    4. KNX adapter can't connect with GIRA IP-Router
    UNSOLVED KNX adapter can't connect with GIRA IP-Router
      Janosz78 last edited by
      Hello,
      I have problems with connecting to my KNX IP-Router (GIRA - 2167 00) after updating of KNX adapter.
      I use the newest version of adapter (1.0.39).
      I attached logs:
      knx.0 2020-03-24 18:46:46.892 info (16794) Change state from STATE_NOT_CONNECTED(0) to STATE_OPENING_PORT(1)
      knx.0 2020-03-24 18:46:46.889 info (16794) Using UDP with local IP: 192.168.1.4
      knx.0 2020-03-24 18:46:44.888 info (16794) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECT_REQUEST(3) to STATE_NOT_CONNECTED(0).
      knx.0 2020-03-24 18:46:44.886 info (16794) ... not able to close connection, because already closed
      knx.0 2020-03-24 18:46:44.877 info (16794) Connection persists.....closing now
      knx.0 2020-03-24 18:46:44.874 info (16794) Change state from STATE_CONNECT_REQUEST(3) to STATE_NOT_CONNECTED(0)
      knx.0 2020-03-24 18:46:42.869 info (16794) Change state from STATE_PORT_OPENED(2) to STATE_CONNECT_REQUEST(3)
      knx.0 2020-03-24 18:46:42.867 info (16794) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 00 00 00 00 bb af 08 01 c0 a8 01 04 bb af 04 04 02 00 sent to 192.168.1.10:3671
      knx.0 2020-03-24 18:46:42.849 info (16794) Connected - local UDP Server listening on 192.168.1.4:48047
      knx.0 2020-03-24 18:46:42.832 info (16794) Change state from STATE_OPENING_PORT(1) to STATE_PORT_OPENED(2)
      knx.0 2020-03-24 18:46:42.829 info (16794) Event : UDP - listening
      knx.0 2020-03-24 18:46:42.809 info (16794) Debuglevel: 10 5
      knx.0 2020-03-24 18:46:42.780 info (16794) Connecting to knx GW: 192.168.1.10:3671 with phy. Adr: 1.1.128
      andreaskos 1 Reply Last reply Reply Quote 0
      • andreaskos
        andreaskos @Janosz78 last edited by
        @Janosz78
        Hi there,
        I had a Smart Home workshop today at my university in St.Pölten in Austria where I introduced ioBroker in connection to KNX. I installed 3 systems with GIRA IP-Interface 2068. The setup was identical at all 3. Two systems showed exactly the same behavior. The third was ok without any error.
        ?? I don't know the reason either...
        Best regards,
        Andreas
        1.0.39 adapter knx connection problem
