    4. Seit update keine Zustandsänderungen der z.B. Fensterkontakte
      audioconcept last edited by
      Hallo
      ich habe seit dem updaten der Adapter im Adminmodul keine veränderung der Schaltzustände im VIS.
      Im Log steht das:
      host-raspberrypi	2016-06-30 16:59:13.904	info	Restart adapter system.adapter.hm-rpc.0 because enabled
      host-raspberrypi	2016-06-30 16:59:13.902	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      hm-rpc-0	2016-06-30 16:59:13.869	info	terminating
      hm-rpc-0	2016-06-30 16:59:13.839	info	Disconnected
      hm-rpc-0	2016-06-30 16:59:13.798	info	binrpc -> 192.168.2.102:2001 init ["xmlrpc_bin://192.168.2.138:2001",""]
      TypeError:	2016-06-30 16:59:13.791	error	at TCP.onread (net.js:531:20)
      TypeError:	2016-06-30 16:59:13.791	error	at Socket.Readable.push (_stream_readable.js:111:10)
      TypeError:	2016-06-30 16:59:13.791	error	at readableAddChunk (_stream_readable.js:153:18)
      TypeError:	2016-06-30 16:59:13.791	error	at Socket.emit (events.js:169:7)
      TypeError:	2016-06-30 16:59:13.791	error	at emitOne (events.js:77:13)
      TypeError:	2016-06-30 16:59:13.791	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
      TypeError:	2016-06-30 16:59:13.791	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
      TypeError:	2016-06-30 16:59:13.791	error	Cannot read property '2' of undefined
      uncaught	2016-06-30 16:59:13.767	error	exception: Cannot read property '2' of undefined
      hm-rpc-0	2016-06-30 16:58:49.221	info	Connected
      hm-rpc-0	2016-06-30 16:58:47.630	info	binrpc -> 143 devices
      hm-rpc-0	2016-06-30 16:58:47.592	info	binrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:58:47.323	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:58:47.318	info	binrpc server is trying to listen on 192.168.2.138:2001
      hm-rpc-0	2016-06-30 16:58:46.784	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-raspberrypi	2016-06-30 16:58:44.102	info	instance system.adapter.hm-rpc.0 started with pid 2241
      host-raspberrypi	2016-06-30 16:58:14.073	info	Restart adapter system.adapter.hm-rpc.0 because enabled
      host-raspberrypi	2016-06-30 16:58:14.072	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      uncaught	2016-06-30 16:58:13.964	error	exception: Cannot read property '2' of undefined
      hm-rpc-0	2016-06-30 16:57:52.079	info	Connected
      hm-rpc-0	2016-06-30 16:57:50.423	info	binrpc -> 143 devices
      hm-rpc-0	2016-06-30 16:57:50.387	info	binrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:57:49.119	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:57:49.113	info	binrpc server is trying to listen on 192.168.2.138:2001
      hm-rpc-0	2016-06-30 16:57:48.508	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-raspberrypi	2016-06-30 16:57:45.803	info	instance system.adapter.hm-rpc.0 started with pid 2219
      host-raspberrypi	2016-06-30 16:57:15.771	info	Restart adapter system.adapter.hm-rpc.0 because enabled
      host-raspberrypi	2016-06-30 16:57:15.769	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      uncaught	2016-06-30 16:57:15.647	error	exception: Cannot read property '2' of undefined
      hm-rpc-0	2016-06-30 16:55:22.354	info	Connected
      hm-rpc-0	2016-06-30 16:55:20.755	info	binrpc -> 143 devices
      hm-rpc-0	2016-06-30 16:55:20.715	info	binrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:55:20.446	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:55:20.440	info	binrpc server is trying to listen on 192.168.2.138:2001
      hm-rpc-0	2016-06-30 16:55:19.910	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-raspberrypi	2016-06-30 16:55:17.409	info	instance system.adapter.hm-rpc.0 started with pid 2036
      host-raspberrypi	2016-06-30 16:54:47.386	info	Restart adapter system.adapter.hm-rpc.0 because enabled
      host-raspberrypi	2016-06-30 16:54:47.384	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      hm-rpc-0	2016-06-30 16:54:47.350	info	terminating
      hm-rpc-0	2016-06-30 16:54:47.319	info	Disconnected
      hm-rpc-0	2016-06-30 16:54:47.298	info	binrpc -> 192.168.2.102:2001 init ["xmlrpc_bin://192.168.2.138:2001",""]
      TypeError:	2016-06-30 16:54:47.293	error	at TCP.onread (net.js:531:20)
      TypeError:	2016-06-30 16:54:47.293	error	at Socket.Readable.push (_stream_readable.js:111:10)
      TypeError:	2016-06-30 16:54:47.293	error	at readableAddChunk (_stream_readable.js:153:18)
      TypeError:	2016-06-30 16:54:47.293	error	at Socket.emit (events.js:169:7)
      TypeError:	2016-06-30 16:54:47.293	error	at emitOne (events.js:77:13)
      TypeError:	2016-06-30 16:54:47.293	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
      TypeError:	2016-06-30 16:54:47.293	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
      TypeError:	2016-06-30 16:54:47.293	error	Cannot read property '2' of undefined
      uncaught	2016-06-30 16:54:47.277	error	exception: Cannot read property '2' of undefined
      hm-rpc-0	2016-06-30 16:52:23.893	info	Connected
      hm-rpc-0	2016-06-30 16:52:22.298	info	binrpc -> 143 devices
      hm-rpc-0	2016-06-30 16:52:22.263	info	binrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:52:21.993	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-30 16:52:21.988	info	binrpc server is trying to listen on 192.168.2.138:2001
      hm-rpc-0	2016-06-30 16:52:21.442	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-raspberrypi	2016-06-30 16:52:19.004	info	instance system.adapter.hm-rpc.0 started with pid 1973
      host-raspberrypi	2016-06-30 16:51:48.980	info	Restart adapter system.adapter.hm-rpc.0 because enabled
      host-raspberrypi	2016-06-30 16:51:48.979	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
        Was hast du denn upgedated?
