    4. [Fehler] io.controller wird ständig neu gestartet
    • derAuge
      derAuge last edited by
      seit gestern Abend habe ich eine erhöte CPU-Last
      Neustart des Pi2 heute morgen brachte keine Änderung
      Auch stelle ich weiter fest, dass die Instanzen immer wieder neu gestartet werden
      root@pi2:/mnt/ioBroker/iobroker.Pi2# ps -A |grep io
       2564 ?        00:11:30 io.admin.0
       2566 ?        00:15:20 io.web.0
       2596 ?        00:08:05 io.history.0
       2610 ?        00:03:37 io.ping.0
       2628 ?        00:02:26 io.sonos.0
       2634 ?        00:02:11 io.sayit.0
       2649 ?        00:10:06 io.javascript.0
       2564 ?        00:11:44 io.admin.0
       2566 ?        00:15:37 io.web.0
       2596 ?        00:08:15 io.history.0
       2610 ?        00:03:41 io.ping.0
       2628 ?        00:02:29 io.sonos.0
       2634 ?        00:02:14 io.sayit.0
       2649 ?        00:10:19 io.javascript.0
       7695 ?        00:00:08 io.js-controlle
      Auch auf der UI [Instanzen] zu erkennen
      im LOG sind folgende Einträge: (kleiner Auszug)
      admin.0	2015-03-19 15:02:27	warn	admin.0 Reconnection to DB.
      TypeError:	2015-03-19 15:02:10	error	2
      TypeError:	2015-03-19 15:02:10	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
      TypeError:	2015-03-19 15:02:10	error	at timer._onTimeout (timers.js:219:16)
      TypeError:	2015-03-19 15:02:10	error	at null. (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:831:17)
      TypeError:	2015-03-19 15:02:10	error	at startInstance (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:913:88)
      TypeError:	2015-03-19 15:02:10	error	Cannot read property '0' of undefined
      uncaught	2015-03-19 15:02:10	error	exception: Cannot read property '0' of undefined
      Weitere Infos
      ! admin.0 2015-03-19 15:02:27 warn admin.0 Reconnection to DB. admin.0 2015-03-19 15:02:27 warn admin.0 Reconnection to DB. admin.0 2015-03-19 15:02:27 warn admin.0 Reconnection to DB. admin.0 2015-03-19 15:02:27 warn admin.0 Reconnection to DB. TypeError: 2015-03-19 15:02:10 error 2 TypeError: 2015-03-19 15:02:10 error at Timer.listOnTimeout [as ontimeout] (timers.js:112:15) TypeError: 2015-03-19 15:02:10 error at timer._onTimeout (timers.js:219:16) TypeError: 2015-03-19 15:02:10 error at null. (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:831:17) TypeError: 2015-03-19 15:02:10 error at startInstance (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:913:88) TypeError: 2015-03-19 15:02:10 error Cannot read property '0' of undefined uncaught 2015-03-19 15:02:10 error exception: Cannot read property '0' of undefined host-pi2 2015-03-19 15:02:06 info instance system.adapter.yr.0 started with pid 7111 host-pi2 2015-03-19 15:02:06 info instance scheduled system.adapter.yr.0 1 * * * * host-pi2 2015-03-19 15:02:06 info instance system.adapter.web.0 started with pid 7109 host-pi2 2015-03-19 15:02:06 info instance system.adapter.admin.0 started with pid 7107 host-pi2 2015-03-19 15:02:06 info instance system.adapter.javascript.0 started with pid 7106 host-pi2 2015-03-19 15:02:03 info Update repository "default" under "conf/sources-dist.json" host-pi2 2015-03-19 15:02:00 info Restart adapter system.adapter.sayit.0 because enabled host-pi2 2015-03-19 15:02:00 error instance system.adapter.sayit.0 terminated with code 7 (Adapter already running) sayit-0 2015-03-19 15:02:00 error already running 2015-03-19 15:01:59 info info host-pi2 2015-03-19 15:01:58 info Restart adapter system.adapter.sonos.0 because enabled host-pi2 2015-03-19 15:01:58 error instance system.adapter.sonos.0 terminated with code 7 (Adapter already running) sonos-0 2015-03-19 15:01:58 error already running 2015-03-19 15:01:55 info info [sonos] 2015-03-19 15:01:55 info info host-pi2 2015-03-19 15:01:58 info instance system.adapter.sayit.0 started with pid 7091 host-pi2 2015-03-19 15:01:57 info instance system.adapter.dwd.0 terminated with code 0 (OK) host-pi2 2015-03-19 15:01:54 info instance system.adapter.sonos.0 started with pid 7085 host-pi2 2015-03-19 15:01:53 info Restart adapter system.adapter.ping.0 because enabled host-pi2 2015-03-19 15:01:53 error instance system.adapter.ping.0 terminated with code 7 (Adapter already running) ping-0 2015-03-19 15:01:52 error already running dwd-0 2015-03-19 15:01:52 info setting states 2015-03-19 15:01:51 info info dwd-0 2015-03-19 15:01:51 info getFile Z_CAP_C_EDZW_20150318233833_OMEDES_WWEM59_BORX.xml dwd-0 2015-03-19 15:01:50 info getFile Z_CAP_C_EDZW_20150317145841_OMEDES_WWEM21_BORX.xml host-pi2 2015-03-19 15:01:50 info instance system.adapter.ping.0 started with pid 7079 dwd-0 2015-03-19 15:01:49 info starting. Version 0.1.7 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.dwd 2015-03-19 15:01:48 info info host-pi2 2015-03-19 15:01:46 info instance system.adapter.dwd.0 started with pid 7060 host-pi2 2015-03-19 15:01:46 info instance scheduled system.adapter.dwd.0 0,30 * * * * javascript-0 2015-03-19 15:01:45 info Stop script script.js.Bewegung_Flur host-pi2 2015-03-19 15:01:44 info Restart adapter system.adapter.history.0 because enabled host-pi2 2015-03-19 15:01:44 error instance system.adapter.history.0 terminated with code 7 (Adapter already running) history-0 2015-03-19 15:01:44 