    3. Tester
    4. Test Coronavirus Statistics for ioBroker
    • Dutchman
      Dutchman Developer Most Active Administrators last edited by Dutchman
      Aktuelle Test Version 0.6.9
      Veröffentlichungsdatum 22-03-2021
      Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
      NPM npm i ioBroker.coronavirus-statistics@latest
      Adapter to show Global Corona Virus information and current reports
      Coronavirus Live Statistics adapter for ioBroker
      There is no configuration required, after installation it will :
      • Receive global information world-wide and write it to "global_totals"
      • Create a folder for each country with all relevant information regarding COVID-19
      • Update the information every 15 minutes
      The following information is available :
      Datapoint Details
      active Amount of current infected people
      cases Amount of totally known cases
      casesPerOneMillion Amount of totally known cases per million citizen
      critical Amount of critical situation (Hospitalized)
      deaths Amount of current registered deaths
      deathsPerOneMillion Amount of current registered deaths per million citizen
      recovered Amount of totally known recovered cases
      todayCases New Cases by Today
      todayDeaths Amount of totally known people died today
      test Total number of covid-19 tests taken globally
      tests per one million counties Total number of covid-19 tests taken globally per one million
      Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
      German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
      Generic Source : https://coronavirus-19-api.herokuapp.com
      Advanced settings
      Option Description
      All Countries Get data for all countries World-Wide (Default: false)
      Continents Group total amounts by continent in seperate state (Default: false)
      Delete unused States Delete data when countries are deselected (Default: false)
      German counties Get counties data for Germany (Selected only, Default false)
      German federal states Get federal state data for Germany (Selected only, Default false)
      Get all German federal states Get federal state data for Germany (Default false)
      Get all German counties Get all counties data for Germany (Default false)
      For Germany only
      It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
      You can choose to recieve all data or just select specific regions in advanced settings.
      Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
      Add missing countries
      It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
      coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
      Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
      List with country names
      With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
      The JSON string then looks like this, for example:
      	"Cabo_Verde": "Cape Verde",
      	"Timor-Leste": "East Timor"
      As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
      Changelog
      sigi234 Chaot ? D A 27 Replies Last reply Reply Quote 4
      • sigi234
        sigi234 Forum Testing Most Active @Dutchman last edited by sigi234
        @Dutchman
        Hallo, wie kann ich das Widget anwenden?
        Erledigt, ein Neustart hat geholfen.
        Latzi 1 Reply Last reply Reply Quote 0
        • sigi234
          @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
          COVID-19
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at endReadableNT (_stream_readable.js:1145:12)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at IncomingMessage.emit (events.js:203:15)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Object.onceWrapper (events.js:286:20)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\request\request.js:1076:12)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.emit (events.js:198:13)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.<anonymous> (C:\Program Files\iobroker\Test\node_modules\request\request.js:1154:10)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.self.callback (C:\Program Files\iobroker\Test\node_modules\request\request.js:185:22)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.request [as _callback] (C:\Program Files\iobroker\Test\node_modules\iobroker.coronavirus-statistics\main.js:51:26)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at JSON.parse (<anonymous>)
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	(14256) SyntaxError: Unexpected end of JSON input
          coronavirus-statistics.0	2020-03-16 13:29:07.148	error	(14256) uncaught exception: Unexpected end of JSON input
          Dutchman 1 Reply Last reply Reply Quote 0
          • Dutchman
            Dutchman Developer Most Active Administrators @sigi234 last edited by
            @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
            COVID-19
            das passiert wen die API nicht erreichbar ist, keine sorge nach 15 min probieren wir es nochmal.
            Ich spiele mit dem Gedanken direkt einen retry ein zu bauen aber denke mal 15 min ist ok damit die API auch nicht überlastet wird
            • Dutchman
              sollte mit 0.2.0 nicht mehr passieren
              • sigi234
                @Dutchman
                Test:
                In der Land Liste sind undefinierbare Länder drinnen
                Wünsche:
                Ein DP als Table
                Land ein/aus blendbar
                Zahlen konfigurierbar
                Dutchman K 2 Replies Last reply Reply Quote 1
                • Dutchman
                  Ein DP als Table
                  gerne gitissue erstellen, kan ich es abarbeiten
                  same here
                  sie meinen ?
                  • sigi234
                    sie meinen ?
                    Größe änderbar
                    • Dutchman
                      sie meinen ?
                      Größe änderbar
                      welche Größe ?
                      • sigi234
                        sie meinen ?
                        Größe änderbar
                        welche Größe ?
                        • Dutchman
                          sie meinen ?
                          Größe änderbar
                          welche Größe ?
                          da bin ich raus @Bluefox war so nett die zu machen front-end ist nicht meine stärke
                          • sigi234
                            @Dutchman
                            coronavirus-statistics.0	2020-03-16 15:18:59.329	info	(13556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            coronavirus-statistics.0	2020-03-16 15:18:55.508	warn	(13556) State attribute definition missing for + updated
                            coronavirus-statistics.0	2020-03-16 15:18:50.119	info	(13556) starting. Version 0.2.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.coronavirus-statistics, node: v10.16.3
                            • Latzi
                              Latzi @sigi234 last edited by
                              Die Frage stellt sich mir auch, dummerweise hat ein Neustart mir nicht die Augen geöffnet. Kannst du mir bitte weiterhelfen?
                                Homoran Global Moderator Administrators @sigi234 last edited by
                                @Dutchman
                                Habe das WARN auch
                                • sigi234
                                  sigi234 Forum Testing Most Active @Latzi last edited by
                                  @Latzi sagte in Test Coronavirus Statistics for ioBroker:
                                    Tobias last edited by
                                    Habt ihr auch ein Problem mit der Darstellung?
                                    Unterste Zeile...
                                    • sigi234
                                      sigi234 Forum Testing Most Active @Tobias last edited by
                                      @Tobias
                                      CSS Font und Text
                                      T 1Topf 2 Replies Last reply Reply Quote 0
                                        stimezo Forum Testing last edited by
                                        Kann man sich aber auch schnell selber basteln 🙂 :
                                        Christian
                                        sigi234 C P A 4 Replies Last reply Reply Quote 1
                                        • sigi234
                                          sigi234 Forum Testing Most Active @stimezo last edited by
                                          @stimezo
                                          Kannst du die Icons zur Verfügung stellen?
                                            stimezo Forum Testing @sigi234 last edited by
                                            @stimezo
                                            Per mail?
                                            Christian
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            332707
