    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Управление GPIO
    Управление GPIO
      Alekseym6 last edited by
      пример рабочего скрипта
      var gpio = require("gpio");
      var gpioSensDoor = 87;
      var gpioRelLamp1 = 88;
      var gpioSensMotion = 89;
      var gpioRelLamp2 = 94;
      createState('SensDoor','',{type:'boolean',role:'indicator.state',read:true});
      createState('RelLamp1','',{type:'boolean',role:'indicator.state',read:true});
      createState('RelLamp2','',{type:'boolean',role:'indicator.state',read:true});
      createState('SensMotionVestibul','',{type:'boolean',role:'indicator.state',read:true});
      // Calling export with a pin number will export that header and return a gpio header instance
      var gpio87 = gpio.export(gpioSensDoor, {
      // When you export a pin, the default direction is out. This allows you to set
      // the pin value to either LOW or HIGH (3.3V) from your program.
      direction: 'in',
      // set the time interval (ms) between each read when watching for value changes
      // note: this is default to 100, setting value too low will cause high CPU usage
      interval: 100,
      // Due to the asynchronous nature of exporting a header, you may not be able to
      // read or write to the header right away. Place your logic in this ready
      // function to guarantee everything will get fired properly
      ready: function() {
      var gpio88 = gpio.export(gpioRelLamp1, {
      direction: 'out',
      ready: function() {
      var gpio89 = gpio.export(gpioSensMotion, {
      direction: 'in',
      ready: function() {
      var gpio94 = gpio.export(gpioRelLamp2, {
      direction: 'out',
      ready: function() {
      // bind to the "change" event
      gpio87.on("change", function(val) {
      // value will report either 1 or 0 (number) when the value changes
      if ( val == 1 ) {
      setState('SensDoor', true, true);
      } else {
      setState('SensDoor', false, true);
      gpio89.on("change", function(val) {
      if ( val == 1 ) {
      setState('SensMotionVestibul', true, true);
      } else {
      setState('SensMotionVestibul', false, true);
      on("RelLamp1", function (obj) {
      if ( obj.newState.val == 1 ) {
      gpio88.set();
      } else {
      gpio88.set(0);
      on("RelLamp2", function (obj) {
      gpio94.set();
      } else {
      gpio94.set(0);
      • V
        vtec last edited by
        Управление gpio это хорошо, но может плату укажите какой управляете?
          spectrekr last edited by
          Угу, а еще желательно от какого пользователя работает IOBroker, и если не от root, то как организовали доступ пользователю к параметрам GPIO.
            сечас работает на ODROID X2 и C1+, раньше запускал на Raspberry PI2, Cubieboard. работает от user(не root).
            нужно добавить user в группу gpio