error already running 2015-03-19 15:01:43 info info host-pi2 2015-03-19 15:01:42 info instance system.adapter.history.0 started with pid 7054 javascript-0 2015-03-19 15:01:41 info Stop script script.js.Bewegung_Terasse host-pi2 2015-03-19 15:01:34 info Restart adapter system.adapter.web.0 because enabled host-pi2 2015-03-19 15:01:34 error instance system.adapter.web.0 terminated with code 7 (Adapter already running) web-0 2015-03-19 15:01:34 error already running 2015-03-19 15:01:32 info info host-pi2 2015-03-19 15:01:33 info Restart adapter system.adapter.admin.0 because enabled host-pi2 2015-03-19 15:01:33 error instance system.adapter.admin.0 terminated with code 7 (Adapter already running) admin-0 2015-03-19 15:01:33 error already running 2015-03-19 15:01:31 info info host-pi2 2015-03-19 15:01:30 info instance system.adapter.web.0 started with pid 7035 web-0 2015-03-19 15:01:27 warn Reconnection to DB. javascript-0 2015-03-19 15:01:27 warn Reconnection to DB. history-0 2015-03-19 15:01:27 warn Reconnection to DB. sonos-0 2015-03-19 15:01:27 warn Reconnection to DB. ping-0 2015-03-19 15:01:27 warn Reconnection to DB. sayit-0 2015-03-19 15:01:27 warn Reconnection to DB. admin-0 2015-03-19 15:01:27 warn Reconnection to DB. web-0 2015-03-19 15:01:27 warn Reconnection to DB. javascript-0 2015-03-19 15:01:27 warn Reconnection to DB. history-0 2015-03-19 15:01:27 warn Reconnection to DB. ping-0 2015-03-19 15:01:27 warn Reconnection to DB. sonos-0 2015-03-19 15:01:27 warn Reconnection to DB. admin-0 2015-03-19 15:01:27 warn Reconnection to DB. sayit-0 2015-03-19 15:01:27 warn Reconnection to DB. host-pi2 2015-03-19 15:01:26 info starting 15 instances host-pi2 2015-03-19 15:01:26 info 17 instances found host-pi2 2015-03-19 15:01:25 info InMemoryDB connected inMem-objects 2015-03-19 15:01:25 info listening on port 9001 inMem-states 2015-03-19 15:01:25 info listening on port 9000 host-pi2 2015-03-19 15:01:24 info ip addresses: 192.168.28.77 host-pi2 2015-03-19 15:01:24 info hostname: pi2 host-pi2 2015-03-19 15:01:24 info Copyright (c) 2014 bluefox, hobbyquaker host-pi2 2015-03-19 15:01:24 info ioBroker.js-controller version 0.5.15 js-controller starting 2015-03-19 15:01:24 info info host-pi2 2015-03-19 15:01:20 info force terminating host-pi2 2015-03-19 15:01:20 info received SIGTERM host-pi2 2015-03-19 15:01:20 info force terminating host-pi2 2015-03-19 15:01:20 info received SIGTERM host-pi2 2015-03-19 15:01:19 info force terminated after 10s host-pi2 2015-03-19 15:01:18 info received SIGTERM host-pi2 2015-03-19 15:01:17 info received SIGTERM host-pi2 2015-03-19 15:01:16 info received SIGTERM host-pi2 2015-03-19 15:01:15 info received SIGTERM host-pi2 2015-03-19 15:01:15 info instance system.adapter.yr.0 terminated with code 0 (OK) host-pi2 2015-03-19 15:01:15 info received SIGTERM host-pi2 2015-03-19 15:01:13 info received SIGTERM host-pi2 2015-03-19 15:01:12 info received SIGTERM host-pi2 2015-03-19 15:01:11 info received SIGTERM host-pi2 2015-03-19 15:01:10 info received SIGTERM host-pi2 2015-03-19 15:01:10 info instance system.adapter.admin.0 terminated with code 7 (Adapter already running) yr-0 2015-03-19 15:01:10 info got weather data from yr.no admin-0 2015-03-19 15:01:10 error already running iobroker 2015-03-19 15:01:10 info exit 0 iobroker 2015-03-19 15:01:10 info Starting node restart.js 2015-03-19 15:01:08 info info yr-0 2015-03-19 15:01:09 info starting. Version 0.1.2 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.yr iobroker 2015-03-19 15:01:09 info _restart TypeError: 2015-03-19 15:01:09 error at Timer.listOnTimeout [as ontimeout] (timers.js:112:15) TypeError: 2015-03-19 15:01:09 error at timer._onTimeout (timers.js:219:16) TypeError: 2015-03-19 15:01:09 error at null. (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:831:17) TypeError: 2015-03-19 15:01:09 error at startInstance (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:913:88) TypeError: 2015-03-19 15:01:09 error Cannot read property '0' of undefined uncaught 2015-03-19 15:01:09 error exception: Cannot read property '0' of undefined 2015-03-19 15:01:07 info info host-pi2 2015-03-19 15:01:07 info Restart adapter system.adapter.web.0 because enabled host-pi2 2015-03-19 15:01:07 error instance system.adapter.web.0 terminated with code 7 (Adapter already running) web-0 2015-03-19 15:01:07 error already running 2015-03-19 15:01:05 info info host-pi2 2015-03-19 15:01:07 info Restart adapter system.adapter.javascript.0 because enabled host-pi2 2015-03-19 15:01:07 error instance system.adapter.javascript.0 terminated with code 7 (Adapter already running) javascript-0 2015-03-19 15:01:07 error already running 2015-03-19 15:01:04 info info host-pi2 2015-03-19 15:01:05 info instance system.adapter.yr.0 started with pid 6982 host-pi2 2015-03-19 15:01:05 info instance scheduled system.adapter.yr.0 1 * * * * host-pi2 2015-03-19 15:01:03 info instance system.adapter.web.0 started with pid 6976 host-pi2 2015-03-19 15:01:02 info instance system.adapter.admin.0 started with pid 6974 host-pi2 2015-03-19 15:01:01 info instance system.adapter.javascript.0 started with pid 6972 host-pi2 2015-03-19 15:00:59 info Restart adapter system.adapter.sayit.0 because enabled host-pi2 2015-03-19 15:00:59 error instance