    5. [gelöst]JSON.parse Problem mit WienerLinien Daten
      Stephan66 last edited by Stephan66
      Ich habe nun folgendes Problem. Die Wiener Linien stellen mit einem Aufruf (z.B. Abfahrtsdaten77A-Lusthaus JSON Daten für den Abfahrtsmonitor zur Verfügung.
      {"data":{"monitors":[{"locationStop":{"type":"Feature","geometry":{"type":"Point","coordinates":[16.4401136,48.1934097]},"properties":{"name":"60200818","title":"Lusthaus, Aspernallee","municipality":"Wien","municipalityId":90001,"type":"stop","coordName":"WGS84","attributes":{"rbl":2139}}},"lines":[{"name":"77A","towards":"Rennweg S","direction":"R","platform":"2","richtungsId":"2","barrierFree":true,"realtimeSupported":true,"trafficjam":false,"departures":{"departure":[{"departureTime":{"timePlanned":"2020-02-02T18:27:00.000+0100","timeReal":"2020-02-02T18:27:00.000+0100","countdown":8}},{"departureTime":{"timePlanned":"2020-02-02T18:37:00.000+0100","timeReal":"2020-02-02T18:37:00.000+0100","countdown":18}},{"departureTime":{"timePlanned":"2020-02-02T18:47:00.000+0100","timeReal":"2020-02-02T18:47:00.000+0100","countdown":28}},{"departureTime":{"timePlanned":"2020-02-02T18:57:00.000+0100","timeReal":"2020-02-02T18:57:00.000+0100","countdown":38}},{"departureTime":{"timePlanned":"2020-02-02T19:07:00.000+0100","timeReal":"2020-02-02T19:07:00.000+0100","countdown":48}},{"departureTime":{"timePlanned":"2020-02-02T19:17:00.000+0100","timeReal":"2020-02-02T19:17:00.000+0100","countdown":58}},{"departureTime":{"timePlanned":"2020-02-02T19:27:00.000+0100","timeReal":"2020-02-02T19:27:00.000+0100","countdown":68}}]},"type":"ptBusCity","lineId":477}],"attributes":{}}]},"message":{"value":"OK","messageCode":1,"serverTime":"2020-02-02T18:18:38.000+0100"}}
      Sind also die Rohdaten.
      mit folgendem Code
      on({id: "parser.0.WL77A", change: 'any'}, function(obj) {
      var gasStation = JSON.parse(obj.state.val);
      if (!Array.isArray(gasStation) ) {
      log ("Array nicht angelegt!");
      return;
      if (gasStation.length === 0) {
      log ("Array hat Länge 0");
      return;
      var myStation = obj.data.monitors[0].locationStop.properties.title;
      log ("Station: " + myStation);
      komme ich nur bis: Array nicht angelegt!
      Da klappt das parsen wohl nicht.
      Im Adapter habe ich wie folgt eingestellt:
      ![Bild Text](3ef11c63-731c-4db8-b089-8f43f4a49bfc-grafik.png Bild Link)
      Was mache ich da falsch?
        paul53 @Stephan66 last edited by
        @Stephan66 sagte:
        Der "Umweg" über den Parser-Adapter ist nicht nötig, da man den JSON direkt per request() von der Webseite einlesen kann. Welche Werte brauchst Du ?
          Vielen Dank für die rasche Antwort.
          Benötigt werden nur die Daten von departure: "0"-"3" TimePlanned, TimeReal und countdown.
          Also eigentlich nur diese 12 Werte. Sollten dann in Datenpunkte geschrieben werden - dürfte aber dann das geringere Problem sein.
            paul53 @Stephan66 last edited by paul53
            @Stephan66 sagte:
            Anstelle von log in Datenpunkte schreiben:
            const url = 'https://www.wienerlinien.at/ogd_realtime/monitor?rbl=2139';
            function abfahrten() {
                request(url, function(error, response, result) {
                    let zeiten = JSON.parse(result).data.monitors[0].lines[0].departures.departure;
                    let anzahl = zeiten.length;
                    if(anzahl > 4) anzahl = 4;
                    for(let i = 0; i < anzahl; i++) {
                        log(zeiten[i].departureTime.timePlanned);
                        log(zeiten[i].departureTime.timeReal);
                        log(zeiten[i].departureTime.countdown);
            schedule('* * * * *', abfahrten); // jede Minute
              @paul53 sagte in JSON.parse Problem mit WienerLinien Daten:
              Super. Klappt. Vielen Dank.
              Da habe ich wohl über zu viele Ecken gedacht.
              Ich bastle dann mal weiter.
              javascript
