    4. Error beim Installieren von Adaptern
    UNSOLVED Error beim Installieren von Adaptern
      Datainspektor last edited by Datainspektor
      Systemdata Bitte Ausfüllen
      Hardwaresystem: WMWare ESX 6.0
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Node-Version: 10.19.0
      Nodejs-Version: 10.19.0
      NPM-Version: 6.13.4
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      beim installieren sowie aktualisieren bekomme ich folgenden Fehler.
      Liegt das an dem nicht verfügbaren Bluetooth auf der Debian Maschine und kann ich das ingnorieren?
      $ ./iobroker upgrade swiss-weather-api
      Update swiss-weather-api from @0.1.6 to @0.2.0
      NPM version: 6.13.4
      npm install iobroker.swiss-weather-api@0.2.0 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc: At global scope:/home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
      In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63,                 from ../src/linux/BluetoothSerialPort.cc:12:/home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.19.0/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../node_modules/nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
      ../src/linux/DeviceINQ.cc:35:14: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden     #include <bluetooth/bluetooth.h>              ^~~~~~~~~~~~~~~~~~~~~~~
      compilation terminated.
      make: *** [BluetoothSerialPort.target.mk:109: Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
      gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
      node-pre-gyp
        msauer last edited by Negalein
        Hi, diesen Fehler bekomme ich seit einm paar Tagen auch,,,seltsam..dachte erst, das mein Bluetooth Modul, welches ich für Radar2 nutze, ein Problem hat. Aber das wird ordnungsgemäß an die VM weitergereicht.
        2020-04-23 12:26:09.149 - info: host.MSNUC-IOB iobroker In file included from ../src/DeviceINQ.h:17, from ../src/linux/BluetoothSerialPort.cc:13:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
        2020-04-23 12:26:09.198 - info: host.MSNUC-IOB iobroker ../src/linux/BluetoothSerialPort.cc: At global scope:../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void void InitAll(Handle exports) { ^~~~~~
        2020-04-23 12:26:09.200 - info: host.MSNUC-IOB iobroker ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
        2020-04-23 12:26:09.204 - info: host.MSNUC-IOB iobroker ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’ void InitAll(Handle exports) { ^~~~~~ rand_r../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token void InitAll(Handle exports) { ^
        2020-04-23 12:26:09.205 - info: host.MSNUC-IOB iobroker ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope void InitAll(Handle exports) { ^~~~~~~
        2020-04-23 12:26:09.209 - info: host.MSNUC-IOB iobroker In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~/home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
        2020-04-23 12:26:09.404 - info: host.MSNUC-IOB iobroker make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Fehler 1
        2020-04-23 12:26:09.406 - info: host.MSNUC-IOB iobroker gyp
        2020-04-23 12:26:09.408 - info: host.MSNUC-IOB iobroker ERR! build error
        2020-04-23 12:26:09.410 - info: host.MSNUC-IOB iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:310:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar2/node_modules/node-bluetoothgyp ERR! node -v
        2020-04-23 12:26:09.412 - info: host.MSNUC-IOB iobroker v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
        @apollon77 : Kann das mit dem JS V3 zu tun haben?
        Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
        Hier gehts zur Hilfe.
        • apollon77
          apollon77 @msauer last edited by
          @msauer Der Fehler kommt von irgendeinem Adapter (radar2) der irgendwas mit Bluetooth macht und ggf eine alte Verison drin hat. beim radar2 bitte Issue anlegen!
          error