system.adapter.sayit.0 terminated with code 7 (Adapter already running) sayit-0 2015-03-19 15:00:59 error already running 2015-03-19 15:00:58 info info host-pi2 2015-03-19 15:00:57 info Restart adapter system.adapter.sonos.0 because enabled host-pi2 2015-03-19 15:00:57 error instance system.adapter.sonos.0 terminated with code 7 (Adapter already running) sonos-0 2015-03-19 15:00:57 error already running 2015-03-19 15:00:54 info info [sonos] 2015-03-19 15:00:54 info info host-pi2 2015-03-19 15:00:57 info instance system.adapter.sayit.0 started with pid 6957 host-pi2 2015-03-19 15:00:56 info instance system.adapter.dwd.0 terminated with code 0 (OK) host-pi2 2015-03-19 15:00:53 info instance system.adapter.sonos.0 started with pid 6951 host-pi2 2015-03-19 15:00:52 info Restart adapter system.adapter.ping.0 because enabled host-pi2 2015-03-19 15:00:52 error instance system.adapter.ping.0 terminated with code 7 (Adapter already running) ping-0 2015-03-19 15:00:51 error already running 2015-03-19 15:00:50 info info dwd-0 2015-03-19 15:00:51 info setting states dwd-0 2015-03-19 15:00:50 info getFile Z_CAP_C_EDZW_20150318233833_OMEDES_WWEM59_BORX.xml dwd-0 2015-03-19 15:00:49 info getFile Z_CAP_C_EDZW_20150317145841_OMEDES_WWEM21_BORX.xml host-pi2 2015-03-19 15:00:49 info instance system.adapter.ping.0 started with pid 6945 dwd-0 2015-03-19 15:00:48 info starting. Version 0.1.7 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.dwd 2015-03-19 15:00:47 info info host-pi2 2015-03-19 15:00:45 info instance system.adapter.dwd.0 started with pid 6925 host-pi2 2015-03-19 15:00:45 info instance scheduled system.adapter.dwd.0 0,30 * * * * host-pi2 2015-03-19 15:00:43 info Restart adapter system.adapter.history.0 because enabled host-pi2 2015-03-19 15:00:43 error instance system.adapter.history.0 terminated with code 7 (Adapter already running) history-0 2015-03-19 15:00:43 error already running 2015-03-19 15:00:42 info info host-pi2 2015-03-19 15:00:41 info instance system.adapter.history.0 started with pid 6919 host-pi2 2015-03-19 15:00:33 info Restart adapter system.adapter.web.0 because enabled host-pi2 2015-03-19 15:00:33 error instance system.adapter.web.0 terminated with code 7 (Adapter already running) web-0 2015-03-19 15:00:33 error already running 2015-03-19 15:00:31 info info host-pi2 2015-03-19 15:00:32 info Restart adapter system.adapter.admin.0 because enabled host-pi2 2015-03-19 15:00:32 error instance system.adapter.admin.0 terminated with code 7 (Adapter already running) admin-0 2015-03-19 15:00:32 error already running 2015-03-19 15:00:30 info info sayit-0 2015-03-19 15:00:29 warn Reconnection to DB. host-pi2 2015-03-19 15:00:29 info instance system.adapter.web.0 started with pid 6900 ping-0 2015-03-19 15:00:29 warn Reconnection to DB. sonos-0 2015-03-19 15:00:29 warn Reconnection to DB. sayit-0 2015-03-19 15:00:28 warn Reconnection to DB. ping-0 2015-03-19 15:00:28 warn Reconnection to DB. sonos-0 2015-03-19 15:00:28 warn Reconnection to DB. host-pi2 2015-03-19 15:00:25 info starting 15 instances host-pi2 2015-03-19 15:00:25 info 17 instances found host-pi2 2015-03-19 15:00:24 info InMemoryDB connected inMem-objects 2015-03-19 15:00:24 info listening on port 9001 inMem-states 2015-03-19 15:00:24 info listening on port 9000 host-pi2 2015-03-19 15:00:23 info ip addresses: 192.168.28.77 host-pi2 2015-03-19 15:00:23 info hostname: pi2 web-0 2015-03-19 15:00:25 warn Reconnection to DB. javascript-0 2015-03-19 15:00:25 warn Reconnection to DB. history-0 2015-03-19 15:00:25 warn Reconnection to DB. admin-0 2015-03-19 15:00:25 warn Reconnection to DB. host-pi2 2015-03-19 15:00:23 info Copyright (c) 2014 bluefox, hobbyquaker host-pi2 2015-03-19 15:00:23 info ioBroker.js-controller version 0.5.15 js-controller starting web-0 2015-03-19 15:00:25 warn Reconnection to DB. javascript-0 2015-03-19 15:00:25 warn Reconnection to DB. history-0 2015-03-19 15:00:25 warn Reconnection to DB. admin-0 2015-03-19 15:00:25 warn Reconnection to DB. 2015-03-19 15:00:23 info info host-pi2 2015-03-19 15:00:19 info force terminating host-pi2 2015-03-19 15:00:19 info received SIGTERM host-pi2 2015-03-19 15:00:18 info force terminating host-pi2 2015-03-19 15:00:18 info received SIGTERM host-pi2 2015-03-19 15:00:17 info force terminated after 10s host-pi2 2015-03-19 15:00:16 info received SIGTERM host-pi2 2015-03-19 15:00:15 info received SIGTERM host-pi2 2015-03-19 15:00:14 info received SIGTERM host-pi2 2015-03-19 15:00:14 info instance system.adapter.yr.0 terminated with code 0 (OK) host-pi2 2015-03-19 15:00:13 info received SIGTERM host-pi2 2015-03-19 15:00:12 info received SIGTERM host-pi2 2015-03-19 15:00:11 info received SIGTERM host-pi2 2015-03-19 15:00:11 info received SIGTERM host-pi2 2015-03-19 15:00:09 info received SIGTERM host-pi2 2015-03-19 15:00:09 info instance system.adapter.admin.0 terminated with code 7 (Adapter already running) admin-0 2015-03-19 15:00:09 error already running yr-0 2015-03-19 15:00:09 info got weather data from yr.no 2015-03-19 15:00:07 info info host-pi2 2015-03-19 15:00:08 info received SIGTERM yr-0 2015-03-19 15:00:08 info starting. Version 0.1.2 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.yr iobroker 2015-03-19 15:00:08 info exit 0 2015-03-19 15:00:06 info info !
