    4. Installation issues due to npm node.js version compatibility
    UNSOLVED Installation issues due to npm node.js version compatibility
      matyi last edited by
      Hello all,
      I started using ioBroker yesterday and it took me till today to get it started. I guess it's good to share the experience to improve the scripts/workflow/documentation. I was going through the following while until setting up ioBorder successfully (roughly reproduced):
      1. trial:
      • setting up a VM with Debian Buster including updating the system.
      • First I was following the instructions using this guide: https://www.iobroker.net/docu/index-15.htm?page_id=8323&lang=de
        I googled for the current node.js version and installed version 10.x intuitively. Axecuting the following command indicated my main issue already
      node -v
      nodejs -v
      npm -v
      the command npm couln'd be found! I simply ignored this issueand installted ioBroker. I couldn't load the ioBroker configuration page.
      1. trial:
      • uninstalled all packages by using:
      update-rc.d iobroker.sh remove
      sudo apt-get remove nodejs
      sudo apt-get remove npm
      • Subsequently, I used the following instructions to install your software: https://www.iobroker.net/#de/download
      • some warnings appeared during installation including that npm is not compatible with the installed nodejs version. I couldn't load the ioBroker configuration page again.
      • I tried to fix this issue by using this troubleshooting instruchtions https://www.iobroker.net/docu/index-26.htm?page_id=3928&lang=de and installing the recent version of npm:
      curl https://www.npmjs.com/install.sh | sudo sh
      from here: https://github.com/nodejs/help/issues/1877
      however no success again
      1. trial
      • since I lost the overview of installed software I reseted the VM to the point after updating the operating system.
      • Again I tried to use the instructions from here: https://www.iobroker.net/#de/download without success.
      • After reseting again I used the following sequence of commands:
      curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
      sudo apt-get install -y nodejs
      curl -sL https://iobroker.net/install.sh | bash -
      With success!!! Now I'm happy to be able to load the web interface of ioBroker. 😊
      I'm curious to learn how it works 😀
      Cheers,
      Matyi
      Systemdata
      Hardwaresystem: Virtual Box
      Arbeitsspeicher: 1GB
      Festplattenart: 8 GB
      Betriebssystem: Debian Buster with Raspberry Pi Desktop
      Node-Version: 10.15.2
      Nodejs-Version: 10.15.2
      NPM-Version: 6.13.7
      Installationsart: Skript
      Image genutzt: Nein
        Homoran Global Moderator Administrators @matyi last edited by
        @matyi sagte in Installation issues due to npm node.js version compatibility:
        This ist outdated!
        This is the actual version:
        https://www.iobroker.net/#en/documentation/install/linux.md
        floow the link to the docu in the header of the forum
        install node.js npm version
