    4. Homeconnect errors after update JScontroller 2.1.1 to 2.2.8
    UNSOLVED Homeconnect errors after update JScontroller 2.1.1 to 2.2.8
    • Y
      ydn last edited by ydn
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4b
      Arbeitsspeicher: 2GB
      Festplattenart: SD-Karte_32G_aDataV90
      Betriebssystem: ioBroker
      Node-Version: v10.19.0
      Nodejs-Version: 2.2.8
      NPM-Version: 6.13.4
      Installationsart: Skript>basic example image, followed all update instructions
      Image genutzt: ?
      Ort/Name der Imagedatei: 2019-11-27
      After the updating of JScontroller to version 2.2.8 ik HomeConnect is not starting anymore. It's probably my fault, the updates was blinking there was a new version, so I upgraded it.... So now i'm in trouble. I'll roll back to old version. But maybe someone is interested in the error 🙂 The log says:
      homeconnect.0	2020-02-08 12:51:19.814	info	(941) Terminated (NO_ERROR): Without reason
      homeconnect.0	2020-02-08 12:51:19.811	info	(941) terminating
      homeconnect.0	2020-02-08 12:51:19.803	info	(941) cleaned everything up...
      homeconnect.0	2020-02-08 12:51:19.799	error	at Timer.processTimers (timers.js:223:10)
      homeconnect.0	2020-02-08 12:51:19.799	error	at listOnTimeout (timers.js:263:5)
      homeconnect.0	2020-02-08 12:51:19.799	error	at tryOnTimeout (timers.js:300:5)
      homeconnect.0	2020-02-08 12:51:19.799	error	at ontimeout (timers.js:436:11)
      homeconnect.0	2020-02-08 12:51:19.799	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:934:35)
      homeconnect.0	2020-02-08 12:51:19.799	error	at Adapter.restart (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:930:14)
      homeconnect.0	2020-02-08 12:51:19.799	error	(941) TypeError: this.stop is not a function
      homeconnect.0	2020-02-08 12:51:19.798	error	(941) uncaught exception: this.stop is not a function
      homeconnect.0	2020-02-08 12:51:19.784	warn	(941) Restart initiated
      homeconnect.0	2020-02-08 12:51:18.047	info	(941) Accesstoken renewed...
      Y E 2 Replies Last reply Reply Quote 0
      • Y
        ydn @ydn last edited by ydn
        @ydn
        Hmm I restarted the setup with the standard JScontroller 2.1.1A
        Seems not so stable aldough, the log is shouting all day:
        homeconnect.0	2020-02-11 08:02:37.465	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 08:02:37.464	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:57:37.233	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:57:37.232	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:52:36.997	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:52:36.996	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:47:36.781	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:47:36.779	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:42:36.539	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:42:36.538	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:37:36.316	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:37:36.314	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:32:36.092	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:32:36.091	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:27:35.858	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:27:35.856	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:22:35.622	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:22:35.620	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:17:35.399	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:17:35.397	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:12:35.086	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:12:35.085	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:07:34.842	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:07:34.840	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 07:02:34.603	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 07:02:34.601	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 06:57:34.383	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 06:57:34.381	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 06:52:34.147	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 06:52:34.145	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 06:47:33.926	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 06:47:33.925	error	(5890) Error Refresh-Token: 403 undefined
        homeconnect.0	2020-02-11 06:42:33.684	warn	(5890) Retry Refresh Token in 5min
        homeconnect.0	2020-02-11 06:42:33.683	error	(5890) Error Refresh-Token: 403 undefined
        • E
          emeins @ydn last edited by
          @ydn I had a simular issue most likely caused by an issue on the API provider side. Please check if https://github.com/dna909/ioBroker.homeconnect/issues/35 helps.
          homeconnect adapter js controller update