      admin.0	2015-03-19 15:05:31	warn	admin.0 Reconnection to DB.
      admin.0	2015-03-19 15:04:30	warn	admin.0 Reconnection to DB.
      admin.0	2015-03-19 15:03:29	warn	admin.0 Reconnection to DB.
      admin.0	2015-03-19 15:03:28	warn	admin.0 Reconnection to DB.
      Was kann die Ursache sein?
      history ( Speicher bei mir einiges)?
      script (Die SayIt an sonos senden, Gerade man deaktiviert) ?
      SONOS / SayIT?
      DB -> habe nie eine DB installiert für : "Ereignissen nach die Ereignisse in DB"
      derAuge
        Ändere Zeile 913 in controller.js
        von:
        logger.error('host.' + hostname + ' startInstance ' + name + '.' + args[0] + ': cannot find start file!');
        auf
        logger.error('host.' + hostname + ' startInstance ' + name + ': cannot find start file!');
        Dann wird mindestens controller weiter laufen. Er kann ein Adapter nicht finden, welcher aber konfiguriert ist.
        • derAuge
          umgesetzt
          brachte nicht wirklich ein ergebniss (Ausser das io.controller nun weiter läuft)
          Habe nun mal den SystemMonitor des Pi2 eingeschaltet
          dort sehe ich nach dem neustart:
          Starting ioBroker
          module.js:340
              throw err;
          Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (module.js:338:15)
              at Function.Module._load (module.js:280:25)
              at Function.Module.runMain (module.js:497:10)
              at startup (node.js:119:16)
              at node.js:935:3
          per ssh kann "iobroker restart" gestartet werden.
          Frage: Sollte ich "root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker.js-controller" versuchen ?
            @derAuge:
            umgesetzt
            Starting ioBroker
            module.js:340
                throw err;
                at node.js:935:3
            Frage: Sollte ich "root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker.js-controller" versuchen ? `
            Schaden wird es nicht. Sichere aber trotzdem /mnt/ioBroker/iobroker.Pi2/iobroker-data
            • derAuge
              root@pi2:~# cd /mnt/ioBroker/iobroker.Pi2/
              > ws@0.5.0 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
              > (node-gyp rebuild 2> builderror.log) || (exit 0)
              make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
                CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                COPY Release/bufferutil.node
                CXX(target) Release/obj.target/validation/src/validation.o
                SOLINK_MODULE(target) Release/obj.target/validation.node
                SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                COPY Release/validation.node
              make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
              npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
              npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
              npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
              npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
              npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
              > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
              make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
              make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
              > iobroker.js-controller@0.5.15 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller
              > node lib/setup.js setup first
              iobroker.js-controller@0.5.15 node_modules/iobroker.js-controller
              ├── daemonize2@0.4.2
              ├── mime@1.2.11
              ├── node-schedule@0.1.13
              ├── ncp@0.6.0
              ├── node.extend@1.0.10 (is@0.3.0)
              ├── adm-zip@0.4.7
              ├── yargs@1.2.6 (minimist@0.1.0)
              ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
              ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, mime-types@1.0.2, form-data@0.1.4, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
              ├── winston@0.7.3 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, colors@0.6.2, async@0.2.10, pkginfo@0.3.0, request@2.16.6)
              ├── npm@2.3.0
              ├── socket.io@1.2.1 (debug@0.7.4, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.2, engine.io@1.4.3)
              └── socket.io-client@1.2.1 (to-array@0.1.3, indexof@0.0.1, debug@0.7.4, component-bind@1.0.0, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.5, parseuri@0.0.2, socket.io-parser@2.2.2, engine.io-client@1.4.3)
              danach ein "init 6"
              und der neustart läft sauber durch.
              jedoch im LOG:
              admin.0	2015-03-19 16:24:51	warn	admin.0 Reconnection to DB.
              admin.0	2015-03-19 16:23:54	warn	admin.0 Reconnection to DB.
              admin.0	2015-03-19 16:23:53	warn	admin.0 Reconnection to DB.
              Da scheint nocht etwas anderes fehlerhaft zu sein
              Frage : muss die "CouchDB" installiert werden?
                Couch und Redis sind schon längst raus und werden nicht benötigt.
                Firewall?
                • derAuge
                  @Bluefox:
                  Firewall? `
                  Das System ist IP-technisch nicht verändert worden
                  • derAuge
                    Guten Morgen
                    habe noch mal versucht der Ursache auf den Grund zu gehen. Leider ohne Erfolg.
