    4. terminating http server on port 8081
    UNSOLVED terminating http server on port 8081
    • O
      oggy1979 last edited by oggy1979
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspbian light Buster
      Node-Version: 10.18.1
      Nodejs-Version: 10.18.1
      NPM-Version: 6.13.4
      Installationsart: Manuell
      Image genutzt: Ja
      Ort/Name der Imagedatei: https://www.iobroker.net/#de/download
      2020-01-14 18:35:28.356  - info: admin.0 (1437) terminating http server on port 8081
      2020-01-14 18:35:28.432  - info: admin.0 (1437) terminating
      2020-01-14 18:35:28.434  - info: admin.0 (1437) Terminated (NO_ERROR): Without reason
      2020-01-14 18:35:29.305  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
      2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
      2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
      2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
      2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at afterWrite (_stream_writable.js:485:3)
      2020-01-14 18:35:29.306  - error: host.raspberrypi Caught by controller[0]:     at onwrite (_stream_writable.js:476:7)
      2020-01-14 18:35:29.307  - error: host.raspberrypi Caught by controller[0]:     at InflateRaw.afterTransform (_stream_transform.js:94:3)
      2020-01-14 18:35:29.307  - error: host.raspberrypi Caught by controller[0]:     at Zlib.processCallback (zlib.js:557:8)
      2020-01-14 18:35:29.307  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2020-01-14 18:35:29.307  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      Fehler wird seit Neustart des Raspbian geloggt. Zuvor ist er durch einen Stromausfall leider wenige Sekunden vom Stromnetz getrennt gewesen 😕
      Was ist das bzw wie kann ich das lösen?
      error iobroker absturz startet nicht error terminating http server port 8
