    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Homekit
    Homekit
    • Z
      znammut last edited by
      Здравствуйте, не получается установить Homekit:
      ./iobroker add homekit
      npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
      In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
      #include <dns_sd.h>
      ! compilation terminated.
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      gyp
      ERR! build error
      gyp ERR! stack
      Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      gyp
      ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)gyp
      ERR! System Linux 3.4.112-sun8igyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR!
      cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdnsgyp ERR! node -v v4.4.7
      gyp ERR! node-gyp -v v3.3.1
      gyp ERR! not ok
      ! npm
      ERR! Linux 3.4.112-sun8i
      npm ERR! argv
      "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.4.7
      npm ERR! npm v2.15.8
      ! npm ERR! code ELIFECYCLE
      npm ERR! mdns@2.2.11 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm
      ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
      npm ERR! This is most likely a problem with the mdns package,
      npm
      ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuild
      npm ERR!
      You can get information on how to open an issue for this project with:npm ERR! npm bugs mdns
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!
      npm owner ls mdnsnpm ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
      ! ERROR: host.orangepipc-1 Cannot install iobroker.homekit: 1
      ERROR: process exited with code 25</dns_sd.h>
      Armbian ставил по инструкции с вашего сайта. Опыт работы с Юникс системами есть, с Node нет. Как починить?
      С уважением Дмитрий
        Вроде бы нужна версия node.js 4.xx
        и
        ` > Note: one some systems additional package is required
        sudo apt-get install libavahi-compat-libdnssd-dev
        • Z
          Спасибо получилось, надо было раньше спросить.