                    😞 Das System ist nicht mehr nutzbar 😞
                    history-0	2015-03-20 05:55:35	warn	Reconnection to DB.
                    admin-0	2015-03-20 05:55:35	warn	Reconnection to DB.
                    sonos-0	2015-03-20 05:55:35	warn	Reconnection to DB.
                    ping-0	2015-03-20 05:55:35	warn	Reconnection to DB.
                    web-0	2015-03-20 05:55:35	warn	Reconnection to DB.
                    javascript-0	2015-03-20 05:55:35	warn	Reconnection to DB.
                    sayit-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    ping-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    sonos-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    history-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    admin-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    web-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    javascript-0	2015-03-20 05:55:34	warn	Reconnection to DB.
                    host-pi2	2015-03-20 05:55:32	info	starting 14 instances
                    host-pi2	2015-03-20 05:55:32	info	17 instances found
                    host-pi2	2015-03-20 05:55:32	info	InMemoryDB connected
                    inMem-objects	2015-03-20 05:55:32	info	listening on port 9001
                    inMem-states	2015-03-20 05:55:32	info	listening on port 9000
                    host-pi2	2015-03-20 05:55:31	info	ip addresses: 192.168.28.77
                    host-pi2	2015-03-20 05:55:31	info	hostname: pi2
                    host-pi2	2015-03-20 05:55:31	info	Copyright (c) 2014 bluefox, hobbyquaker
                    host-pi2	2015-03-20 05:55:31	info	ioBroker.js-controller version 0.5.15 js-controller starting
                    	2015-03-20 05:55:31	info	info
                    host-pi2	2015-03-20 05:55:27	info	force terminating
                    host-pi2	2015-03-20 05:55:27	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:26	info	force terminated after 10s
                    host-pi2	2015-03-20 05:55:25	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:24	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:23	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:22	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:21	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:21	info	instance system.adapter.yr.0 terminated with code 0 (OK)
                    host-pi2	2015-03-20 05:55:21	info	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                    admin-0	2015-03-20 05:55:21	error	already running
                    	2015-03-20 05:55:19	info	info
                    host-pi2	2015-03-20 05:55:19	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:18	info	received SIGTERM
                    host-pi2	2015-03-20 05:55:17	info	received SIGTERM
                    iobroker	2015-03-20 05:55:17	info	exit 0
                    iobroker	2015-03-20 05:55:17	info	Starting node restart.js
                    yr-0	2015-03-20 05:55:16	info	got weather data from yr.no
                    iobroker	2015-03-20 05:55:16	info	_restart
                    TypeError:	2015-03-20 05:55:16	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                    TypeError:	2015-03-20 05:55:16	error	at timer._onTimeout (timers.js:219:16)
                    TypeError:	2015-03-20 05:55:16	error	at null. (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:831:17)
                    TypeError:	2015-03-20 05:55:16	error	at startInstance (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:913:88)
                    TypeError:	2015-03-20 05:55:16	error	Cannot read property '0' of undefined
                    uncaught	2015-03-20 05:55:16	error	exception: Cannot read property '0' of undefined
                    yr-0	2015-03-20 05:55:15	info	starting. Version 0.1.2 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.yr
                    	2015-03-20 05:55:14	info	info
                    host-pi2	2015-03-20 05:55:13	info	instance system.adapter.admin.0 started with pid 23540
                    host-pi2	2015-03-20 05:55:13	info	Restart adapter system.adapter.javascript.0 because enabled
                    host-pi2	2015-03-20 05:55:13	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                    javascript-0	2015-03-20 05:55:13	error	already running
                    	2015-03-20 05:55:11	info	info
                    host-pi2	2015-03-20 05:55:12	info	instance system.adapter.yr.0 started with pid 23538
                    host-pi2	2015-03-20 05:55:12	info	instance scheduled system.adapter.yr.0 1 * * * *
                    host-pi2	2015-03-20 05:55:08	info	instance system.adapter.javascript.0 started with pid 23523
                    host-pi2	2015-03-20 05:55:07	info	Restart adapter system.adapter.sayit.0 because enabled
                    host-pi2	2015-03-20 05:55:07	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
                    sayit-0	2015-03-20 05:55:06	error	already running
                    	2015-03-20 05:55:05	info	info
                    host-pi2	2015-03-20 05:55:04	info	Restart adapter system.adapter.sonos.0 because enabled
                    host-pi2	2015-03-20 05:55:04	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
                    sonos-0	2015-03-20 05:55:04	error	already running
                    	2015-03-20 05:55:01	info	info
                    [sonos]	2015-03-20 05:55:01	info	info
                    host-pi2	2015-03-20 05:55:04	info	instance system.adapter.sayit.0 started with pid 23517
                    host-pi2	2015-03-20 05:55:03	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                    host-pi2	2015-03-20 05:55:00	info	instance system.adapter.sonos.0 started with pid 23511
                    host-pi2	2015-03-20 05:54:59	info	Restart adapter system.adapter.ping.0 because enabled
                    host-pi2	2015-03-20 05:54:59	error	instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
                    ping-0	2015-03-20 05:54:58	error	already running
                    dwd-0	2015-03-20 05:54:58	info	setting states
                    	2015-03-20 05:54:57	info	info
                    dwd-0	2015-03-20 05:54:57	info	getFile Z_CAP_C_EDZW_20150319212320_OMEDES_WWEM59_BORX.xml
                    dwd-0	2015-03-20 05:54:56	info	getFile Z_CAP_C_EDZW_20150318233833_OMEDES_WWEM59_BORX.xml
                    host-pi2	2015-03-20 05:54:56	info	instance system.adapter.ping.0 started with pid 23496
                    dwd-0	2015-03-20 05:54:55	info	starting. Version 0.1.7 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.dwd
                    	2015-03-20 05:54:54	info	info
                    host-pi2	2015-03-20 05:54:52	info	instance system.adapter.dwd.0 started with pid 23490
                    host-pi2	2015-03-20 05:54:52	info	instance scheduled system.adapter.dwd.0 0,30 * * * *
                    host-pi2	2015-03-20 05:54:50	info	Restart adapter system.adapter.history.0 because enabled
                    host-pi2	2015-03-20 05:54:50	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
                    history-0	2015-03-20 05:54:50	error	already running
                    	2015-03-20 05:54:49	info	info
                    host-pi2	2015-03-20 05:54:48	info	instance system.adapter.history.0 started with pid 23484
                    host-pi2	2015-03-20 05:54:46	info	Restart adapter system.adapter.web.0 because enabled
                    host-pi2	2015-03-20 05:54:46	error	instance system.adapter.web.0 terminated with code 1 ()
                    web-0	2015-03-20 05:54:46	error	port 8082 already in use
                    web-0	2015-03-20 05:54:46	info	socket.io server listening on port 8082
                    web-0	2015-03-20 05:54:44	info	starting. Version 0.2.6 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.web
                    host-pi2	2015-03-20 05:54:43	info	Restart adapter system.adapter.admin.0 because enabled
                    	2015-03-20 05:54:42	info	info
                    host-pi2	2015-03-20 05:54:43	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                    admin-0	2015-03-20 05:54:43	error	already running
                    host-pi2	2015-03-20 05:54:40	info	instance system.adapter.web.0 started with pid 23460
                    admin-0	2015-03-20 05:54:38	warn	Reconnection to DB.
