    4. Send this info to Developer
    SOLVED Send this info to Developer
      bwl last edited by bwl
      habe mir die Homematic IP Fernbedienung "HMIP-KRCA" zugelegt, in iobroker eingebunden, Tasten werden auch angezeigt aber keine Werte angezeigt/aktualisiert. Im logfile steht:
      2020-02-19 18:04:42.607  - info: hm-rpc.0 (13305) xmlrpc <- newDevices 7
      2020-02-19 18:04:42.678  - info: hm-rpc.0 (13305) new HmIP devices/channels after filter: 7
      2020-02-19 18:04:42.753  - info: hm-rpc.0 (13305) xmlrpc -> getParamsetDescription ["00099A499CF93A:0","VALUES"]
      2020-02-19 18:04:42.788  - warn: hm-rpc.0 (13305) Send this info to developer: {"_id":"hm-rpc.meta.VALUES.HmIP-KRCA.MAINTENANCE.2","type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"CONFIG_PENDING","TYPE":"BOOL","DEFAULT":false},"DUTY_CYCLE":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":1,"ID":"DUTY_CYCLE","TYPE":"BOOL","DEFAULT":false},"LOW_BAT":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"LOW_BAT","TYPE":"BOOL","DEFAULT":false},"INSTALL_TEST":{"MIN":false,"OPERATIONS":3,"MAX":true,"FLAGS":2,"ID":"INSTALL_TEST","TYPE":"BOOL","DEFAULT":false},"UNREACH":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":25,"ID":"UNREACH","TYPE":"BOOL","DEFAULT":false},"OPERATING_VOLTAGE_STATUS":{"MIN":"NORMAL","OPERATIONS":5,"MAX":"OVERFLOW","FLAGS":1,"ID":"OPERATING_VOLTAGE_STATUS","TYPE":"ENUM","DEFAULT":"NORMAL","VALUE_LIST":["NORMAL","UNKNOWN","OVERFLOW"]},"RSSI_DEVICE":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_DEVICE","TYPE":"INTEGER","DEFAULT":0},"OPERATING_VOLTAGE":{"MIN":0,"OPERATIONS":5,"MAX":25.2,"FLAGS":1,"ID":"OPERATING_VOLTAGE","TYPE":"FLOAT","DEFAULT":0},"RSSI_PEER":{"MIN":-128,"OPERATIONS":5,"MAX":127,"FLAGS":1,"ID":"RSSI_PEER","TYPE":"INTEGER","DEFAULT":0},"UPDATE_PENDING":{"MIN":false,"OPERATIONS":5,"MAX":true,"FLAGS":9,"ID":"UPDATE_PENDING","TYPE":"BOOL","DEFAULT":false}}}
      2020-02-19 18:04:42.871  - info: hm-rpc.0 (13305) xmlrpc -> getParamsetDescription ["00099A499CF93A:1","VALUES"]
      2020-02-19 18:04:42.889  - warn: hm-rpc.0 (13305) Send this info to developer: {"_id":"hm-rpc.meta.VALUES.HmIP-KRCA.KEY_TRANSCEIVER.2","type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PRESS_SHORT":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_SHORT","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.SHORT"},"PRESS_LONG":{"MIN":false,"OPERATIONS":4,"MAX":true,"FLAGS":1,"ID":"PRESS_LONG","TYPE":"ACTION","DEFAULT":false,"CONTROL":"BUTTON_NO_FUNCTION.LONG"}}}
      2020-02-19 18:04:42.961  - info: hm-rpc.0 (13305) xmlrpc -> getParamsetDescription ["00099A499CF93A:5","VALUES"]
      Wäre toll wenn jemand die Fernbedienung einpflegen könnte.
      Liebe Grüße
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: DietPi
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      • foxriver76
        foxriver76 Developer last edited by
        Ja, braucht bestimmt ein Dummy Programm auf der CCU.
        Metas als Issue sind ok das andere potentiell kein Issue, siehe oben.
        • sigi234
          sigi234 Forum Testing Most Active @bwl last edited by
          @bwl sagte in Send this info to Developer:
          Issues an:
          https://github.com/ioBroker/ioBroker.hm-rpc
          • foxriver76
              bwl last edited by
              Ah danke für den Tipp, lag an fehlendem Dummy Programm war wohl etwas zu voreilig bzw verwirrt durch die Log Meldung
              info
