    4. Javascript Adapter geht ständig auf rot
    SOLVED Javascript Adapter geht ständig auf rot
      martin last edited by
      Systemdata Bitte Ausfüllen
      Arbeitsspeicher: 16GB
      Festplattenart: HDD
      Mein Javacript-Adapter wechselt seit heute ständig zwischen Status rot und grün.
      Habe jetzt ein Update auf die neueste Version gemacht, aber das brachte auch keinen Erfolg.
      Hier die Daten aus dem Log:
      javascript.0	2020-02-06 18:11:19.825	info	terminating
      javascript.0	2020-02-06 18:11:19.769	error	at Zlib.callback (zlib.js:515:5)
      javascript.0	2020-02-06 18:11:19.769	error	at InflateRaw.afterTransform (_stream_transform.js:90:3)
      javascript.0	2020-02-06 18:11:19.769	error	at onwrite (_stream_writable.js:454:7)
      javascript.0	2020-02-06 18:11:19.769	error	at afterWrite (_stream_writable.js:463:3)
      javascript.0	2020-02-06 18:11:19.769	error	at _inflate.flush (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:386:7)
      javascript.0	2020-02-06 18:11:19.769	error	at _decompress (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:306:9)
      javascript.0	2020-02-06 18:11:19.769	error	at perMessageDeflate.decompress (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:349:40)
      javascript.0	2020-02-06 18:11:19.769	error	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
      javascript.0	2020-02-06 18:11:19.769	error	at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
      javascript.0	2020-02-06 18:11:19.769	error	at WebSocket.emit (events.js:211:7)
      javascript.0	2020-02-06 18:11:19.769	error	at emitOne (events.js:116:13)
      javascript.0	2020-02-06 18:11:19.769	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
      javascript.0	2020-02-06 18:11:19.769	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
      javascript.0	2020-02-06 18:11:19.769	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
      javascript.0	2020-02-06 18:11:19.769	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
      javascript.0	2020-02-06 18:11:19.769	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2020-02-06 18:11:19.769	error	at WS.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
      javascript.0	2020-02-06 18:11:19.769	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
      javascript.0	2020-02-06 18:11:19.769	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2020-02-06 18:11:19.769	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2020-02-06 18:11:19.769	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
      javascript.0	2020-02-06 18:11:19.769	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
      javascript.0	2020-02-06 18:11:19.769	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2020-02-06 18:11:19.769	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2020-02-06 18:11:19.769	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      javascript.0	2020-02-06 18:11:19.769	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      javascript.0	2020-02-06 18:11:19.769	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      javascript.0	2020-02-06 18:11:19.769	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
      javascript.0	2020-02-06 18:11:19.769	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
      javascript.0	2020-02-06 18:11:19.769	error	at Socket.adapter.objects.getObjectList (/opt/iobroker/node_modules/iobroker.javascript/main.js:1556:58)
      javascript.0	2020-02-06 18:11:19.769	error	at getData (/opt/iobroker/node_modules/iobroker.javascript/main.js:520:29)
      javascript.0	2020-02-06 18:11:19.769	error	TypeError: adapter.getObjectView is not a function
      javascript.0	2020-02-06 18:11:19.769	error	uncaught exception: adapter.getObjectView is not a function
      javascript.0	2020-02-06 18:11:19.754	info	received all objects
      javascript.0	2020-02-06 18:11:17.851	info	received all states
      javascript.0	2020-02-06 18:11:14.630	info	requesting all objects
      javascript.0	2020-02-06 18:11:14.624	info	requesting all states
      javascript.0	2020-02-06 18:11:14.606	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2020-02-06 18:11:14.589	info	starting. Version 4.3.7 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.15.0
      javascript.0	2020-02-06 18:11:06.986	info	requesting all objects
      javascript.0	2020-02-06 18:11:06.984	info	requesting all states
      javascript.0	2020-02-06 18:11:06.967	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2020-02-06 18:11:06.951	info	starting. Version 4.3.7 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.15.0
      Bitte um Hilfe!
      • crunchip
        crunchip Forum Testing Most Active @martin last edited by crunchip
        @martin dein Land, Stadt Breiten/Längengrad hinterlegt? Da du in einem Script die Astro Funktion benutzt
          Ja, da ist alles drin. Habe auch nichts geändert.