                    history-0	2015-03-20 05:54:38	warn	Reconnection to DB.
                    javascript-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    web-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    sayit-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    sonos-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    ping-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    history-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    admin-0	2015-03-20 05:54:37	warn	Reconnection to DB.
                    ping-0	2015-03-20 05:54:36	warn	Reconnection to DB.
                    sonos-0	2015-03-20 05:54:36	warn	Reconnection to DB.
                    sayit-0	2015-03-20 05:54:36	warn	Reconnection to DB.
                    history-0	2015-03-20 05:54:36	warn	Reconnection to DB.
                    host-pi2	2015-03-20 05:54:36	info	starting 14 instances
                    host-pi2	2015-03-20 05:54:36	info	17 instances found
                    host-pi2	2015-03-20 05:54:36	info	InMemoryDB connected
                    inMem-objects	2015-03-20 05:54:36	info	listening on port 9001
                    inMem-states	2015-03-20 05:54:35	info	listening on port 9000
                    host-pi2	2015-03-20 05:54:34	info	ip addresses: 192.168.28.77
                    host-pi2	2015-03-20 05:54:34	info	hostname: pi2
                    host-pi2	2015-03-20 05:54:34	info	Copyright (c) 2014 bluefox, hobbyquaker
                    host-pi2	2015-03-20 05:54:34	info	ioBroker.js-controller version 0.5.15 js-controller starting
                    	2015-03-20 05:54:34	info	info
                    Wenn es keinen Lösungsweg gibt, muss ich die geasmte Installation erneuern und alle Daten und Einstellungen von vorne beginnen.
                    Wo kann ich noch unterstützen die Fehlerursache zu finden?
                      Läuft überhaupt js-contorller?
                      ps -A
                      Gibt es 9000 und 9001 Ports dabei?
                      netstat -n -a
                      • derAuge
                        @Bluefox:
                        ps -A
                        netstat -n -a
                           10 ?        00:00:00 migration/0
                           11 ?        00:00:00 migration/1
                           15 ?        00:00:00 migration/2
                           19 ?        00:00:00 migration/3
                           30 ?        00:00:00 bioset
                           33 ?        00:00:00 rpciod
                           36 ?        00:00:00 nfsiod
                           49 ?        00:00:00 DWC Notificatio
                         2551 ?        00:04:27 io.js-controlle
                         2573 ?        00:03:05 io.sayit.0
                         2588 ?        00:03:04 io.ping.0
                         2626 ?        00:07:56 io.admin.0
                         2628 ?        00:07:51 io.web.0
                         2647 ?        00:06:05 io.history.0
                         2672 ?        00:05:42 io.ping.0
                         2689 ?        00:03:34 io.sonos.0
                         2705 ?        00:03:14 io.sayit.0
                         2711 ?        00:07:41 io.javascript.0
                         2741 ?        00:00:21 io.hm-rpc.0
                         2762 ?        00:00:25 io.hm-rega.0
                        23057 ?        00:02:39 io.history.0
                        23060 ?        00:00:49 io.ping.0
                        23063 ?        00:00:36 io.sonos.0
                        23117 ?        00:00:30 io.sayit.0
                        root@pi2:/mnt/ioBroker/iobroker.Pi2# netstat -n -a
                        Aktive Internetverbindungen (Server und stehende Verbindungen)
                        Proto Recv-Q Send-Q Local Address           Foreign Address         State
                        tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:57983           0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:3500            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:3501            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:44686           0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
                        tcp        0      0 192.168.28.77:2001      0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37340         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45565         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42253         VERBUNDEN
                        tcp        0      0 127.0.0.1:42207         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:45601         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:45615         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45600         TIME_WAIT
                        tcp        0      0 127.0.0.1:37288         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42257         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37275         TIME_WAIT
                        tcp        0      0 127.0.0.1:37323         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37289         TIME_WAIT
                        tcp        0      0 127.0.0.1:42251         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45608         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37281         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37302         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37331         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37283         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37336         TIME_WAIT
                        tcp        0      0 127.0.0.1:45566         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37322         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45592         TIME_WAIT
                        tcp        0      0 192.168.28.77:714       192.168.28.24:2049      VERBUNDEN
                        tcp        0      0 127.0.0.1:42213         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33936         VERBUNDEN
                        tcp        0      0 127.0.0.1:34144         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33954         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33946         VERBUNDEN
                        tcp        0      0 127.0.0.1:45607         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:42255         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:45579         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45584         TIME_WAIT
                        tcp        0      0 127.0.0.1:42253         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42209         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33950         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45553         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37293         TIME_WAIT
                        tcp        0      0 127.0.0.1:42405         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:45591         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37344         TIME_WAIT
                        tcp        0      0 127.0.0.1:37276         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:33956         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37330         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42422         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45622         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45606         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37287         TIME_WAIT
                        tcp        0      0 127.0.0.1:37337         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:33938         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45580         TIME_WAIT
                        tcp        0      0 127.0.0.1:42215         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42213         VERBUNDEN
                        tcp        0      0 127.0.0.1:33940         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:45623         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:33958         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 192.168.28.77:8081      192.168.28.88:49704     VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45575         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42405         VERBUNDEN
                        tcp        0      0 127.0.0.1:37345         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:42422         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:37307         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:34144         VERBUNDEN
                        tcp        0      0 127.0.0.1:42245         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45561         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33960         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42245         VERBUNDEN
                        tcp        0      0 127.0.0.1:45585         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45616         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45567         TIME_WAIT
