    5. [Vorlage] Simple Anrufer-Ansage via Alexa/tr-064
    • StrathCole
      StrathCole last edited by StrathCole
      Anbei ein kleines Javascript für eine Ansage des Anrufers bzw. der Nummer über den Alexa2-Adapter.
      Benötigt wird auch der tr-064-Adapter (aktuelle 3.x Version) für das Empfangen der Fritz!Box-Daten.
      //* Insert own numbers with description
      const numbers = {
          '01234512345': 'privat',
          '01234522222': 'Büro'
      function tellMeWhoCalls(sayattention) {
          let curtime = new Date();
          //* not between 21pm and 7am UTC
          if(curtime.getHours() < 7 || curtime.getHours() > 21) {
              return;
          let targ = getState('tr-064.0.callmonitor.inbound.callee').val;
          let src = getState('tr-064.0.callmonitor.inbound.caller').val;
          let srcName = getState('tr-064.0.callmonitor.inbound.callerName').val;
          let targName = numbers[targ];
          if(!targName) {
              targName = 'unbekannt';
          let text = (sayattention ? 'Achtung! ' : '') + 'Anruf für ' + targName + ' von ';
          if(srcName) {
              text += srcName;
          } else if(src) {
              text += '<say-as interpret-as="digits">' + src + '</say-as>';
          } else {
              text += 'unbekannter Nummer';
          text += '.';
          text = '<speak>' + text + '</speak>';
          //* replace XXXXX by your echo device id and add further lines for more devices
          setState('alexa2.0.Echo-Devices.XXXXXXX.Commands.ssml', text);
          if(targName === 'privat') {
              //* replace YYYYYY by your echo device id or delete this part if you don't need it
              setState('alexa2.0.Echo-Devices.YYYYYYYY.Commands.ssml', text);
      let ringInterval = null;
      on({id: 'tr-064.0.callmonitor.ringing', change: 'ne'}, function(obj) {
          if(obj.state.val !== true) {
              //* no longer ringing
              if(ringInterval) {
                  clearInterval(ringInterval);
              return;
          if(ringInterval) {
          //* repeat caller anouncement each 10 secs
          ringInterval = setInterval(function() {
              tellMeWhoCalls();
          }, 10000);
          //* first time add "Achtung!" in front of the text
          setTimeout(function() {
              tellMeWhoCalls(true);
          }, 1000);
        jensus11 last edited by
        Ich habe dein Script importiert, doch leider sagt Alexa nichts.
        tr-064 und Alexa2 sind natürlich installiert.
        Angepasst im Script habe ich die XXXXX für Alexa und die Nummer für privat.
        Den zweiten für ein zweites Alexa Gerät habe ich gelöscht.
        Was könnte ich denn verkehrt gemacht haben?
          jensus11 @jensus11 last edited by
          @jensus11 sagte in [Vorlage] Simple Anrufer-Ansage via Alexa/tr-064:
          Habe es selber hinbekommen. Lag am alten tr-064. Mit der 3.1.4 läuft das.
            bergbock @StrathCole last edited by
            Hat auch 3 Jahre später noch gut funktioniert! 🙂
            Vielen Dank 👍
            1.1k
            81.1k
            communication javascript