        Sind ALLE Adapter und auch der js-controller auf dem neuesten Stand?
          Hi ja habe alle Adapter im Adminmodul aktualisiert.
          Gesendet von meinem STV100-4 mit Tapatalk
            der js controller muss ich den anders auf dem neuesten Stand bringen?
            Komischerweise wird die Temperatur und Uhrzeit richtig angezeigt.Nur der Zustandbder Fenster und Türen nicht.
            • htrecksler
              guckst du hier
              http://www.iobroker.net/?page_id=3074&lang=de
                Hi ist denn der Fehler hm-rpc oder node_modules?
                Soll ich das so ausführen?
                cd /opt/iobroker
                npm install iobroker.hm-rpc –production
                iobroker upload hm-rpc
                ./iobroker restart
                  Könnte ihr mir bitte noch mal weiterhelfen?
                    Wie ist denn jetzt der aktuelle Status?
                    Meine letzte Frage war:
                    @Homoran:
                    Sind ALLE Adapter und auch der js-controller auf dem neuesten Stand? `
                    Leider bekam ich nur die folgende Antwort:
                    @audioconcept:
                    ja … habe alle Adapter im Adminmodul aktualisiert. `
                    Da kann ich mir jetzt etwas bei aussuchen, oder?
                    Dann kommt:
                    @audioconcept:
                    der js controller muss ich den anders auf dem neuesten Stand bringen? `
                    und weiter Informationen, die ich nicht der aktuellen Lage zuordnen konnte.
                    Könnten aber ursächlich sein.
                    Also nochmal:
                    Was ist jetzt der Status?
                    • Fehlermeldungen im Log??
                      Hallo Rainer
                      Ich hatte Jessie neu installiert auf dem Pi. Habe es nach der Anleitung auf der IOBROKER Seite gemacht. Danach habe ich letzte Sicherungsdatei eingespielt.
                      Auf der Admin-Adapterseite habe ich alle Aktualisierungen ausgeführt.
                      ist der js-controller dann nicht automatisch auf den neuesten Stand?
                      Muss ich es dann so installieren?:
                      ` > cd /opt/iobroker
                      iobroker stop
                      npm install iobroker.js-controller –production
                      iobroker start `
                      Die Logmeldung ist noch die im ersten Beitrag.
                        @audioconcept:
                        ist der js-controller dann nicht automatisch auf den neuesten Stand? `
                        Nein, das update dazu findest du unter dem Reiter "Hosts"
                        @audioconcept:
                        cd /opt/iobroker
                        iobroker stop
                        npm install iobroker.js-controller --production
                        iobroker start
                        ja!
                          Hi Rainer
                          sorry ja unter Host ist der js controller auch auf dem neuesten Stand 0.9.0. Hatte ich auch alles gemacht.
                          Was kann ich noch machen?
                            Bitte folgendes alles auf der konsole ausführen und Fehlermeldungen sofort posten (cut and paste in code-tags)
                            zuerst einmal überprüfen, ob alles auf dem neuesten Stand ist.
                            cd /opt/iobroker
                            iobroker update
                            Sollte da hinter einem Adapter "updateable" stehen bitte diesen updaten, aber erst:
                            Da es ja immer sein kann, dass eine Datei beim Download korrupt ist, und damit diese auch wieder neu heruntergeladen wird, mache bitte als erstes:
                            cd /opt/iobroker
                            npm cache clean
                            Dann ggf. noch zu aktualisierende Adapter aktualisieren.
