    4. Amazon Dash wird nicht Grün nach Nodejs update
    SOLVED Amazon Dash wird nicht Grün nach Nodejs update
      denjo last edited by
      Hallo mein Amazon dash Adapter läuft nach einem nodejs update nicht mehr bekomme folgende Meldung
      amazon-dash.0	2020-02-13 20:37:48.413	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6811:25)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7114:22)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at Adapter.emit (events.js:198:13)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
      amazon-dash.0	2020-02-13 20:37:48.413	error	at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
      amazon-dash.0	2020-02-13 20:37:48.413	error	(11779) Error: socket: Operation not permitted
      amazon-dash.0	2020-02-13 20:37:48.410	error	(11779) uncaught exception: socket: Operation not permitted
      amazon-dash.0	2020-02-13 20:37:48.399	info	(11779) starting pcap session on default interface
      Dr. Bakterius 1 Reply Last reply Reply Quote 0
      • Dr. Bakterius
        Dr. Bakterius Most Active @denjo last edited by
        @denjo Schon mal den Fixer laufen lassen?
          denjo @Dr. Bakterius last edited by
          @Dr-Bakterius ja, oder muss ich den immer neu machen bei einem nodejs Update?
          • Dr. Bakterius
            @denjo Den kann man ruhig ab und zu laufen lassen. Ich hatte mal das selbe Problem und da half der Fixer.
              @Dr-Bakterius fett danke hat geklappt
              amazon-dashbutton
