    4. TR 064 Error beim installieren
    SOLVED TR 064 Error beim installieren
    • bahnuhr
      Habe neu installiert.
      Folgende Fehlermeldungen:
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at promise.then (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at tryCatcher (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at (anonymous function).get (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\iobroker.objects-redis\index.js:1:77706)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at objects.getObject (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:2450:65)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at adapter.getForeignObject (C:\ioBroker\node_modules\iobroker.tr-064\main.js:115:13)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: at main (C:\ioBroker\node_modules\iobroker.tr-064\main.js:1119:49)
      host.Asus-Buero	2020-01-31 17:28:14.477	error	Caught by controller[0]: ReferenceError: secret is not defined
      tr-064.0	2020-01-31 17:28:13.700	info	(22680) Terminated (NO_ERROR): Without reason
      tr-064.0	2020-01-31 17:28:13.700	info	(22680) terminating
      tr-064.0	2020-01-31 17:28:13.666	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      tr-064.0	2020-01-31 17:28:13.666	error	at promise.then (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
      tr-064.0	2020-01-31 17:28:13.666	error	at tryCatcher (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
      tr-064.0	2020-01-31 17:28:13.666	error	at (anonymous function).get (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\iobroker.objects-redis\index.js:1:77706)
      tr-064.0	2020-01-31 17:28:13.666	error	at objects.getObject (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:2450:65)
      tr-064.0	2020-01-31 17:28:13.666	error	at adapter.getForeignObject (C:\ioBroker\node_modules\iobroker.tr-064\main.js:115:13)
      tr-064.0	2020-01-31 17:28:13.666	error	at main (C:\ioBroker\node_modules\iobroker.tr-064\main.js:1119:49)
      tr-064.0	2020-01-31 17:28:13.666	error	(22680) ReferenceError: secret is not defined
      tr-064.0	2020-01-31 17:28:13.664	error	(22680) uncaught exception: secret is not defined
      • bahnuhr
        So, habe den neuen community Adapter deinstalliert.
        Läuft nicht mehr.
        Und den alten von soef wieder installiert (läuft ja auf meinem win7 noch).
        Der läuft und lief zuverlässig.
        • bahnuhr
          Nachtrag:
          Der neue Adapter aktualisiert nicht ringing und callername
          Der alte schon.
          • Negalein
            Negalein Global Moderator @bahnuhr last edited by Negalein
            @bahnuhr sagte in TR 064 Error beim installieren:
            Läuft nicht mehr.
            Den Community gibt es nicht mehr.
            Das Team arbeitet am normalen TR-064 weiter.
            Siehe auch hier
            • bahnuhr
              bahnuhr Forum Testing Most Active @Negalein last edited by
              @Negalein sagte in TR 064 Error beim installieren:
              Mag ja sein, nur funktioniert dieser nicht mehr.
              Der alte von soef, direkt von gut, klappt
              • Negalein
                welche Version und wie installiert?
                Siehe auch hier
                • bahnuhr
                  Deine Fragen sind schon manchmal klasse.
                  Hab ich doch klar geschrieben.
                  Direkt von git
                  Aktuell 0.4.18
                  J sigi234 Negalein 3 Replies Last reply Reply Quote 0
                    Jan1 @bahnuhr last edited by
                    @bahnuhr
                    Und warum nicht über Admin, dann läuft er auch. Steht auch so im passenden Thread den man auch hätte mal lesen können.
                    bahnuhr 1 Reply Last reply Reply Quote 1
                    • sigi234
                      sigi234 Forum Testing Most Active @bahnuhr last edited by
                      Aktuell 0.4.18
                      Falsch!
                      https://forum.iobroker.net/topic/29456/tr-064-v3-1-x-latest-repo-diskussion/59
                      J bahnuhr 2 Replies Last reply Reply Quote 0
                        Jan1 @sigi234 last edited by Jan1
                        @sigi234
                        Ist wie immer, meckern und die falsche Version aus der falschen Quelle laden.
                        • Negalein
                          Zumindest gehe ich auf DEINE Fragen ein und geb dir PASSENDE Antworten.
                          hast du eben nicht.
                          Ich sehe in dem ganzen Thema erst jetzt, dass du 0.4.18 direkt von GIT installiert hast.
                          • bahnuhr
                            bahnuhr Forum Testing Most Active @sigi234 last edited by
                            @sigi234 sagte in TR 064 Error beim installieren:
                            Falsch!
                            https://github.com/soef/ioBroker.tr-064.git
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @Jan1 last edited by
                              @Jan1 sagte in TR 064 Error beim installieren:
                              Den habe ich gelesen, und bei mir läuft er eben nicht.
                              • sigi234
                                sigi234 Forum Testing Most Active @bahnuhr last edited by sigi234
                                Falsch!
                                https://www.npmjs.com/package/iobroker.tr-064
                                Ich muss zugeben es ist ein bisschen verwirrend.
                                • bahnuhr
                                  Klasse Aussage.
                                  Warum mecker ich.
                                  Ich habe doch nur darauf aufmerksam gemacht, dass die neue bei mir nicht läuft und o.g. Fehler produziert.
                                  Nach dem Wechsel auf die soef Version läuft alles.
                                  Nicht mehr, aber auch nicht weniger.
                                    @bahnuhr
                                    Die neue Version läuft bei vielen und Du willst die alte haben weil die bei Dir angeblich läuft, was sie aber nicht macht.
                                    Wäre es nicht besser das Problem an Deinem System zu suchen und dann den aktuellen zu verwenden?
                                    • Negalein
                                      Und in dem von mir verlinktem Thema steht Nicht mehr vom github installieren. 3.1.4 von npm
                                      Weil es aktuell ein Problem gibt.
                                      • bahnuhr
                                        So, jetzt nochmal
                                        Ich habe:
                                        node 10.18.0
                                        npm 6.13.4
                                        js-contr. 2.1.1
                                        Verwahr steht auf stable
                                        Angeboten wird mir:
                                        die 0.4.14.
                                        Über das Octa.. hab ich nun die 3.2.0 installiert.
                                        Wenn ich die konfig eingegeben habe kommt dann im log:
                                        host.Asus-Buero	2020-01-31 19:20:55.823	info	Restart adapter system.adapter.tr-064.0 because enabled
                                        host.Asus-Buero	2020-01-31 19:20:55.823	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                                        host.Asus-Buero	2020-01-31 19:20:55.822	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: at promise.then (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: at tryCatcher (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: at (anonymous function).get (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\iobroker.objects-redis\index.js:1:77706)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: at objects.getObject (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:2450:65)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: at adapter.getForeignObject (C:\ioBroker\node_modules\iobroker.tr-064\main.js:115:13)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: at main (C:\ioBroker\node_modules\iobroker.tr-064\main.js:1119:49)
                                        host.Asus-Buero	2020-01-31 19:20:55.821	error	Caught by controller[0]: ReferenceError: secret is not defined
                                        host.Asus-Buero	2020-01-31 19:20:52.358	info	instance system.adapter.tr-064.0 started with pid 17000
                                        sigi234 J 2 Replies Last reply Reply Quote 0
                                        • sigi234
                                          @bahnuhr
                                          Probier mal einen Neustart, und die Daten im Adapter nochmal eingeben. IP-Benutzer-Passwort
                                            Jan1 @bahnuhr last edited by Jan1
                                            @bahnuhr
                                            Über Admin die 3.1.4 installieren. Du versuchst ne defekte Version zu installieren und das ist Dein Problem.
                                            Steht aber genau so im anderen Thread.
                                            error tr064
                                            888
