    4. iobroker startet nicht mehr
    SOLVED iobroker startet nicht mehr
    • U
      URI3L last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspbian Buster Lite
      Node-Version: v10.18.1
      Nodejs-Version: v10.18.1
      NPM-Version: 6.13.4
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Hallo liebe Community,
      ich bin seit ein paar Tagen von OpenHab auf ioBroker umgestiegen. Und bei der Installation kam schon folgende Fehlermeldung:
      pi@IOBROKER:/opt/iobroker $ npm install iobroker.js-controller
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      > iobroker.js-controller@2.1.1 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.13.4
      > iobroker.js-controller@2.1.1 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      No objects found!
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 101
      npm ERR! iobroker.js-controller@2.1.1 install: `node iobroker.js setup first`
      npm ERR! Exit status 101
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@2.1.1 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2020-01-22T19_57_47_946Z-debug.log
      Ich fuhr mit der Installation von iobroker dennoch fort und es klappte. Ich habe mir ein paar Adapter installiert (Harmony, Milight, Homematic und Visualisierung). Da der Aufruf der Visualisierung über Port 8082 nicht funktionierte, habe ich den Pi3 mit "sudo reboot" neugestartet. Jetzt habe ich das Problem, dass iobroker nicht mehr startet.
      ein "iobroker list" ergibt folgendes:
      pi@IOBROKER:/opt/iobroker $ iobroker list
      internal/modules/cjs/loader.js:638
          throw err;
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      Ich bin gerade ziemlich ratlos. Muss ich das ganze von neu installieren?
      War anfangs froh über den Umstieg, da mein OpenHab nicht stabil gelaufen ist. Und wurde schon bei der Installation von iobroker mit einer Fehlermeldung begrüßt (siehe oben).
      Vielen Dank 🙂
      • sigi234
        sigi234 Forum Testing Most Active @URI3L last edited by sigi234
        @URI3L
        Was kommt bei:
        cd /opt/iobroker
        node -v
        nodejs -v
        npm -v
        https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
        • U
          nach langem Kampf habe ich jetzt den iobroker nochmal komplett neu aufgesetzt, obwohl node, nodejs und npm auf den jeweils aktuellen Stand war. Jetzt funktioniert es. Leider kann ich nicht sagen, woran es gelegen hat.
          Vielen Dank.
          installation raspberrypi installationsfehler iobroker absturz iobroker startet nicht mehr vis funktioniert nicht
