    4. Update Tuya
    UNSOLVED Update Tuya
    • Pat1968
      Pat1968 last edited by Negalein
      Hallo
      beim update auf Tuya habe ich diese meldung bekommen
      *make: *** [unix_dgram.target.mk:99: Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.58-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! node -v v10.16.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      npm WARN jsdom@15.2.1 requires a peer of canvas@^2.5.0 but none is installed. You must install peer dependencies yourself.npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
      npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1* "
      Keiner ener mir sagen was dies zu bedeuten hat resp ob ich was updaten muss?
      MFG
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      tuya adapter