          Er zeigt mir beim "Admin" ein Update an. Wenn ich drauf klicke kommt nach 1 Sekunde "Erfolgreich", aber passiert ist nichts.
          • crunchip
            @martin das auch aktiviert?
              Ja, da ist der Haken auch drin.
                martin @martin last edited by
                @martin said in Javascript Adapter geht ständig auf rot:
                Ich lasse ihn jetzt mal alle Adapter upgraden. Jetzt erzählt er nämlich von 20 Stück, vorher warens nur 3.
                Mal sehen obs was bringt.
                • crunchip
                  @martin dann hab ich leider auch keine Idee mehr
                  mit dieser Meldung kann ich leider nichts anfangen
                    @crunchip sagte in Javascript Adapter geht ständig auf rot:
                    Naja, der Haken muss raus 😉
                    Wenn der drin ist werden nicht die Werte im Adapter genommen.
                    Leider müssen aber diese genommen werden
                    • crunchip
                      @Homoran heisst? Astro über System funktioniert nicht mehr?
                        @crunchip ich fürchte da hat es immer schon Probleme mit gegeben.
                        Nur wenn die Koordinaten im Adapter eingegeben waren hat es IMMER funktioniert
                          paul53 @Homoran last edited by paul53
                          @Homoran sagte:
                          Es gab einmal Versionen des JS-Adapters, bei denen es mit dem Haken funktioniert hat. Da ich immer die Koordinaten in der JS-Instanz eintrage (2 Wohnorte), kann ich nicht sagen, ab welcher Version es nicht mehr funktioniert.
                          crunchip Homoran 2 Replies Last reply Reply Quote 0
                          • crunchip
                            crunchip Forum Testing Most Active @paul53 last edited by
                            @paul53 @Homoran ich habe den Haken schon immer drin und es funktioniert nach wie vor, hatte noch nie Probleme, deshalb Frage ich
                              Okay.
                              Koordinaten habe ich in den iobroker-Einstellungen drin.
                              Er ist noch beim Update.
                              Wenn es nicht klappt versuche ich es mal ohne Haken.
                                @paul53 sagte in Javascript Adapter geht ständig auf rot:
                                So sehe ich es auch
                                Außerdem kann es ohner weiteres sein, dass das "nicht-funktionieren" von "beutze Systemeinstellungen" ggf. auch von anderemn Faktoren wie js-controller Version oder admin Version, ggf. auch node und npm ... abhängig war/ist, so dass es bei einigen Usern klappt, bei anderen nicht.
                                Ich weiß lediglich, dass es (nach meiner Erinnerung) immer geklappt hat, wenn man die Koordinaten im javascript Adapter eingetragen (und den Haken rausgenommen) hatte.
                                  So, 16 von 20 Adaptern upgedatet.
                                  Javascript scheint wieder problemlos zu laufen.
                                  4 Stück nicht. Da kommt sofort erledigt.
                                  Kann ich die Adapter (z.B. Admin) irgendwie über die Konsole oder Putty updaten?
                                  • crunchip
                                    @martin https://github.com/ioBroker/ioBroker/wiki/Console-commands
                                      @crunchip hilfe!
                                      Vorsicht vor verlinkungen auf das Wiki auf Github.
                                      Mit viel "Glück" findest du da noch meine erste Doku von 2015 - mit allen "aktuellen" Anleitungen 😂
                                        Also würde
                                        iobroker upgrade Admin
                                        den Admin-Adapter updaten? Oder muss da noch eine URL etc. dazu? Wenn ja, wo finde ich die???
                                          Homoran Global Moderator Administrators @martin last edited by
                                          @martin sagte in Javascript Adapter geht ständig auf rot:
                                          Es reich iobroker update admin
                                          Dazu musst du aber mit putty o.ä. eine ssh Verbindung auf deinen Raspi machen
                                          • crunchip
                                            @Homoran in dem Fall glaub ich....ist das schon ok😉
                                            Hab auf die schnelle nix neueres gefunden😜
                                            javascript adapter rot
                                            1285