                            Da der Fehler anscheinend etwas mit dem hm-rpc zu tun hat würde ich jetzt erst einmal den neu installieren.
                            cd /opt/iobroker
                            iobroker stop
                            npm install iobroker.hm-rpc --production
                            iobroker start
                            Und dann mal sehen, ob es jetzt wieder läuft.
                              ok Danke versuche ich morgen sofort.
                                Hi hab alles jetzt so gemacht.
                                Geht aber noch immer nicht.
                                Im log steht immer noch:
                                Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                                raspberrypi	2016-07-04 20:27:47.231	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                raspberrypi	2016-07-04 20:27:47.230	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc.0	2016-07-04 20:27:47.133	info	hm-rpc.0 Disconnected
                                hm-rpc.0	2016-07-04 20:27:46.932	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                hm-rpc.0	2016-07-04 20:27:46.932	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                                hm-rpc.0	2016-07-04 20:27:46.930	error	uncaught exception: Cannot read property '2' of undefined
                                hm-rpc.0	2016-07-04 20:26:04.552	info	hm-rpc.0 Connected
                                hm-rpc.0	2016-07-04 20:26:03.236	info	hm-rpc.0 binrpc -> 143 devices
                                hm-rpc.0	2016-07-04 20:26:02.859	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:26:02.596	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:26:02.593	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                                hm-rpc.0	2016-07-04 20:26:02.182	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                raspberrypi	2016-07-04 20:25:59.522	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 2009
                                raspberrypi	2016-07-04 20:25:29.511	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                raspberrypi	2016-07-04 20:25:29.510	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc.0	2016-07-04 20:24:44.565	info	hm-rpc.0 Connected
                                hm-rpc.0	2016-07-04 20:24:43.252	info	hm-rpc.0 binrpc -> 143 devices
                                hm-rpc.0	2016-07-04 20:24:42.843	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:24:42.582	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:24:42.579	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                                hm-rpc.0	2016-07-04 20:24:42.172	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                raspberrypi	2016-07-04 20:24:39.539	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 1838
                                raspberrypi	2016-07-04 20:24:09.519	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                raspberrypi	2016-07-04 20:24:09.517	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc.0	2016-07-04 20:24:09.458	info	hm-rpc.0 Disconnected
                                hm-rpc.0	2016-07-04 20:24:09.457	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                hm-rpc.0	2016-07-04 20:24:09.457	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                                hm-rpc.0	2016-07-04 20:24:09.453	error	uncaught exception: Cannot read property '2' of undefined
                                hm-rpc.0	2016-07-04 20:24:09.221	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                hm-rpc.0	2016-07-04 20:24:09.220	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                                hm-rpc.0	2016-07-04 20:24:09.219	error	uncaught exception: Cannot read property '2' of undefined
                                hm-rpc.0	2016-07-04 20:24:08.978	info	hm-rpc.0 Connected
                                hm-rpc.0	2016-07-04 20:24:07.646	info	hm-rpc.0 binrpc -> 143 devices
                                hm-rpc.0	2016-07-04 20:24:07.240	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:24:06.968	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:24:06.965	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                                hm-rpc.0	2016-07-04 20:24:06.567	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                raspberrypi	2016-07-04 20:24:05.831	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 1748
                                raspberrypi	2016-07-04 20:23:33.657	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                raspberrypi	2016-07-04 20:23:33.656	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc.0	2016-07-04 20:23:33.575	info	hm-rpc.0 Disconnected
                                hm-rpc.0	2016-07-04 20:23:33.575	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                hm-rpc.0	2016-07-04 20:23:33.575	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                                hm-rpc.0	2016-07-04 20:23:33.574	error	uncaught exception: Cannot read property '2' of undefined
                                hm-rpc.0	2016-07-04 20:23:33.405	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                hm-rpc.0	2016-07-04 20:23:33.404	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                                hm-rpc.0	2016-07-04 20:23:33.402	error	uncaught exception: Cannot read property '2' of undefined
                                hm-rpc.0	2016-07-04 20:23:33.311	info	hm-rpc.0 Connected
                                hm-rpc.0	2016-07-04 20:23:31.925	info	hm-rpc.0 binrpc -> 143 devices
                                hm-rpc.0	2016-07-04 20:23:31.542	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:23:31.278	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                                hm-rpc.0	2016-07-04 20:23:31.275	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                                hm-rpc.0	2016-07-04 20:23:30.856	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                raspberrypi	2016-07-04 20:23:28.984	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 1739
