    4. iobroker.mqtt kill every 3 mins
    UNSOLVED iobroker.mqtt kill every 3 mins
      ManuelW last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Linux PC
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu 18.x LTS
      Node-Version: 10.18.1
      Nodejs-Version: 10.18.1
      NPM-Version: 6.13.4
      Installationsart: Adapter Admin
      Image genutzt: Nein
      seit meinem Update von node 8.x auf 10.x wird der iobroker.mqtt Adapter regelmäßig alle ca. 3min gekillt. Ich habe keine cron eingerichtet die das machen.
      2020-01-18 08:32:30.351  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:36:01.402  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:39:32.456  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:43:03.497  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:46:34.538  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:50:05.601  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:53:36.723  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 08:57:07.771  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 09:00:38.887  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 09:04:09.936  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 09:07:40.980  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 09:11:12.023  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 09:14:43.067  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-18 09:18:14.124  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
      2020-01-16 13:29:06.642  - info: mqtt.0 (19331) send2Server system.adapter.admin.0.sigKill[undefined]
      2020-01-16 13:29:06.642  - info: mqtt.0 (19331) send2Server system.adapter.admin.0.sigKill[system/adapter/admin/0/sigKill]
      2020-01-16 13:29:06.645  - warn: admin.0 (18309) Got terminate signal. Checking desired PID:  vs own PID 18309
      2020-01-16 13:29:06.650  - info: admin.0 (18309) terminating http server on port 8081
      2020-01-16 13:29:06.651  - info: admin.0 (18309) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-01-16 13:29:07.165  - error: host.zeus instance system.adapter.admin.0 terminated with code 156 (156)
      2020-01-16 13:29:07.166  - info: host.zeus Restart adapter system.adapter.admin.0 because enabled
      Ich habe mich an die node Upgradeanleitung aus dem Forum gehalten und bereits alles mögliche versucht, bis hin zur Neuinstallation von iobroker (mit Altdatenübernahme iobroker-data), jedoch bekomme ich es nicht gelöst.
      • PrRu
        PrRu last edited by
        Do not use pattern '*' on field 'Mask to publish own states'. It causes an error
        iobroker.mqtt kill restarts
