    4. Log-Error trotz exited with code 0
    SOLVED Log-Error trotz exited with code 0
    • Negalein
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Synology Docker
      Arbeitsspeicher: 10GB
      Festplattenart: HDD
      Betriebssystem: Synology
      Node-Version: 10.17.0
      Nodejs-Version: 10.17.0
      NPM-Version: 6.11.3
      Installationsart: Image
      Image genutzt: Ja
      Ort/Name der Imagedatei: Buanet
      Hallo
      Seit neuestem bekomme ich bei jedem Update Meldungen, die mich irritieren.
      Update wird zwar mit process exited with code 0 abgeschlossen und funktioniert auch.
      Was bedeuten die Meldungen (vorallem kommen auch ERR darin vor)?
      $ ./iobroker upgrade zigbee
      Update zigbee from @0.11.5 to @1.0.0
      NPM version: 6.11.3
      npm install iobroker.zigbee@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
      ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
      ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?     return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);                                       ^~~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
      ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
      ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^
      In file included from ../src/bufferutil.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^
      In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);                                                    ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "mask", BufferUtil::Mask);                                                ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "merge", BufferUtil::Merge);                                                  ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> bufferObj = args[0]->ToObject();                                                 ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Local<Object> src = array->Get(i)->ToObject();                                                   ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> output_obj = args[2]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int dataOffset = args[3]->Int32Value();                                                   ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int length = args[4]->Int32Value();                                               ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
      gyp
      ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp
       ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.4.59+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^
      In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^
      In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^
      In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
      ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/validation.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
      In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^
      In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^
      In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
      ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
      make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR!
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR!
       not ok
      Update "system.adapter.zigbee.0"
      upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
      upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_g_spot.png img/osram_g_spot.png image/png
      upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_vibration.png img/lumi_vibration.png image/png
      upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/livolo.png img/livolo.png image/png
      upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/konke_kpft.png img/konke_kpft.png image/png
      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr.png img/innr.png image/png
      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_led1837r5.PNG img/ikea_led1837r5.PNG image/png
      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hs1sa.png img/hs1sa.png image/png
      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/fnb56zsw01.png img/fnb56zsw01.png image/png
      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
      upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
      upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
      upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/contact.png img/contact.png image/png
      upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_plug.png img/bitron_plug.png image/png
      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
      upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
      upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/basiczbr3.png img/basiczbr3.png image/png
      upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
      upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
      upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
      upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
      upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
      upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
      upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
      upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
      Adapter "zigbee" updated
      process exited with code 0
        arteck Developer Most Active @Negalein last edited by
        @Negalein die Adapter sind ja nicht nur für DEIN System geschrieben mit DEINER bodejs und und und...
        es wrd versucht zu kompilieren während der Installtion und wenn das eben nicht auf deinem System geht dann wird weiter zum nächsten Statement übergegangen..
        also Systemabhängig bekommst du Fehler ...
        wichtig ist eben der
        Negalein 1 Reply Last reply Reply Quote 1
        • Negalein
          Negalein Global Moderator @arteck last edited by
          @arteck sagte in Log-Error trotz exited with code 0:
          Danke für die Erklärung.
          Jetzt ist mir das klar.
          error