                        tcp        0      0 127.0.0.1:42257         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37324         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37339         TIME_WAIT
                        tcp        0      0 127.0.0.1:33936         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:45560         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37316         TIME_WAIT
                        tcp        0      0 127.0.0.1:33946         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45559         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33952         VERBUNDEN
                        tcp        0      0 127.0.0.1:33954         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45571         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42207         VERBUNDEN
                        tcp        0      0 127.0.0.1:45554         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37315         TIME_WAIT
                        tcp        0      0 127.0.0.1:33944         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45624         TIME_WAIT
                        tcp        0      0 192.168.28.77:8082      192.168.28.88:49924     VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42247         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33948         VERBUNDEN
                        tcp        0      0 127.0.0.1:37301         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:37295         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37332         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45586         TIME_WAIT
                        tcp        0      0 127.0.0.1:33960         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:34130         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42249         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37300         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42215         VERBUNDEN
                        tcp        0      0 127.0.0.1:33948         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45602         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37338         TIME_WAIT
                        tcp        0      0 127.0.0.1:34130         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:45572         127.0.0.1:9001          TIME_WAIT
                        tcp        0      0 127.0.0.1:42249         127.0.0.1:9001          VERBUNDEN
                        tcp        0   4368 192.168.28.77:22        192.168.28.88:49693     VERBUNDEN
                        tcp        0      0 127.0.0.1:33942         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37277         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37346         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45578         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45614         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37328         TIME_WAIT
                        tcp        0      0 127.0.0.1:42209         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:37282         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33958         VERBUNDEN
                        tcp        0      0 127.0.0.1:42243         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:42247         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 192.168.28.77:2001      192.168.28.25:47449     VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33944         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42243         VERBUNDEN
                        tcp        0      0 127.0.0.1:33952         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:37329         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45628         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37314         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42211         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33938         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37306         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37312         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45590         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33956         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45573         TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37308         TIME_WAIT
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42251         VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33942         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:42255         VERBUNDEN
                        tcp        0      0 127.0.0.1:9001          127.0.0.1:45555         TIME_WAIT
                        tcp        0      0 192.168.28.77:8081      192.168.28.184:49599    VERBUNDEN
                        tcp        0      0 127.0.0.1:33950         127.0.0.1:9000          VERBUNDEN
                        tcp        0      0 127.0.0.1:37313         127.0.0.1:9000          TIME_WAIT
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:33940         VERBUNDEN
                        tcp      307      0 127.0.0.1:45628         127.0.0.1:9001          CLOSE_WAIT
                        tcp        0      0 127.0.0.1:42211         127.0.0.1:9001          VERBUNDEN
                        tcp        0      0 127.0.0.1:9000          127.0.0.1:37296         TIME_WAIT
                        udp        0      0 0.0.0.0:68              0.0.0.0:*
                        udp        0      0 0.0.0.0:111             0.0.0.0:*
                        udp        0      0 192.168.28.77:123       0.0.0.0:*
                        udp        0      0 127.0.0.1:123           0.0.0.0:*
                        udp        0      0 0.0.0.0:123             0.0.0.0:*
                        udp        0      0 0.0.0.0:700             0.0.0.0:*
                        udp        0      0 127.0.0.1:742           0.0.0.0:*
                        udp        0      0 0.0.0.0:46353           0.0.0.0:*
                        udp        0      0 0.0.0.0:60330           0.0.0.0:*
                        udp        0      0 0.0.0.0:44459           0.0.0.0:*
                        Aktive Sockets in der UNIX-Domäne (Server und stehende Verbindungen)
                        Proto RefCnt Flags       Type       State         I-Node   Pfad
                        unix  3      [ ]         DGRAM                    9256     /var/run/wpa_supplicant/wlan0
                        unix  2      [ ]         DGRAM                    8533     /var/run/thd.socket
                        unix  2      [ ]         DGRAM                    7525     /tmp/wpa_ctrl_1898-1
                        unix  2      [ ACC ]     STREAM     HÖRT         6011     /var/run/rpcbind.sock
                        unix  2      [ ACC ]     STREAM     HÖRT         8572     /var/run/dbus/system_bus_socket
                        unix  7      [ ]         DGRAM                    9393     /dev/log
                        unix  2      [ ACC ]     SEQPAKET   HÖRT         4556     /run/udev/control
                        unix  2      [ ]         DGRAM                    9412
                        unix  3      [ ]         STREAM     VERBUNDEN     9280
                        unix  3      [ ]         DGRAM                    5140
                        unix  3      [ ]         STREAM     VERBUNDEN     423225
                        unix  2      [ ]         STREAM     VERBUNDEN     7630
                        unix  2      [ ]         DGRAM                    303550
                        unix  3      [ ]         STREAM     VERBUNDEN     424591
                        unix  2      [ ]         DGRAM                    303908
                        unix  3      [ ]         STREAM     VERBUNDEN     8579
                        unix  2      [ ]         DGRAM                    9448
                        unix  3      [ ]         STREAM     VERBUNDEN     462460
                        unix  3      [ ]         STREAM     VERBUNDEN     9279
                        unix  3      [ ]         DGRAM                    5141
                        unix  2      [ ]         DGRAM                    245555
                        unix  3      [ ]         STREAM     VERBUNDEN     462459
                        unix  3      [ ]         STREAM     VERBUNDEN     424590
                        unix  3      [ ]         STREAM     VERBUNDEN     8578
                        unix  3      [ ]         STREAM     VERBUNDEN     423224
                        870_generategas.js
                          Was sagt "top"? Ich kann nur jetzt RAM vermuten.
                          • derAuge
                            da wir hier nicht wirklich weiter kommen, habe ich mich entschieden das iobroker-System neu aufzusetzen. (Schade)
                            habe das "alte" Verzeichniss gesichert.
                            Anschließend mit
                            neu installiert.