                                raspberrypi	2016-07-04 20:22:57.953	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                raspberrypi	2016-07-04 20:22:57.952	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc.0	2016-07-04 20:22:57.874	info	hm-rpc.0 Disconnected
                                hm-rpc.0	2016-07-04 20:22:57.682	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                hm-rpc.0	2016-07-04 20:22:57.681	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                                hm-rpc.0	2016-07-04 20:22:57.678	error	uncaught exception: Cannot read property '2' of undefined
                                hm-rpc-0	2016-07-04 20:21:55.938	info	Connected
                                hm-rpc-0	2016-07-04 20:21:54.359	info	binrpc -> 143 devices
                                hm-rpc-0	2016-07-04 20:21:54.320	info	binrpc <- listDevices ['hm-rpc.0']
                                hm-rpc-0	2016-07-04 20:21:54.038	info	binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                                hm-rpc-0	2016-07-04 20:21:54.031	info	binrpc server is trying to listen on 192.168.2.138:2001
                                hm-rpc-0	2016-07-04 20:21:53.458	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                host-raspberrypi	2016-07-04 20:21:50.909	info	instance system.adapter.hm-rpc.0 started with pid 1651
                                host-raspberrypi	2016-07-04 20:21:20.887	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                                host-raspberrypi	2016-07-04 20:21:20.886	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc-0	2016-07-04 20:21:20.842	info	terminating
                                hm-rpc-0	2016-07-04 20:21:20.801	info	Disconnected
                                hm-rpc-0	2016-07-04 20:21:20.685	info	binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                TypeError:	2016-07-04 20:21:20.680	error	at TCP.onread (net.js:531:20)
                                TypeError:	2016-07-04 20:21:20.680	error	at Socket.Readable.push (_stream_readable.js:111:10)
                                TypeError:	2016-07-04 20:21:20.680	error	at readableAddChunk (_stream_readable.js:153:18)
                                TypeError:	2016-07-04 20:21:20.680	error	at Socket.emit (events.js:169:7)
                                TypeError:	2016-07-04 20:21:20.680	error	at emitOne (events.js:77:13)
                                TypeError:	2016-07-04 20:21:20.680	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
                                TypeError:	2016-07-04 20:21:20.680	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
                                TypeError:	2016-07-04 20:21:20.680	error	Cannot read property '2' of undefined
                                uncaught	2016-07-04 20:21:20.664	error	exception: Cannot read property '2' of undefined
                                hm-rpc-0	2016-07-04 20:20:46.258	info	Connected
                                hm-rpc-0	2016-07-04 20:20:44.616	info	binrpc -> 143 devices
                                hm-rpc-0	2016-07-04 20:20:44.576	info	binrpc <- listDevices ['hm-rpc.0']
                                hm-rpc-0	2016-07-04 20:20:44.299	info	binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                                hm-rpc-0	2016-07-04 20:20:44.293	info	binrpc server is trying to listen on 192.168.2.138:2001
                                hm-rpc-0	2016-07-04 20:20:43.752	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                host-raspberrypi	2016-07-04 20:20:41.198	info	instance system.adapter.hm-rpc.0 started with pid 1630
                                host-raspberrypi	2016-07-04 20:20:11.176	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                                host-raspberrypi	2016-07-04 20:20:11.175	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                                hm-rpc-0	2016-07-04 20:20:11.139	info	terminating
                                hm-rpc-0	2016-07-04 20:20:11.095	info	Disconnected
                                hm-rpc-0	2016-07-04 20:20:11.075	info	binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                                TypeError:	2016-07-04 20:20:11.068	error	at TCP.onread (net.js:531:20)
                                TypeError:	2016-07-04 20:20:11.068	error	at Socket.Readable.push (_stream_readable.js:111:10)
                                TypeError:	2016-07-04 20:20:11.068	error	at readableAddChunk (_stream_readable.js:153:18)
                                TypeError:	2016-07-04 20:20:11.068	error	at Socket.emit (events.js:169:7)
                                TypeError:	2016-07-04 20:20:11.068	error	at emitOne (events.js:77:13)
                                TypeError:	2016-07-04 20:20:11.068	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
                                TypeError:	2016-07-04 20:20:11.068	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
                                TypeError:	2016-07-04 20:20:11.068	error	Cannot read property '2' of undefined
                                uncaught	2016-07-04 20:20:11.047	error	exception: Cannot read property '2' of undefined
                                  Stimmen die Konfigurationen von hm-rpc und hm-rega noch?
                                  Irgendetwas scheint der hm-rpc einzulesen, mit dem er aber nicht klar kommt.
                                    Hallo sollte eigentlich stimmen.
                                    filename="IMG_20160630_1708479.jpg" index="0">~~ filename="IMG_20160630_1708199.jpg" index="1">~~ filename="IMG_20160630_1708171.jpg" index="2">~~
                                      Es waren keine Updates mehr offen (nur zwei Wetterupdates).
                                      Hast du noch eine Idee?
                                        HI
                                        aus irgend einen Grund war im RPC Adapter BIN-RPC anstatt XML-RPC eingestellt. Jetzt geht es wieder.
                                        Danke euch.
                                        1722
