    4. Mi vacuum Adapter kann nicht installiert werden
    UNSOLVED Mi vacuum Adapter kann nicht installiert werden
      haenk93 last edited by Negalein
      Hallo
      Ich versuche den mi vacuum adapter zu installieren leider kommt bei der Installation immer ein oder mehrere Errors. Leider bin ich ein absoluter Noob und kann damit nichts anfangen
      $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master" mihome-vacuum --debug
      install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master
      NPM version: 6.13.4
      npm install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
      > canvas@2.6.1 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp
       ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.93-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5
      gyp ERR! not ok
      node-pre-gyp
      ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.93-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.18.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      npm
       ERR! code
       ELIFECYCLE
      npm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
      npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-02-29T11_13_28_603Z-debug.log
      ERROR: host.raspberrypi Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
      ERROR: process exited with code 25
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      • Meistertr
        Hallo, als Anfänger sollte man nicht die Entwicklerversionen installieren außer man weiß was man macht. Desweiteren sollte man auch immer die readme lesen bevor man loslegt. Dort ist der Fehler aufgeführt und beschrieben was gemacht werden muss
        • Espace0401
          Espace0401 last edited by
          vorab, ich habe die Readme gelesen und die Bibliotheken manuell installiert. Hierbei hatte ich jedoch folgenden Fehler, vielleicht kann einer was damit anfangen.
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/gettext/autopoint_0.19.8.1-2_all.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/gettext/gettext_0.19.8.1-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/i/icu/icu-devtools_57.1-6+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/e/expat/libexpat1_2.2.0-2+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/e/expat/libexpat1-dev_2.2.0-2+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/glib2.0/libglib2.0-bin_2.50.3-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/g/glib2.0/libglib2.0-dev_2.50.3-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/pool/main/i/icu/libicu-dev_57.1-6+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
          E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
          Beim Update kommt es trotzdem zu dem unten stehenden Fehler. Ferner ist bei dem fehlerhaften Update, der Adapter auch anschließend aus der Liste der Adapter verschwunden, die Instanze ist aber noch da. Habe dann manuell wieder die Version 1.1.5 installiert.
          $ ./iobroker upgrade mihome-vacuum
          Update mihome-vacuum from @1.1.5 to @2.0.7
          NPM version: 6.9.0
          npm install iobroker.mihome-vacuum@2.0.7 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
          gyp
           ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.14.34-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.0gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
          node-pre-gyp ERR!
          build error
          node-pre-gyp
           ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR!
          stack
          node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
          npm
           ERR! code
           ELIFECYCLE
          npm
          ERR!
          errno 1
          npm
          ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.
          npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2020-03-02T07_59_18_524Z-debug.log
          ERROR: host.ioBroker-RasPi Cannot install iobroker.mihome-vacuum@2.0.7: 1
          Espace0401 1 Reply Last reply Reply Quote 0
          • Espace0401
            Espace0401 @Espace0401 last edited by
            @Espace0401
            hat sich erledigt. Habe den Fixer drüber laufen lassen
            adapter error mi vacuum