                            Den Gedanke die einzelen Adapter nach und nach zurück zu sichern / kopieren habe ich wieder verworfen, da die Konfiguration aller Adapter in einer Datei gespeichert sind. [objects.json] (Oder sehe ich das falsch?) Daher habe ich keine Changse einzelne Adapter mit ihrer Konfiguration zurück zu spielen. (Da sind wir wieder bei dem Thema BACKUP: http://forum.iobroker.org/viewtopic.php … =445#p3164 )
                            Frage: Habe ich die Möglichkeit einzelne Adapter mit ihrer Konfiguration zurück zu sichern ?
                            Wenn es nicht Möglich ist muss ich wieder von vorne Anfangen und die Adapter installieren und konfigurieren
                            EDIT:
                            Im Bereich von VIS gibt es die Möglichkeit die Konfiguration zurück zu spielen.
                            Nach installation des Adaptern habe ich folgendes zurück kopiert:
                            root@pi2:/mnt/ioBroker/iobroker.Pi2# mkdir iobroker-data/files/vis.0
                            root@pi2:/mnt/ioBroker/iobroker.Pi2# mkdir iobroker-data/files/vis.0/main
                            root@pi2:/mnt/ioBroker/iobroker.Pi2# cp ../iobroker.Pi2.defekt/iobroker-data/files/vis.0/main/* iobroker-data/files/vis.0/main/
                            root@pi2:/mnt/ioBroker/iobroker.Pi2# ls -l iobroker-data/files/vis.0/main
                            insgesamt 28
                            ---------- 1 root root     0 Mär 21 10:17 vis-user.css
                            ---------- 1 root root 25244 Mär 21 10:17 vis-views.json
                            Somit habe ich eine Menge Arbeit gespart
                              Man kann alles (jeden einzelnen Adapter) importieren. Nun ist es nicht so bequem.
                              Alle Daten liegen in objects.json. Wenn du denn aufmachst und formatierst (z.b. mit notepad++) dann kannst du für jeden Adapter system.adapter.XXX.0 finden. Das ist Konfiguration vom Adapter XXX.
                              Man kann diese information einfach nehmen (common und native getrennt und in admin reinkopieren)
                              • ruhr70
                                ruhr70 last edited by
                                @derAuge:
                                filename="ioBrokerCPU-Last.PNG" index="0">~~
                                derAuge `
                                Hi derAuge,
                                womit hast Du denn die Grafik erzeugt?
                                Sieht sehr brauchbar aus.
                                Viele Grüße,
                                Michael
                                • derAuge
                                  @ruhr70:
                                  @derAuge:
                                  derAuge `
                                  Hi derAuge,
                                  Viele Grüße,
                                  Michael `
                                  Schau mal unter : http://rpi-experiences.blogspot.fr/p/rpi-monitor.html
                                  derAuge
                                  • ruhr70
                                    @derAuge:
                                    derAuge `
                                    Super, ich danke Dir!
                                    Das werde ich auf den Raspberrys ausprobieren.
                                    In meiner ioBroker installation hilft es mir leider nicht, da diese auf Debian läuft.
                                    Aber da wird es mit Sicherheit auch was geben 😉
                                    Danke 🙂
                                      @ruhr70:
                                      @derAuge:
                                      derAuge `
                                      Danke 🙂 `
                                      Kann jemand das beschreiben, wir nehmen das in Wiki rein. Grafik kann man in vis anbinden.
                                      • derAuge
                                        @Bluefox:
                                        @ruhr70:
                                        @derAuge:
                                        derAuge `
                                        Danke 🙂 Kann jemand das beschreiben, wir nehmen das in Wiki rein. Grafik kann man in vis anbinden.
                                        Ich hatte es nach folgender Anleitung installiert: http://jankarres.de/2013/11/raspberry-p … tallieren/
                                        ! Voraussetzung: Raspbian oder vergleichbare Distribution installiert
                                        ! Step 1
                                        ! Zunächst aktualisieren wir das System, sodass wir sichergehen können, dass alle installierten Pakete aktuell sind.
                                        sudo apt-get update && sudo apt-get upgrade
                                        Step 2
                                        >! Nun installieren wir folgende Pakete, welche von RPI-Monitor benötigt werden.
                                        sudo apt-get install dpkg-dev librrds-perl libhttp-daemon-perl libjson-perl libipc-sharelite-perl libfile-which-perl
                                        Step 3
                                        ! Jetzt ist es an der Zeit, RPI-Monitor herunterzuladen. Im Git Repository des Projekts findet man die aktuellen Debian Packages. Zum Zeitpunkt als dieses Tutorial geschrieben wurde, war Version 2.6-1 aktuell.
                                        wget --no-check-certificate https://github.com/XavierBerger/RPi-Monitor-deb/raw/master/packages/rpimonitor_2.6-1_all.deb
                                        Step 4
                                        >! Wir installieren RPI-Monitor und löschen anschließend die nicht mehr benötigte deb-Datei.
                                        sudo dpkg -i rpimonitor_2.6-1_all.deb
                                        rm rpimonitor_2.6-1_all.deb
                                        Step 5
                                        ! RPI-Monitor ist nun im Browser unter http://IP:8888/ (IP ersetzt durch IP-Adresse des Raspberry Pis) aufrufbar. Der Service wurde bereits automatisch im Autostart eingetragen, sodass das Webinterface auch nach einem Neustart des Raspberry Pis wieder verfügbar ist.
                                        ! Und das wars schon. Nun hat man übersichtlich den Status des Raspberry Pis im Blick und es werden automatisch Langzeitstatistiken erzeugt.
                                          Super.
                                            @derAuge:
                                            ! Step 1
                                            Step 2
                                            Step 3
                                            Step 4
                                            Step 5
                                            ! Und das wars schon. Nun hat man übersichtlich den Status des Raspberry Pis im Blick und es werden automatisch Langzeitstatistiken erzeugt. `
                                            Habe es übernommen. Ist das OK, dass ich dein Bild nutze?
                                            https://github.com/ioBroker/ioBroker/wi … stallieren
                                            1.0k
                                            5291
