1 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/rascal/.npm/_logs/2020-01-11T20_08_16_060Z-debug.log
            rascal@Mastermind:/opt/iobroker$
              ok, habe mir mittlerweile iobroker zerschossen.... backups for the win 🙄
              ich habe mir wieder nodejs v8 installiert und alles funkt wieder.
              Ich hasse es, wenn ein Adapter eine neue Node -v möchte und 3 andere sind dafür noch nicht bereit 😞
              fehler nodejs 12
