    4. Zigbee - nach Update geht nichts mehr
    SOLVED Zigbee - nach Update geht nichts mehr
      janachti last edited by
      |Hardwaresystem:| Pi3 |
      |Arbeitsspeicher:| 1GB |
      |Node-Version:| 10.19.0 |
      |NPM-Version:| 6.13.4 |
      Hallo zuammen,
      ich verzweifle seitdem ich den Zigbee-Adapter auf 1.0.3 aktualisiert habe. Seitdem bekomme ich ihn nicht mehr zum Laufen. Direkt nach dem Update habe ich folgendes Fehlerlog bekommen:
      2020-02-27 20:13:18.656 - info: zigbee.0 (3412) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
      2020-02-27 20:13:18.706 - info: zigbee.0 (3412) Starting Zigbee...
      2020-02-27 20:13:18.708 - debug: zigbee.0 (3412) Starting zigbee-herdsman...
      2020-02-27 20:13:31.130 - error: zigbee.0 (3412) Failed to start Zigbee
      2020-02-27 20:13:31.131 - error: zigbee.0 (3412) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:72:23)
      at Generator.throw ()
      at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:6:65)
      2020-02-27 20:13:41.133 - info: zigbee.0 (3412) Try to reconnect. 1 attempts left
      2020-02-27 20:13:41.134 - info: zigbee.0 (3412) Starting Zigbee...
      2020-02-27 20:13:41.135 - debug: zigbee.0 (3412) Starting zigbee-herdsman...
      2020-02-27 20:13:46.358 - error: zigbee.0 (3412) Failed to start Zigbee
      2020-02-27 20:13:46.360 - error: zigbee.0 (3412) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
      at Generator.next ()
      at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
      at new Promise ()
      at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
      at SerialPort.serialPort.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
      at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      at binding.open.then.err (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12)
      Ich habe aus Verzweiflung Node und NPM auf den neusten Stand gebracht, einen anderen CC2531-Stick getestet, alle Befehle, die ich in Foren gefunden habe benutzt, zig mal neu installiert...nichts gebracht.
      Hat vielleicht einer einen Tipp?
      Danke!
        w00dy last edited by w00dy
        lösch doch die 1.0.3 Version und geh wieder zurück auf die Version davor (hoffe, das war die Stable-Version 1.0.2). Dann den alten Zigbee-Stick wieder einstecken den du mit der funktionierenden Version genutzt hast und die Zigbee-Backupdatei von vor deiner Aktualisierung wieder einspielen. Dann bist du wieder auf dem gleichen Stand wie vor deiner Aktualisierung und es müsste somit wieder laufen.
          War auch mein Plan, aber ich habe blöderweise aus zeitlichen Gründen verpennt, das Backup zu speichern. Das wurde dann nach ein paar Tagen überschrieben.
          Auf ältere Versionen zu gehen, hat leider nichts bewirkt. Kann man den Adapter vielleicht rückstandsfrei entfernen und dann neu installieren?
            arteck Developer Most Active @janachti last edited by
            @janachti der serialport ist zu.. Schon mal die Kiste neu gestartet
              janachti @arteck last edited by
              @arteck Ich habe es nun wieder zum Laufen bekommen. Es lag tatsächlich an einem defekten CC2531.
              Und der erste Ersatz, den ich besorgt hatte, funktionierte auch nicht. Der wurde nicht mal am Win 10-PC erkannt.
              Den zweiten Stick reingesteckt und es ging problemlos.
                @janachti sehr gut
                cc2531 update zigbee
