    4. Fehler bei der Installation
    SOLVED Fehler bei der Installation
      martin last edited by
      Habe Debian 10.3.0 neu installiert und dann laut Anleitung iobroker.
      Leider kommen während der Installation unter Schritt 3 einige Meldungen mit denen ich nichts anfangen kann.
      Ist das alles korrekt so?
      root@iobroker:/# node -v
      v10.19.0
      root@iobroker:/# nodejs -v
      v10.19.0
      root@iobroker:/# npm -v
      6.13.4
      root@iobroker:/# curl -sL https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2020-01-30
          Welcome to the ioBroker installer!
          Installer version: 2020-01-25
          Installing prerequisites (1/4)
      OK:1 http://deb.debian.org/debian buster InRelease
      OK:2 http://security.debian.org/debian-security buster/updates InRelease
      OK:3 http://deb.debian.org/debian buster-updates InRelease
      OK:4 https://deb.nodesource.com/node_10.x buster InRelease
      Changing npm registry to https://registry.npmjs.org
      Installed gcc-c++
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      In file included from ../src/main.cpp:3:
      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      In file included from ../../nan/nan.h:54,
      ../src/main.cpp: At global scope:
      /root/.cache/node-gyp/10.19.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /root/.cache/node-gyp/10.19.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(diskusage, Init)
      In file included from /root/.cache/node-gyp/10.19.0/include/node/node.h:63,
      /root/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
      /root/.cache/node-gyp/10.19.0/include/node/node_object_wrap.h:84:78:   required from here
      /root/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                      reinterpret_cast<Callback>(callback), type);
      /root/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
      ../../nan/nan_object_wrap.h:65:61:   required from here
      /root/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
      In file included from ../src/unix_dgram.cc:5:
      ../src/unix_dgram.cc: At global scope:
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(unix_dgram, Initialize)
      Some packets could not be installed. Please install them manually
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
          ioBroker was installed successfully
          Open http://192.168.177.44:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      root@iobroker:/#
      • FredF
        FredF Most Active Forum Testing @martin last edited by
        @martin sagte in Fehler bei der Installation:
        Diese Meldungen hatte ich auch. System läuft.
        Sind ja keine Fehlermeldungen und es wird gemeldet
          Danke.
          Habe jetzt versucht das letzte Backup einzuspielen.
          Hier aber jetzt Probleme mit denen ich nicht klar komme.
          root@iobroker:/# iobroker stop
          root@iobroker:/# iobroker restore 0
          host.iobroker Using backup file total_2019_11_25-02_00_10_backupiobroker.tar.gz
          host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
          iobroker controller daemon is not running
          host.iobroker OK.
          (node:4959) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
              at Object.openSync (fs.js:443:3)
              at Object.readFileSync (fs.js:343:35)
              at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
              at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:846:22)
              at Daemon.emit (events.js:203:15)
              at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
              at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
              at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:848:20)
          (node:4959) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
          (node:4959) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          root@iobroker:/#
          • FredF
            @martin
            Ich bin mir nicht sicher, aber muß ioBroker vorher gestoppt werden?
              Wenn er läuft kommt die Meldung, dass man ihn stoppen soll.
              • FredF
                @martin
                Das gemacht
                  martin last edited by martin
                  Ja, ich mache nach jedem Schritt ein Reboot.
                  root@iobroker:~# iobroker upgrade self
                  Host    "iobroker"       is up to date.
                  • FredF
                    @martin Dann probier doch mal das fixer script drüber laufen zu lassen.
                    curl -sL https://iobroker.net/fix.sh | bash -
                      Habe jetzt alles (Debian + Iobroker) neu aufgesetzt.
                      root@iobroker:~# iobroker restore 0
                      Dann das Fixer-Script laufen lassen (erfolgreich) und nochmal restore.
                      host.iobroker OK.
                      root@iobroker:~#
                      Ich habe von der gecrashten Festplatte den /opt/iobroker Ordner kopieren können.
                      Kann ich den einfach per FTP drüber bügeln?
                        Habe es jetzt mal mit "backitup" versucht.
                        Log Backitup Restore:
                        [DEBUG] [iobroker] Start ioBroker Restore ...
                        [ERROR] [iobroker] host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
                        [DEBUG] [iobroker] iobroker controller daemon is not running
                        [DEBUG] [iobroker] host.iobroker OK.
                        [DEBUG] [iobroker] ioBroker Restore completed successfully
                        [EXIT] 9 **** Restore completed successfully!! ****
                        The log can be closed ...
                          Und nach iobroker upgrade self das hier:
                          root@iobroker:/opt/iobroker# iobroker restore 0
                          host.iobroker Using backup file iobroker_2020_02_18-19_14_04_backupiobroker.tar.gz
                          host.iobroker OK.
                          (node:1151) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
                              at Object.openSync (fs.js:439:3)
                              at Object.readFileSync (fs.js:344:35)
                              at Daemon.emit (events.js:194:15)
                          (node:1151) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                          (node:1151) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                            Lösung:
                            du legst dein Backup in den Ordner /opt/iobroker und führst folgenden Befehl in diesem Ordner aus:
                            iobroker stop
                            cd /opt/iobroker
                            sudo tar -xzvf Backupname.tar.gz -C /opt/iobroker
                            iobroker start
                            Jetzt läuft alles zumindest mal wieder und meine Daten sind da.
                            Werde die nächsten Tage mal ein Standard-Backup erstellen das ich dann hoffentlich in eine saubere Neuinstallation per "Restore" einspielen kann.
                            iobroker installation
                            955
