    4. Fehler bei installation des Harmony Adapters
      myol last edited by
      ich bin mit meinen iobroker auf nen neuen Raspi3 umgestiegen und habe dabei genau die Anleitung von iobroker.net befolgt.
      Habe ein Jessie light drauf, iobroker läuft auch soweit, nur bei der installation kommt folgender Fehler:
      $ ./iobroker add harmony
      npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      npm
       WARN engine harmonyhubjs-client@1.1.8: wanted: {"npm":">=3.0.0"} (current: {"node":"4.4.7","npm":"2.15.8"})
      npm
       WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      npm
       WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)
      npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
      npm
       ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefined
      npm
       ERR! Linux 4.4.15-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v4.4.7
      npm ERR! npm  v2.15.8
      npm ERR! code ENOGIT
      npm ERR! not found: git
      npm ERR!
      npm ERR! Failed using git.
      npm ERR! This is most likely not a problem with npm itself.
      npm ERR! Please check if you have git installed and in your PATH.
      npm ERR! Please include the following file with any support request:npm ERR!     /opt/iobroker/node_modules/npm-debug.log
      ERROR: host.Raspi3 Cannot install iobroker.harmony: 1
      ERROR: process exited with code 25
      Ich bin in Linux nicht sonderlich bewandert.
      Kann mit jemand helfen?
      Ich scheint ja mit der npm-Version zusammenzhängen, aber das ist ja die ganz frische nodejs-Installation aus der Anleitung …
      Schon mal Danke im voraus und Gruß,
      Oliver
        Die npm Version die vom Harmony Adapter angefordert wird ist tatsächlich neuer als die installierte. Allerdings gibt es mit npm 3.xx Probleme.
        Gottseidank ist dies auch nur eine WARNung und kein ERROR.
        Diesen hast du dann mit ENOGIT. Soll heißen Error NO Gut installiert.
        Ich habe auch RaspBIAN Lite drauf und kann mich nicht erinnern gut installiert zu haben und hatte keine Probleme mit dem Harmony Adapter.
        Probiere mal
         sudo apt-get install git
        Schlimmstenfalls kommt eine Meldung in etwa wie
        git ist bereits die aktuelle Version.
        Wenn etwas installiert wird, danach nochmal den Adapter installieren.
          myol last edited by
          Danke!
          Scheint funktioniert zu haben.
          Die Installation sah dann so aus:
          root@Raspi3:/opt/iobroker# ./iobroker add harmony
          npm WARN engine harmonyhubjs-client@1.1.8: wanted: {"npm":">=3.0.0"} (current: {"node":"4.4.7","npm":"2.15.8"})
          npm WARN addRemoteGit Error: Command failed: git config --get remote.origin.url
          npm WARN addRemoteGit     at ChildProcess.exithandler (child_process.js:213:12)
          npm WARN addRemoteGit     at emitTwo (events.js:87:13)
          npm WARN addRemoteGit     at ChildProcess.emit (events.js:172:7)
          npm WARN addRemoteGit     at maybeClose (internal/child_process.js:827:16)
          npm WARN addRemoteGit     at Socket. <anonymous>(internal/child_process.js:319:11)
          npm WARN addRemoteGit     at emitOne (events.js:77:13)
          npm WARN addRemoteGit     at Socket.emit (events.js:169:7)
          npm WARN addRemoteGit     at Pipe._onclose (net.js:486:12)
          npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-           remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: Command failed: git config --get remot           e.origin.url
          npm WARN addRemoteGit ]
          npm WARN addRemoteGit   killed: false,
          npm WARN addRemoteGit   code: 1,
          npm WARN addRemoteGit   signal: null,
          npm WARN addRemoteGit   cmd: 'git config --get remote.origin.url' }
          host.Raspi3 install adapter harmony
          got /opt/iobroker/node_modules/iobroker.harmony/admin
          upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
          upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
          host.Raspi3 object system.adapter.harmony created
          host.Raspi3 create instance harmony
          host.Raspi3 object system.adapter.harmony.0.uptime created
          host.Raspi3 object system.adapter.harmony.0.memRss created
          host.Raspi3 object system.adapter.harmony.0.memHeapTotal created
          host.Raspi3 object system.adapter.harmony.0.memHeapUsed created
          host.Raspi3 object system.adapter.harmony.0.connected created
          host.Raspi3 object system.adapter.harmony.0.alive created
          host.Raspi3 object system.adapter.harmony.0 created</anonymous>
          Viele Warnungen, aber das Adapte ist jetzt drauf.
          Mal sehen, ob er stabil läuft. 🙂
          Gruß,
          Oliver
